Old Jun 13, 2001, 11:16 PM
bruce ryan is offline
Find More Posts by bruce ryan
USA, WA, Bellevue
Joined Apr 2000
CG on flying wing
hello,
I just flew my scale Blohm& Voss 215 off the slope. On test glides the cg was to far forward so I kept moving it back. By the time
I was done flying I had the cg at 31% mac.(a pic of the bv215 can be seen in my
"documents" at http://y42.briefcase.yahoo.com/ untitled bv2
31% should be way to far back, any ideas?
bruce
[This message has been edited by bruce ryan (edited 06-14-2001).]
bruce ryan is offline Find More Posts by bruce ryan
Old Jun 14, 2001, 05:38 AM
fisher is offline
Find More Posts by fisher
Joined Apr 2001
Perfomance is what counts. If that's where it feels good to you, keep it.
The link isn't working so I can't see it.
does it have extensive fins? That could contribute to the stability.
-fish
[This message has been edited by fisher (edited 06-14-2001).]
fisher is offline Find More Posts by fisher
Old Jun 14, 2001, 08:09 AM
USA, WA, Bellevue
Joined Apr 2000
it took three tries but the pic should work now.
just find it strange to have the cg so far back. the airfoil is a MH 45
bruce
Old Jun 14, 2001, 09:00 AM
berniep1 is offline
Find More Posts by berniep1
Vacaville, CA USA
Joined Nov 2000
I can't get the pictures to work...can you post specifics? Wingspan, airfoil cord root & tip, sweep angle, weight? How much twist (washout)? Do you have the elevons set to positive? By how much?
Bernie
berniep1 is offline Find More Posts by berniep1
Old Jun 14, 2001, 06:03 PM
USA, WA, Bellevue
Joined Apr 2000
Bernie,
try this and then click "my documents"
http://briefcase.yahoo.com/brucexryan
the ws is about 36 " not counting the tips
about 1 to 2 degrees washout(stabs follow tip incidence)
I will need to add some up to the stabs as the plane needed up trim.
maybe 30 degrees sweep.
bruce
Old Jun 14, 2001, 07:44 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I think what you have is a "conventional" wing-tail layout, with a large gap at the horizontal root..
How are you figuring the c.g.?
It does look good...
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jun 15, 2001, 08:49 AM
berniep1 is offline
Vacaville, CA USA
Joined Nov 2000
Well...that's still not enough data.. but I'll give it a shot....let's assume you have a 36" wing with a root and tip cord of about 8" --- using a 25 degree sweep and the MH45 airfoil the CG would end up around 6" (give or take .1")back from the leading edge at the root (meaning: where the two wingpanels meet; not at the fuselage!)
At 30 degree sweep it's around 7" back...hope this helps
BTW: that's just an approximation...you would also have to consider those "add-on" triangles at the inner part of the wing...
Bernie
Old Jun 15, 2001, 11:37 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Well IF you built it 'scale' and I believe you did ....the CG should be just barely behind the point where the rear of the canopy meets the fuse
Bare is offline Find More Posts by Bare
Old Jun 18, 2001, 09:46 AM
cwatters is offline
Find More Posts by cwatters
Somewhere in England
Joined Apr 2001
There is a first class intro to swept and plank style flying wings at Martins site...
http://beadec1.ea.bs.dlr.de/Airfoils/flywing1.htm
Colin
cwatters is offline Find More Posts by cwatters
Old Jun 21, 2001, 07:43 AM
J Cubed is offline
Find More Posts by J Cubed
Bloomington, MN
Joined May 2001
Those are some pretty birds you've got there! I love that EDF!
J^3
J Cubed is offline Find More Posts by J Cubed
Where is the CG on a Flying wing? ecologito Flying Wings 6 Jan 04, 2005 10:31 PM
how to find CG on a flying wing? EKI16 Parkflyers 8 Jan 02, 2004 05:10 PM
location of cg on a flying wing TNTRC Foamies (Kits) 9 Nov 23, 2003 02:42 PM
Dive testing CG on flying wing? DeuceTrinal Foamies (Kits) 1 Oct 17, 2003 03:52 PM
help needed on CG for flying wing model bronco Power Systems 5 Apr 24, 2002 08:12 AM
