Old Sep 17, 2006, 11:21 AM
fudi50 is offline
Find More Posts by fudi50
Modesto Calfornia
Joined Feb 2004
hanger 9 Sopwith Camel
Can any one point me in the right direction. I have just purchased a Hanger 9 Sopwith Camel 60" span weight approx 7lbs.
I have an Aveox 46/43/2 brushless motor [pushes my 1/4 scale boat about 20mph boat weighs 30lbs] it has a 99amp W/C speed controller I have 2 x 6 cell 3700 mha nMh batteries.
I also have a Mega 7 brushed motor never used.
An Astro 40 geared cobalt with a 35amp Pegasus speed controller unused.
Questions are which plant to use and what size prop
fudi50 is offline Find More Posts by fudi50
Old Sep 17, 2006, 07:55 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
OH I'd definietly use the astro geared 40...
http://www.astroflight.com/store/sto...L442ocbsc5n9d5
for props and cell counts suitable for it. For a camel you porobably want to over prop it a bit and use a coarse prop..I am simming up a 60" albatros, and hope to get away with not much over 3lb, and use an astro 15 geared. Something like a 20" prop is scaleish, but thats a bit impractical. Say a 15x10 on that 40 of yours.
Then use a 4s LIPO pack to keep the amps and weight down. Should pull around 35A or so..about 250 Watts nicely matched..enough to fly a 5lb Camel realistically I'd say.
Old Oct 01, 2006, 10:00 PM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
I'd agree that the Astro 40G is the best choice of what you have listed, but you're going to need more like 550-600w to fly like it should, assuming a AUW of 7.5-ish to 8 lb.
It would help if you could list the out-of-the-box weight of the airframe, so I can plug the numbers into Motocalc for the Astro. I used an empty weight of 88 oz. to play around with some numbers for my own intended brushless setup (haven't bought the plane yet), but that 88 oz. is only a guess.
If you could weigh the plane before you start putting any gear in it, I can give you a Motocalc recommendation for prop and battery selection, for use with the Astro.
Rick
ElectRick is offline Find More Posts by ElectRick
Old Oct 02, 2006, 02:27 AM
fudi50 is offline
Modesto Calfornia
Joined Feb 2004
just weighed the plane 8lbs 7 oz gross I'll guess nett would be 7lbs. I tried flying with the A 40 G 13x8 prop 2 x 6 cell 3700 mah nmh could not get off tyhe ground used 15 x 6 just managed to get off the ground for about 20ft. Would I do better with a 17" prop and two 2500 Li Poly.
Can you answer this question I was given a Midwest kit partialy built a Extra 300S I have now finished it. Specs are 80" W/Area 1162 servos giant scale Gas power 2.2 - 2.8 [5] dry weight is 7 1/2 lbs . I have and Aveox 46/43/16 brushless would this be enough power if so what batteries would I needr
Old Oct 02, 2006, 09:48 AM
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
Sounds like you need more RPM (thrust) out of the motor than 14.4v of NiMH cells are giving you.
Going to a 5S or even a 6S 4400mah or so LiPo would give a lot better thrust, and reduce weight a good bit at the same time. The pack voltage under load would be better too. Should make a world of difference.
Rick
Old Oct 02, 2006, 05:14 PM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
You should be running that motor on 18 cells, (5 or 6 Lipos). Take a look at the Astro website for prop sizes depending on your voltage.
If you tried with 12 X 3700 cells, they weigh about 25oz. The Astro 40 geared weighs about 15 oz. Add about 10 oz. for a typical radio installation and your equipment weight is 50 o. That makes the airframe come out at about 85oz. - (pretty close Rick!)
Try more voltage - Lipos if you can, round cells if you need the noseweight.
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
For Sale Hanger 9 Sopwith Camel fudi50 Aircraft - Electric - Airplanes (FS/W) 0 Dec 19, 2006 01:51 PM
Discussion Hangar 9 Sopwith Camel !!! tailskid2 Fuel Warbirds 32 Sep 30, 2006 02:51 PM
Discussion hanger 9 Sopwith Camel fudi50 Electric Motor Design and Construction 1 Sep 15, 2006 10:02 PM
Build Log New AerodromeRC 1/9 Sopwith Camel sleonard Scale Kit/Scratch Built 15 Sep 14, 2006 06:22 PM
New Product Hangar 9 Sopwith Camel !!! P-51C Scale Kit/Scratch Built 4 Jul 31, 2006 01:03 PM
