Old Jan 16, 2007, 06:59 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
just a little info, 2mm depron has the same weight as 3mm. the 2mm has more skin to it because of the process used to make it. it was discussed in depth in the indoor and micro models board.
maybe i should go for a record breaker of under 5 grams ive got all the gear to do it
Derrik
derk is offline Find More Posts by derk
Old Jan 16, 2007, 11:45 PM
urs is offline
urs
Find More Posts by urs
urs
switzerland
Joined Dec 2000
mini mini
Hi
here a few details to my mini mini twirl,23 grms weight 14 size of the halfsize twirl. (just printed out the 1/2 size twirl 2 pages to the one page) has the plantco scout setup and this gives it just enough power to fly around the hall at about a meter height. Turns nice and flat looks great. Will experiment with a bit more power. Had a plug in undercariage took it of after first flight trying to go higher.
urs (switzerland)
urs is offline Find More Posts by urs
Old Jan 17, 2007, 01:16 AM
iter is offline
Find More Posts by iter
High-power Rocket Gliders
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
I love the little one! I've been thinking about doing a Plantraco-based Twirl for some time but never did anything about it. Yours is most impressive! I'm looking forward to it's reaching its full performance potential, and to a video if you can post one.
Well done!
Ari.
iter is offline Find More Posts by iter
Old Jan 17, 2007, 06:15 AM
alfoot is offline
Find More Posts by alfoot
Keep it simple
alfoot's Avatar
Salisbury,England
Joined Jan 2005
Urs,
Your mini-minitwirl looks great - as iter says, it would be great to see a video of it in flight if you can.
Al
alfoot is offline Find More Posts by alfoot
Old Jan 17, 2007, 12:34 PM
urs is offline
urs
urs
switzerland
Joined Dec 2000
Hi all
his sunday our club has its indoor meeting this sunday, I wiil try for some film then.
urs
Old Dec 26, 2008, 07:02 PM
thechannelmast is offline
Find More Posts by thechannelmast
thechannelmast's Avatar
martinsville indiana
Joined Dec 2007
mintwirl
hi i have built a mini twirl it does fly like it big brother here some pics
thechannelmast is offline Find More Posts by thechannelmast
Old Dec 27, 2008, 04:42 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Nice work Jeff,
Would be nice to see a video of your gyro in flight if you can.
Regards Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Dec 27, 2008, 08:43 AM
Joined Dec 2007
hi
soon as the wind let down ill try get some video and here is the finish pics
Old Jan 29, 2013, 08:48 PM
bloomqum is online now
Find More Posts by bloomqum
Rome, NY
Joined May 2010
Thanks to inspiration by this thread and a $5 fuselage from a swap meet the contained an E-Flite 180 motor, Castle Creations ESC, and two micro servos, this is my MiniTwirl (yet to be maidened).
bloomqum is online now Find More Posts by bloomqum
Old Jan 29, 2013, 10:08 PM
Joined Dec 2007
bloomqum
look good is that 6mm foam you use keep us post on flite
Old Jan 30, 2013, 06:04 AM
Rome, NY
Joined May 2010
Mostly 5mm with some 4mm (Dollar Tree foam with the paper stripped). Then the blades are 3mm with bamboo skewers on the leading edge. I'm scared to weigh it, but the E-Flite 180 will almost hover it out of my hand ( @ full throttle).
46 Gram Micro 3D with 7.7g Brushless Motor! bselman Scratchbuilt Indoor and Micro Models 141 May 05, 2008 03:50 PM
Check this out!! 46 gram micro 3d'er Ben McCoy 3D Flying 0 Jul 10, 2004 04:09 PM
