Old Sep 19, 2006, 04:09 AM
Seamaster is offline
Find More Posts by Seamaster
Denmark, Europe
Joined Jun 2005
Foamwing and problems with RC installation
I have bought a used Bonito without RC-equipment, the problem is now to install the servo's in the wings because it's impossible to pull the servocables through the foamwing.
The Bonito wing is a one piece 193 cm wing, foamcore covered with balsa.
Any suggestions to solve this problem?
Regards Claus
Seamaster is offline Find More Posts by Seamaster
Old Sep 19, 2006, 07:18 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Get a piece of string and a vacuum cleaner. Hold onto one end of the string, and use the vacuum to suck the string through (remember to hold onto the other end of the string). Once it's thru, tie the servo lead to the string and use it as a fish to pull it thru.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Sep 20, 2006, 03:50 PM
Denmark, Europe
Joined Jun 2005
Sounds like a good idea, I'll try and see if it will solve the problem.
Thanks.
Claus
Old Sep 20, 2006, 07:58 PM
The Fonz is offline
Find More Posts by The Fonz
The Fonz's Avatar
Joined Dec 2005
Also , if that doesn't work you could tie on a small piece of foam, something smaller than the area you are trying to fish. This gives the vaccuum something with mass to suck. It will work guaranteed. I have been fishing conduit for over 20 years and it never ceases to amaze me the ways some people get wires through things. Just when you thought you seen it all................someone shows you another way
The Fonz
The Fonz is offline Find More Posts by The Fonz
Discussion Any common problems with RC-Tek phantom? RightSkid Mini Helis 21 Aug 08, 2007 12:33 AM
Problems with RC-Direct? pequeajim Vendor Talk 3 Aug 26, 2004 05:32 PM
air travel with rc planes-problems JoeR Electric Plane Talk 21 Jul 09, 2002 04:04 PM
Problems with Icare RC!!!! knight of Ni Vendor Talk 11 May 10, 2002 08:04 PM
Problems with RC MicroFlight Subscription GHarvey Vendor Talk 11 Feb 15, 2002 08:52 AM
