Old Sep 17, 2006, 05:13 PM
Allen D is offline
Find More Posts by Allen D
Model Builder
Joined Apr 2006
Low voltage Speed Control???
Are there any electronic speed controls out there that will run at 1.5 to 3 Volts?
Allen D.
Allen D is offline Find More Posts by Allen D
Old Sep 19, 2006, 04:08 PM
Tachikaze is offline
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
What are you planing on placing it into?
I have been working on the Skippers Launch for the LST 150, which is only 7" long. I picked up a R/C mouse ( like a zipzap car) a real cheap thing. Remove the board in it and I now have a ESC/Reciever for the boat. It runs on one cell, that is charged by two AA cells.
Tachikaze is offline Find More Posts by Tachikaze
Old Sep 22, 2006, 05:12 PM
wingnut163 is offline
Find More Posts by wingnut163
wingnut163's Avatar
Newburgh New York
Joined May 2005
Esp
allen;
why not use a servo. there you will have the motor and speed control. i put that in a revel long beach tug, 8" long,
wingnut163 is offline Find More Posts by wingnut163
Old Sep 23, 2006, 01:54 PM
Allen D is offline
Model Builder
Joined Apr 2006
A friend has a small fireboat that used to run off one cell battery and I believe it had an old contact type of esc (like a dumas one-but smaller) it no longer works. Will a servo work in reverse as well??
Old Sep 24, 2006, 08:35 AM
wingnut163's Avatar
Newburgh New York
Joined May 2005
yes it will work in reverse. you need to do some mods to the servo if you plan on leaving it in the case. most times it is easer to take it apart, then you can put things were you want for space.
Is there a limit on voltage in Speed Control or motor? jhicks Power Systems 1 Feb 05, 2005 09:05 PM
On/Off Speed Controllers w/low voltage cut off??? InTheLift Power Systems 5 Dec 19, 2004 12:43 AM
Question LIPO min voltage and speed control question pumi Power Systems 7 Apr 15, 2004 04:42 PM
Speed control voltage R. Roger Power Systems 2 Oct 30, 2002 01:17 AM
Tech MC-Air 60 speed control Theuns Electric Plane Talk 0 May 29, 2001 02:28 PM
