Old Sep 18, 2006, 09:08 AM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
52 inch span B25 free plans
Here is a 52 inch span B-25 that you can build for under $70 bucks easy. .(Airframe only, not counting motors ESC's and radio gear.
If you have never built a model with foam and not afraid of a little sanding this is a good one to start on. The sides are relatively flat keeping the sanding to a minimum. The only place you might stumble is getting a good fit between the wings and nacelles. Even then it's just foam, 120 grit really eats this stuff up.
sparks is offline Find More Posts by sparks
Old Sep 18, 2006, 09:12 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Plans
Ok here is the deal. . . .I have to come clean right off. it's not really free plans it's more like free foam cutting patterns and a three view but that's all you need to build this plane.
It's based on a four inch wide fuselage so you can build it with 2 inch blue foam.
A half sheet 4' X 4' is enough to make one plane. A whole sheet of 2 inch blue foam (4' X 8' ) runs about $26.
developments:
My model took 4 oz. of ballast in the nose just behind the gunner.
with the wing incidence set at zero at the root the stab needs 2.5 to 3 degrees of nose down to fly level. E-flight 480's provide more than enough power to fly the model and only pull 20 amps. this makes a three cell 2100 MAH pack useable.
Notice:
the wing span to my model is from tip to tip 53 inches. The wing cores were cut to the point that the tips start to curve ( top View). This does not correspond to the three views .
In other words I cheated a little. After seeing how the model flies the scale layout will work just fine ( 48 inch tip to tip) so stick to it. My next one will.
Old Sep 18, 2006, 09:20 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
plastic parts
The plastic? nose greenhouse windows (2 pieces). cockpit windows, upper turret. observers bubble, side gunners windows, tail gunners bubble, two cowls and the entire flight crew. (6 figures) and the guns under the cockpit. $27 shipped in the US.
this is enough parts to build your favorite model with the exception of the G and H model.
You should note that the panel lines are not formed into the windows.
Normally I do put the lines in my tools but about 10% would find fault with the thickness, width and location of them. Besides this will give you model options.
Drop me an E mail and I'll fill you in on shipping and payment options. parkflyerplastics@att.net
You first timers Say the word and I'll throw in the book "building with foam" and you can save the postage.
Old Sep 18, 2006, 09:21 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
This is going to feel like you walked into a movie a half hour late. Originally I was just going to build this one just for me.
Ron Singer (of the EAM B-17 fame) wanted one too so I cut his while I was doing mine.
Well mine is nearly ready to paint and load up with the flying gear. Ron and the people I fly with has persuaded me to post the model and offer the plastic. Not knowing how well it will fly, I have reluctantly agreed.
My version. . . .
Without the landing gear and radio equipment my model weighs in at 1.5 pound. I'd bet it would fly with a pair of E-flight 450 outrunners but to be safe I'm going with the 480's. The wings are not removable and are covered with one ply of 3/4 oz cloth because I used white beaded foam for the wings. a single sheet of 1/8 light ply connects the wings at the fuselage centerline. the rest of the model has been covered with two ply of .5 oz cloth. I have elected to install functional rudders, ailerons and elevators and flaps just for fun. No retracts, no bomb bay. .
Every time you add a feature the weight goes up . . .Duh.
If I made the model with no glass cloth, landing gear, rudders, or flaps I'd bet it would weigh half at this point.
Ron has elected to sheet his wing, this allows him to skip weight of a spar. This decision was made because he intends to make his wing removable for transport. The down side is he looses space in the fuselage. Ill post his progress as well.
Right now we are facing tail heavy models but time will tell how heavy.
Old Sep 18, 2006, 09:31 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Ron's plane
To cut out the parts for the B-25 you will need a hot wire and patterns / templates.
Construction for both are in the book. The tail feathers have been cut from the 2 inch blue foam at just under 1/2 inch thickness and then cut out. Below you can see that Ron is using balsa as to dress the hinge lines. This adds stiffness and allows ca to be used to attach the hinges.
Old Sep 18, 2006, 09:46 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Gun ship
Ron is going to do the gun ship version so he is not going to use the forward windows.
Not a bad choice. This will hide the battery all the way up front helping the CG sanitation.
Entry for cell replacement will be through a hatch cut around the cockpit plastic. Note the balsa edge to support the hatch.
Old Sep 18, 2006, 10:03 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Nacelles
Ah, the nacelles, bit of a pain but it has to be done.
Start with two blocks of 2 inch foam.
Bond them together with two drops of epoxy applied to the centerline front and back.
Use the template to cut it into a cylinder.
All that's left is to cut the top and side profile and the wire cutting is done.
I have no cutting illustrations to show but it's done like I did the nose to my 757 so I used those photos.. . .Sorry
Put the hot wire away and get out the 90 grit sand paper and start shaping.
This goes fast so when you get close go to 120 grit and finish with 180.
Don't forget to mark the top and bottom.
The photo below shows where Ron has to hollow the rest of the nacelle out with a rotary tool.
Old Sep 18, 2006, 10:10 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Motor mounting
This one is my model. I came up short on the nacelles so I had to make a motor mount block.
A light ply plate is bonded to the nacelle and glass has been folded over to it's edge for additional support. I prefer to use magnets to hold my cowls on.
No screws to mess with and 1/8 inch twist removes it from the model.
The light ply ring inside the cowl makes it rather strong too. I plan to have the air flow through the nacelle and out through the gear door.
Run the wires before the face plate is installed.
Old Sep 21, 2006, 05:55 PM
ron s is offline
Find More Posts by ron s
ron s's Avatar
fort worth
Joined Aug 2005
thanks sparky for posting this build! had a good build day today took more pics hpoe to get them to you soon for posting.
ron s is offline Find More Posts by ron s
Old Sep 21, 2006, 06:17 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Very cool Sparky. Now I know what you've been doing in your spare time
charlie
portablevcb is offline Find More Posts by portablevcb
Old Sep 21, 2006, 10:23 PM
Synwpn is offline
Find More Posts by Synwpn
go fly! no crashes!
Synwpn's Avatar
Honolulu, HI
Joined Jun 2003
Thanks for the templates Keith! I think I'll have to try this one!
Synwpn is offline Find More Posts by Synwpn
Old Sep 22, 2006, 03:40 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Painted
Well My plane is all painted and ready to put the flying equipment in.
Ron's plane is getting the wing saddle installed as well as the battery hatch.
You can see the grooves he cut in the stabilizer to install the rudder cable tubes.
Old Sep 22, 2006, 03:42 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Painted
Forgot my model. . . .
Old Sep 22, 2006, 04:28 PM
newcomer is offline
Find More Posts by newcomer
newcomer's Avatar
central illinois
Joined Aug 2002
Sparks. bought the book - love it.
what are you using to mask the canopy?
david
newcomer is offline Find More Posts by newcomer
Old Sep 22, 2006, 05:40 PM
ron s is offline
ron s's Avatar
fort worth
Joined Aug 2005
newcomer, im using blue seethrough mylar tape to mask the windows.
Discussion 96 inch span House of Balsa plans, build thread, or other help needed. willin Sailplane Talk 33 Jul 20, 2009 08:51 PM
Discussion 48 inch span B-25 free plans sparks Foamies (Scratchbuilt) 1 Oct 17, 2006 02:24 AM
Discussion 48 inch span B-25 free plans. sparks Electric Warbirds 0 Oct 16, 2006 04:51 PM
Get free plans here.... Graham Stabler Parkflyers 5 Jun 29, 2001 05:32 PM
Free plans ? Russell2 Sport Planes 3 May 08, 2001 08:03 AM
