Old Sep 15, 2006, 07:16 PM
john-rcg is offline
Find More Posts by john-rcg
o___O
NY
Joined Sep 2004
how do i check the individual voltage of 1 cell with a multimeter??
how do i check the voltage of the cells 1 by 1 with a multimeter??
http://www.harborfreight.com/cpi/cta...emnumber=90939
people told me to use the balancing tab on my battery, but the balancing tab has 4 wires/holes and the multimeter (see link) only has 2 medal pins sticking out. how do i use it ???
please help!!
john-rcg is offline Find More Posts by john-rcg
Old Sep 15, 2006, 07:22 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
I sharpened my test probes to measure the exposed pins on side of balance connector, adjacent pins should read ~ 3.7-4.2V
hall woo is offline Find More Posts by hall woo
Old Sep 15, 2006, 07:30 PM
john-rcg is offline
o___O
NY
Joined Sep 2004
huh?????????
there is no pin on the side of the balancing connector....i am using a thunder power 1320.
Old Sep 15, 2006, 07:31 PM
john-rcg is offline
o___O
NY
Joined Sep 2004
can i just use one test probe and shouve it in one hole in the balancing connector at a time? then do the rest?
thanks
Old Sep 15, 2006, 07:32 PM
john-rcg is offline
o___O
NY
Joined Sep 2004
oh yeah, and also how do those $2.99 HF multimeters (u have 4) work?
john-rcg is offline
o___O
NY
Joined Sep 2004
thanks
Old Sep 15, 2006, 08:16 PM
john-rcg is offline
o___O
NY
Joined Sep 2004
please help
Old Sep 15, 2006, 08:33 PM
Santini is offline
Find More Posts by Santini
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
Stop, please. Google, "how to use a multimeter" or similar. Before you ruin your meter, your battery or do worse. Also see the commonsenserc.com site, educational section for pack wiring. This will tell you the leads to test. Trust me, first, understand what to do before you start poking with a multimeter.
Santini is offline Find More Posts by Santini
Old Sep 15, 2006, 09:29 PM
john-rcg is offline
o___O
NY
Joined Sep 2004
ok.
EDIT:...common sense's pack wiring is for nicads
and google does not give me the results i need
Old Sep 15, 2006, 09:47 PM
Santini is offline
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
Look again at the commonsense as the wiring is for three cells (lipo).
http://www.commonsenserc.com/page.ph...g_diagram.html
In this diagram, testing black and blue gives you first cell; blue and yellow, second cell; yellow and red gives you third; black and red the whole pack. more:
http://www.rcgroups.com/forums/showthread.php?t=569930
But read about multimeters and don't touch the tips and short the pack out. You kind of need to study a bit and search. That's the only way. The answer was only several posts below your post.
How do I check voltage of individual LiPo cells? mjgillen Batteries and Chargers 1 Oct 21, 2005 02:27 PM
How do I check voltage? air4se Parkflyers 6 Jan 19, 2004 10:31 AM
How do I fix my Li Poly cell? :( flytowner Scratchbuilt Indoor and Micro Models 15 Oct 15, 2002 03:43 AM
How do I check Amp draw? FX1SUB Parkflyers 6 Sep 06, 2002 04:00 PM
How do you get out of the seven cell trap? jyoder111 Electric Plane Talk 16 May 20, 2001 08:02 PM
