Joined Jun 2006
AXI Silver
I have one in and AUW 15.5 Oz model, and the vertical is fast , But its never used that way , just a squirt to get me out of trouble sometimes , when I get out of shape , with a 9 by 4 APC on,,,, acceleration is instant and I feel that full throttle turns around the sky would snap the model , its lightly built , no way would a gold make any difference to this model except in price and its been running for months,, 180 Watts of real power
.My guess is there is a larger difference in real life... It would be interesting to find out. |
Joined Jun 2006
Yes Dr K
My calcs are 12.6V by 16 A are over 200 watts , Its a 16 A for minute allowable motor , thats real big power in 15.5 Oz AUW and I dont know if its pulling 16 on a 9 by 4 APC , I reckon that I could pull a 9.5 by 4 ( more amps for a short period ) and have even more massive performance
But to be sure its not a WOT setup It would be crazy to do that, Im burning a CS 1650MaH , 10C 3S , so thats right for 16A constant and about 24A burst if I remember right Wide open throttle in the far sky is a far different setup to short sharp 3D and the 2 setups dont seem to mix,,,,,, I made sure I understood the setup before I converted to electric,, it really pays |
I just tried Motocalc with the Silver Axi 2212/20 on 3s and a 9x4.5 APC E (I assume that's what you have) - I can't see 180-200W anywhere - just over 12A and 125W is what it predicts.
I don't quite understand your 12.6v and 16A - {unless you are using 4s} there is no way you can get 12.6v out of a 3s pack - a 1650 10C pack might deliver 10.5v under 16A load but not much more. |
Joined Jun 2006
Hey Dr
Just goes to show how much
I know about Electric Zip Im glad Im talking to you guys I see ,,, under load you mean you have a lot less voltage to play with ,MMMMM, and your saying I can run a lot more prop but my bat may be not up to delivering 16 amps ,,, oh no Luck the plane even works ,, but as I said the performance is good I was under the impression that a 1650 battery,, 10C,, could deliver 16 A Constant
| Thread Tools | |
| Off Site AXI 2212/34 Brushless Motor from Model Motors - New | Allan_A | Aircraft - Electric - Airplanes (FS/W) | 4 | Jun 19, 2005 07:18 PM |
| Could I put my AXI 2212/34 or 2208/34 on a hummingbird V.3? | Daniel11 | Micro Helis | 2 | Dec 07, 2004 07:22 PM |
| Little Axi 2212/34 power house | KillerAir | Power Systems | 360 | Feb 21, 2004 05:09 PM |
| WTB Model Motors AXI 2212/34 | DRL | Aircraft - Electric - Airplanes (FS/W) | 1 | Jan 13, 2004 07:00 PM |
| Mounting an axi 2212/34? | tabbytabb | Power Systems | 3 | Dec 10, 2003 01:20 PM |
