Old Sep 19, 2006, 12:50 PM
gorgeflyer is offline
Find More Posts by gorgeflyer
Slope Dog
gorgeflyer's Avatar
The Gorge
Joined Mar 2002
Leading Edge Leading Edge?
I started the spar for a LEG Hellcat last night and it got me to thinking about my last build with epp. I love the finished product but hate taping the leading edge of the wing. Have any of you guys used a basswood leading edge? Or maybe take it a step further and use a carbon rod? I am not worried about hitting a rock on landing or anything like that so I don't see why not. Should also add a little weight which isn't a bad thing either. I want to be able to keep up with Vic pumping half pipes next time I fly with him.
gorgeflyer is offline Find More Posts by gorgeflyer
Old Sep 19, 2006, 01:12 PM
legliderman is offline
Find More Posts by legliderman
All work and no play
legliderman's Avatar
Lucas, KS
Joined Apr 2003
Dont see why it wouldnt work. DO IT!
legliderman is offline Find More Posts by legliderman
Old Sep 19, 2006, 01:32 PM
THUREN is offline
Find More Posts by THUREN
blah...
THUREN's Avatar
United States, OR, Bend
Joined Jun 2005
Should work great, but IMO, goes a "little" beyond the point of building a foamy.
I was thinking this same thing on my last build. I hate where the top and bottom tape layers meet. You can't get a SUPER clean line there so my idea next time is this...
Use a TON of thinned goop on the LE, tape the wing normally, and then where the tape meets at the LE run a bead of goop over it and smooth it down as clean as possible. Now put a piece of the 3" wide thin cheap masking tape to smooth it down till it tacks up.... Once it's mostly dry smooth it down with a rag soaked in Toluene...
Should be a bomb-proof, but pliable LE when need be...
Just an idea...
-Don
THUREN is offline Find More Posts by THUREN
Old Sep 19, 2006, 01:51 PM
I'm Rick James is offline
Find More Posts by I'm Rick James
Nucking Futs
I'm Rick James's Avatar
Southern Killafornia
Joined Jan 2005
I figured a half dozen passes over the LE with some primer over the Solartex before paint would be enough buildup to get rid of that bump.
I'm done taping my P40 wing and will try that over the LE and the tips where I couldn't get it absolutely perfect.
We'll see how it comes out. RJ
I'm Rick James is offline Find More Posts by I'm Rick James
Old Sep 19, 2006, 03:29 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
The point of having an EPP plane is bouncibility without serious permanent damage. If you're going to put a hard leading edge on it--go composite!!!
IMHO
Timmig
timmig is offline Find More Posts by timmig
Old Sep 19, 2006, 03:30 PM
Slope Dog
gorgeflyer's Avatar
The Gorge
Joined Mar 2002
Just an idea...
-Don
The reason I am going down this path is I am lazy at heart. I am trying to get the best result with the least amount of work. I've had my fun with thinned goop and stinking up the house. I think this would make a very clean LE with very little effort. Off to the LHS for a gander at the basswood supply.
Old Sep 19, 2006, 03:32 PM
Slope Dog
gorgeflyer's Avatar
The Gorge
Joined Mar 2002
IMHO
Timmig
Ok, scatch that last post. Off to Fibreglass supply for some 6 oz carbon. Don't know how well it will stick to EPP though.
Old Sep 19, 2006, 03:42 PM
timmig is offline
timmig's Avatar
Southern California
Joined Sep 2003
Well it appears you want composite performance, and now are going to pay the composite price if you hit something. Why not just make the change and get the performance you seek?
T
Old Sep 19, 2006, 03:56 PM
codezilla is offline
Find More Posts by codezilla
codezilla's Avatar
Chino Hills, CA
Joined Feb 2003
If you're thinking about laying up carbon on the leading edge, you should spackle it first otherwise the foam will drink epoxy.
Adrian
codezilla is offline Find More Posts by codezilla
Old Sep 19, 2006, 04:01 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
I guess it would be fairly easy if you can find the perfect piece of Bass...
If not, I don't know that shaping a Bass LE would be considered easy..
Old Sep 19, 2006, 04:02 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
In the house????
I do it outside....
Old Sep 19, 2006, 04:17 PM
Slope Dog
gorgeflyer's Avatar
The Gorge
Joined Mar 2002
[QUOTE=THUREN]I guess it would be fairly easy if you can find the perfect piece of Bass...
QUOTE]
I'm always on the lookout for the perfect piece of Bass!
I will most likely use Goop to attach this. That will give me good grip and still allow the foam to flex a little bit. I do use PU to hold the spars in though.
Old Sep 19, 2006, 10:22 PM
TomFlyer is offline
Find More Posts by TomFlyer
United States, OR, Tualatin
Joined Apr 2005
Pictures?
We would like to see how you do this leading edge.
Tom
TomFlyer is offline Find More Posts by TomFlyer
Old Sep 19, 2006, 11:21 PM
prplgoat is offline
Find More Posts by prplgoat
gas tires and oil
prplgoat's Avatar
malad, idaho
Joined Dec 2004
my buddy ron used a carbon rod on the LE of his crossover. i did the normal tape thing and his crossover kicks mines butt! it is faster has a cool sound and all around flies better!
mine is bounce'able though!!
it is a cool mod,sometimes i kinda wish i had done it too,but not when i smack it!
marty
prplgoat is offline Find More Posts by prplgoat
Old Sep 20, 2006, 01:01 AM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
Isn't that how TFLG does it with his cheap foam cutter? When he overhangs the templates at the LE and TE doesn't he have to rebuild the missing area with wood/whatever?
Boz
[attachment]171417[/attachment]
theBOZman is offline Find More Posts by theBOZman
Ultra flyer - reshape leading edge ? Flyfan Parkflyers 3 Jul 21, 2002 12:05 PM
Ultra Flyer Leading edge very sharp? Flyfan Foamies (Kits) 1 Jul 21, 2002 12:00 PM
Scratchbuild question: leading edge Steph280 Electric Plane Talk 15 Jul 12, 2002 10:59 AM
leading edge radius bearsa Modeling Science 3 Jul 11, 2002 09:05 AM
Question about Zagi leading edge rounding. slowflyer Foamies (Kits) 1 Jul 05, 2001 10:55 PM
