Old Sep 14, 2006, 08:53 PM
camxbad is offline
Find More Posts by camxbad
Joined Jun 2004
Help!
How to measure a charge in a lipo pack
The question sounds like commonsense, and maybe it is, but I am confused. It all starts with a 3 cell 1300 11.1 volt pack that I can't get to charge on my DN Power balancing charger. I know my charger has a safe guard built in to NOT charge if a cell is below 2.7volts. How can I tell this on my 3 cell pack? I have a volt meter, and when I measure the overall of the pack using the plug that I attach to my speed controller I get 9.82 volts. Assuming this is divided out my all 3 cells I would have roughly 3.27 per cell. Could this just be 2 highly charged cells and one bad one? Either way the pack has a balancing plug attached to it. How do I read in each cell independently? What does the red,blue,yellow, and black cables mean?
End the end this is a new pack that has only been bench tested, and I want to charge it up! Help!
Thanks (newbie converting from brush/nimh to brusheless/lipo)
camxbad is offline Find More Posts by camxbad
Old Sep 14, 2006, 09:19 PM
Santini is offline
Find More Posts by Santini
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
Since you mention common sense, look at this info on wiring of the pack:
http://www.commonsenserc.com/page.ph...2c7bce9ae3b5d2
Santini is offline Find More Posts by Santini
Old Sep 14, 2006, 09:39 PM
camxbad is offline
Joined Jun 2004
Interesting...never seen that part of their site before. So, blue and black are the positive/negative for cell one. When I hit it against my volt meter I am getting around 6.49? Is this because it is trying to pull voltage from a neighboring cell?
Old Sep 14, 2006, 10:01 PM
xorbe is offline
Find More Posts by xorbe
so i rewired it...
xorbe's Avatar
Mountain View CA USA
Joined Jun 2006
Well usually red is at the positive terminal and black at the far negative terminal of course. Your blue-to-black is obviously measuring two cells, which means those two are 3.25V each or so. (Wire colors change... always best to figure out how your battery is really wired.)
So what's blue-to-red (the other cell), and yellow-to-blue, and black-to-yellow?
xorbe is offline Find More Posts by xorbe
Old Sep 15, 2006, 11:37 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
All Balance Leads R the Same
one side blk or red colored is either + or -, the adjacent lead and COMMON will read 3.7, 7.4. and 11.1 on the last lead, there is always 3.7V between any two adjacent leads
important thing to remember is to always remember to use the proper reversing adaptor which is supplied with DN Power 3S 2150 15C packs
hall woo is offline Find More Posts by hall woo
Old Sep 15, 2006, 11:39 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Different vedors use different colors .
http://www.rcgroups.com/forums/showp...64&postcount=6
Old Sep 15, 2006, 12:10 PM
hall woo is offline
Permanently Banned
Joined May 2003
amazing how some MFRs can't follow a simple color code black=0, common-0v , brown =cell 1-3.7V, red=cell 2-7.7v, orange=cell 3-11.1v, yellow=cell 4-14.8v, green= cell 5-18.5v, blue = cell 6-22.2v
maybe they should GO BACK TO SCHOOL OR SELL HOT DOGS
Old Sep 15, 2006, 12:21 PM
xorbe is offline
so i rewired it...
xorbe's Avatar
Joined Jun 2006
Back to school special, buy 2 batteries get a hotdog half off?
Old Sep 15, 2006, 12:43 PM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
Hi camxbad,
So, if you have 6.49v for two cells the third cell must be 9.82v - 6.49 = 3.33v. I have found that if you measure the adjacent terminals on most balance taps, it will give you the indivdual cell charge.
I'm not sure if this is recomended but it worked for me on one battery pack that I had mistakenly left plugged in on one of my planes. It went below the minimum that the charger would accept. What I did was to put the charger on NiCad charge for a few seconds until it brought up the pack voltage enough for the charger to allow it to charge as a lipo. Like I said, it only took a few seconds to achieve this. I then switched the charger back to LiPo and it charged as normal. I haven't had any problems with that pack so for but it could be that I'm lucky. IT was a fairly new pack.
Blessings, Terry
still4given is offline Find More Posts by still4given
Old Sep 16, 2006, 11:06 AM
camxbad is offline
Joined Jun 2004
Great advice on figuring out the charge!
Hall Woo was the winner though....I wasn't using the supplied reversing cable with the DN charger....hooked it up and wam! working!
Thanks again for the advice
-Cam
how long can you leave a charge in a lipo ? mhale71 Batteries and Chargers 11 Mar 02, 2005 01:36 PM
Help? How fast to charge new Nicad pack? duganderson Batteries and Chargers 0 Sep 12, 2003 10:35 PM
How long to charge new LiPo's genenjr420 Batteries and Chargers 4 Apr 25, 2003 07:16 PM
How Do I measure resistance in a battery pack? Rob0101 Batteries and Chargers 8 Oct 24, 2002 02:52 PM
How to measure wingspan in a blended fuselage? razzor7 Electric Ducted Fan Jet Talk 12 Jun 07, 2001 06:32 PM
