Old Sep 18, 2006, 12:39 AM
Chachin is offline
Find More Posts by Chachin
Powered by ThunderPower
Chachin's Avatar
United States, FL, Cocoa
Joined Sep 2001
Link
Ion-X going strong again - Video
Had a rash of bad luck... first I had problems with stripped gears and damaged secondary stage while trying the Neumotor. Then I screwed up and crashed (tipover) it due to low Rx pack voltage at IRCHA. Now it's all fixed up and dialed in again . This is still my favorite machine in the fleet. Here are a couple of videos from today's flights using the Hacker motor with ProLites and new 690V-blades. Not as powerful, by today's standards, but still loads of fun . Hope you enjoy:
http://www.chachin.rchomepage.com/Io...12-VBlades.zip (21MB)
http://www.chachin.rchomepage.com/Ion-X-0013.wmv (19MB)
Chachin..
PS: Been thinking about trying the Actro motor on 10S... Can the Hacker ESC handle it without burning up??
Chachin is offline Find More Posts by Chachin
Old Sep 18, 2006, 01:13 AM
kogibankole is offline
Find More Posts by kogibankole
Permanently Banned
kogibankole's Avatar
Albuquerque
Joined Nov 2004
wow...i used this same motor on my 550mm bladed quick 16....
kogibankole is offline Find More Posts by kogibankole
Old Sep 18, 2006, 02:05 AM
misskimo is offline
Find More Posts by misskimo
TeamTP,Minicopter,Spartan
misskimo's Avatar
Mississippi 31 years , Now Kotzebue , Alaska 12
Joined Apr 2001
yeh ! yeh it can handle it , you will like the power it has , even on 10s 8000s , I liked it , and throw on some 4600s , and hang on for a 5 min flight ,
Ill watch the video wed when I get home from work , 32 k here ,
Tony
misskimo is offline Find More Posts by misskimo
Old Sep 19, 2006, 11:51 PM
Chachin is offline
Chachin's Avatar
Joined Sep 2001
Hello KB, as long as you use the kevlar wrapped version the motor can handle the Ion fairly well for its size .
Tony, thanks for the info. I remember you guys mentioning cut frames, I believe it was to fit a larger main gear. Is that necessary for a 10S Actro setup?
Chachin..
Old Sep 20, 2006, 12:57 AM
Chachin is offline
Chachin's Avatar
Joined Sep 2001
Added second flight vid.
Chachin..
Old Sep 20, 2006, 02:11 AM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , I think you need to trim off alittle , cant remember , havent change a frame yet , well soon I will , got one at the house all banged up .
I dont have any 2 stage setups , and still have all them 2 stages too , also have a lenher motor I was ganna slap in there , now I bet that gives a NEU a run for its money , Chris made a motor plate for it , but no 2 stage , one good thing with this motor , it has 2 KVs , one for 10s and 1 for HV
Old Sep 20, 2006, 05:44 PM
SMITHB is offline
Find More Posts by SMITHB
FLORIDA
Joined Apr 2005
Carlos i have done alot of flying wiht the Actro and the Hacker on 10s it wokrs really good
Also you only have to cut the frames if you run the fan for the single stage
You might want to wait and see what i got going before you change to single stage
Bobby
SMITHB is offline Find More Posts by SMITHB
Old Sep 20, 2006, 11:15 PM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
yeh , the 32-3 belt drive 12 to 1 on 12s 4600 will rock the house forsure
Old Sep 20, 2006, 11:44 PM
epc2 is offline
Find More Posts by epc2
Miami Fl/Santo.Dgo.
Joined Jun 2004
Bobby
Bobby,
How many flights do you have on the new setup?? , I think you're using some Joker stuff !!
epc2.
epc2 is offline Find More Posts by epc2
Old Sep 21, 2006, 07:50 AM
SMITHB is offline
FLORIDA
Joined Apr 2005
I have about 15 flights Not sure how many Chris has on his yet we have 2 Ions pretty muchh set up identical geared the same way.Iam not having any luck wiht the New tp packs iam waiting on some 6s Evo's to fly should have them hopefully by tomorrow also i want to change the gear ratio alittle as it dont have the pop i like. On a good note the power train is holding together @ the first of the year we were only getting 2 to 4 minute flights on 12s
Bobby
Old Sep 21, 2006, 01:31 PM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , with that setup Bobby , adding pitch will get you the pop , since your running 85 to 90% gov , means you are at around 1900 headspeed ,
I been running 12 degrees for a while now , wanna try 13 with 1900 on the head, the pop comes from 2100 on the head , that means short flight time , that extra drag takes abit of time off the as$ end of the flight ,
off the proto 10s TP 4400s I ran 10 degrees of pitch, wide open , 4 min 15 seconds and the packs was dumped , 10s 3700 , 3m and 40 seconds , DUMPED, almost like autoing when they dump. at 85 to 90 % gov , same setup , 4400s 12 degrees of pitch . you can stretch it to 5 min, but still have the punch with 12 degrees of pitch
Old Sep 22, 2006, 08:10 AM
Chachin is offline
Chachin's Avatar
Joined Sep 2001
Bobby, looking forward to knowing more about the setups you guys are trying. Does it involve the Neumotor??
I'll talk to you later about it.
Chachin..
Download Ion-X demo at KSC - Video Chachin Electric Heli Talk 3 Nov 21, 2006 06:20 PM
T-Rex & Ion-X Video Chachin Mini Helis 26 May 18, 2005 11:58 PM
First Ion-X Video Chachin Electric Heli Talk 17 Apr 08, 2005 08:45 PM
Video - Lawrend's Ion-X flown by Gary Wright Chachin Electric Heli Talk 16 Jan 06, 2005 09:49 AM
Xcell Ion X video misskimo Electric Heli Talk 8 Aug 09, 2004 07:08 PM
