Old Sep 13, 2006, 10:49 PM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Cool
What to extend? Motor wires or Battery wires?
I've got a new twin motor plane coming soon and I know that I'm going to have to extend the wires on my 2 thunderbird 18 speed controllers to make sure that everything can contact. If I have to extend either the motor or the battery wires which ones should I extend. I have read different things all over the place.
L0stS0ul is offline Find More Posts by L0stS0ul
Old Sep 15, 2006, 03:17 PM
vpersiani is offline
Find More Posts by vpersiani
Creteil, France
Joined Nov 2003
I would say that you should extend battery wires because motor wires are driven in PWM (pulses) and therefore will generate high noise level if too long.
My $0.02
vpersiani is offline Find More Posts by vpersiani
Old Sep 16, 2006, 09:37 PM
diver don is offline
Find More Posts by diver don
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
Check out Issue #3 of the Castle Scribe above.
Joe talks about twin setups and his final statement is to run both ESC's of a common battery source (very important).
That being said it would be the battery wires that should be extended.( common battery pack in the fuselage tied into the two or more motors) BUT!
Joe has also said that long battery wires could cause voltage spikes that could blow up the ESC's.
So the definite answer is WHO THE HELL KNOWS?
Hopefully some one from Castle will chime in and give us a definitive answer once and for all.
DD
diver don is offline Find More Posts by diver don
Old Sep 17, 2006, 02:39 AM
myk is offline
myk
Find More Posts by myk
myk
myk's Avatar
Lake Sawyer, Washington
Joined Jul 2003
http://www.rcgroups.com/forums/showthread.php?t=569212
myk is offline Find More Posts by myk
Old Sep 17, 2006, 07:36 AM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
How about someone from Castle piping in on this issue?
Nethole is offline Find More Posts by Nethole
Old Sep 17, 2006, 12:32 PM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Think that most of the guys from Castle are up at NEAT.
I'm not looking for a response from them until the first of the week.
DD
Old Sep 17, 2006, 09:59 PM
Joe Ford is offline
Find More Posts by Joe Ford
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Extend the wires on the motor side.
Joe Ford is offline Find More Posts by Joe Ford
Old Sep 17, 2006, 10:37 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
Yup...works for me...on the Pondside there was simply NO CHOICE as the AXI motor is about 6 inches above the fuselage and the esc is under a hatch so the motor wires were lengthened four inches so the connections would be under the hatch as well.
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Sep 18, 2006, 01:32 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Joe,
Thanks for the reply.
Do you have a recommendation for the max length for battery wires in general.
Don
Old Sep 18, 2006, 01:35 AM
Joe Ford is offline
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
We recommend a maximum combined length of 12" between the ESC and battery.
Old Sep 18, 2006, 01:49 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Thanks Joe.
What does "combined length" mean?
Did you get over to NEAT?
Don
Old Sep 18, 2006, 01:59 AM
Joe Ford is offline
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
No, unfortunately. Maybe next year. Shawn and Lee represented us this year. Lucky dogs!!! Can't wait to see the pictures and videos they bring back...I really hope Lee brought his 8mp digital SLR camera and snapped a bunch of pics. Combined length meaning the wire provided on the controller and the wire on the battery combined should not be more than 12".
Old Sep 18, 2006, 02:12 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Thank you Sir.
What are you doing up this time of the morning.
I thought I was the nut in the area.
Yea,
I had jury duty , so I got screwed this year, but I WILL be there next year.
Just call me "Hang em high Don".
Have a good one,
Don
Old Sep 18, 2006, 08:58 AM
L0stS0ul is offline
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Thanks for the info Joe,
What about the max length from the ESC to the Motor. Since that's the one I'll be increasing What should be the max length for each motor wire?
Thanks again.
Old Sep 18, 2006, 10:27 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
LS,
What plane are you waiting for?
DD
Discussion extend motor or battery wires to esc? carl rich Power Systems 1 Jan 13, 2007 10:22 PM
Question EDF Gurus, do we want shorter motor wire or battery wire? shschon Electric Ducted Fan Jet Talk 11 Jan 01, 2006 09:52 AM
What prop, motor, gearbox, ESC, battery setup for the Formosa? Crazyrcer Foamies (Kits) 14 Oct 03, 2004 12:39 PM
long motor leads, or battery wires? Phreakish Power Systems 19 Sep 21, 2004 08:48 PM
What kill a motor, volts or Amp? Magna Electric Plane Talk 3 May 29, 2002 09:05 PM
