Old Sep 17, 2006, 06:59 PM
Teufel-Hundin is offline
Find More Posts by Teufel-Hundin
United States, FL, Port Orange
Joined Mar 2006
How do you think this plane will perform?
How do you think this plane:
http://www.3dhobbyshop.com/detail.as...1745&Source=fr
Seagull EP Extra 300
Wing Span: 43 in (109 cm)
Overall Length: 38.4 in (97.5cm)
Wing Area: 367 sq in (23.7 sq dm)
Flying Weight: 28-32 oz (792-905 g)
Motor Size: Park 450 to Park 480 Outrunner (EFLM1510)
Prop Size: 10x4.7 electric Recommended w/480 outrunner
Would perform with this motor on 3s1p Li-Poly
http://www.himodel.com/en/rc_hobby/electric_1905.php
No. Of cells:2-3 Li-Poly
RPM/V:800 RMP/V
Max. efficiency:82%
Max. efficiency current:8A (>75%)
No load current / 10 V:0,5 A
Current capacity:17A/60 s
Internal Resistance:116 mohm
Dimensions:22x15 mm
Shaft diameter: 3 mm
Weight:59 g
Recomended model weight: 300 - 900 g
Recomended prop without gearbox:APC 10X5 / APC 11X5.5APC / 10X4.7(SLOW)
Model BL2215/25
Cell Count 3S Li-Po
RPM/V 800
Prop 11X7
RPM 6300
Current 18A
Thrust 1046g/2.31lb
Teufel-Hundin is offline Find More Posts by Teufel-Hundin
Old Sep 17, 2006, 07:08 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I haven't tested this motor yet but having tested others in the range I imagine the current draw etc is optimistic. Also, I just put the 6300rpm with an 11x7 APC E into our calculator
(http://www.gobrushless.com/testing/t...=Calculate+Now
and , even if it does manage the rpm with that prop, it gets nowhere near as much thrust as the specs you posted would suggest - 29oz is well short of the 37oz they suggest.
That said, it could well be enough for your particular airplane.
Wait a week or two and I hope to have test stand data for this motor.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 17, 2006, 07:18 PM
Joined Mar 2006
I am looking for greater than 1/1 for true vertical on this plane.
Would this be better?
RPM/V:1260 RMP/V
Max. efficiency:82%
Max. efficiency current: 13 A (>75%)
Current capacity:22 A/60 s
Dimensions:22x15 mm
Shaft diameter:3 mm
Weight:59 g
Or do you have a recomendation in this price range.
Or perhaps going to a 11x4.7
Old Sep 17, 2006, 08:11 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Again, I just don't know yet - I have one of these 2215/20's coming. They look good on paper, but BEC has test run some of them and not been impressed.
Old Sep 18, 2006, 07:47 AM
Joined Mar 2006
Hmmmmm
Old Nov 01, 2006, 06:45 PM
makarov380 is offline
Find More Posts by makarov380
makarov380's Avatar
Grapevine,Texas
Joined Mar 2005
Well the motor looks interesting. I don't if Dr. Kiwi has tested it yet, but I wired mine up quickly with a GWS 12x8HD it pulled 16A on a tired 3S and ~10A with a 10x8HD. I will get some RPM readings from it tomorrow, but it was pulling very hard with the 12x8. The amps did really start to spike, either, so the motor doesn't appear to be struggling too bad with the 12" prop.
I want to use it on a hotrod Formosa. It will be more than adequate for that. It might even fly my GenericStik that weighs in @ 28oz
makarov380 is offline Find More Posts by makarov380
Question Do You Think This Will Last For Even One Flight? Kenny Sharp Flying Wings 16 Feb 12, 2007 04:07 PM
How much power do you think this will use? ch2s Batteries and Chargers 9 Jul 10, 2005 10:12 AM
Hmm how do you think a Neu will work in a Zoom guys? wildstallion Mini Helis 8 Mar 24, 2005 09:37 PM
Do you think this A10 will fly? Mike Hall Foamies (Kits) 13 Sep 09, 2002 11:20 AM
Do you think this will work?????? Foam bashing hehe Dauntae Foamies (Kits) 4 Oct 13, 2001 08:07 PM
