Closed Thread
Old Sep 13, 2006, 09:47 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
ESky Belt CP BareBones build and setup....
I just got a new E-Sky Belt CP from HeliDirect... Steve is a great guy to deal with.... and they have a great selection of heli stuff. (spare parts too, a major plus in my books) Anyhoo this is an ARTF bare bones heli. It is mostly assembled in the box. The heli comes complete with woodies and plastic tail blades. No Motor is included.
Everything looks good, the linkages are smooth, there's even ball links on the servo side of the linkages...Nice touch.
The landing gear comes with the little rubber "feet" already in place on the skids another nice touch that ESky added those..
Electronics:
Servos: Hitek HS55s on cyclic, Futaba S3108 on the tail.
The motor is a HeliMax HMXG1001 Brushless 2580KV inrunner.
I'll be using a Castle Creations Thunderbird 18 ESC
For the RX I'm going to use a Hitek HS05S and for a gyro a GWS PG-03
I want to keep the heli avionics on a low budget and lightweight and see just what kind of performance I can get out of this heli using a decent motor for some basic aerobatic flight.
More to come.....
Ken
kdill2160 is offline Find More Posts by kdill2160
Old Sep 13, 2006, 10:29 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Since I had to count them....140 tooth main gear is stock....now to figure out the pinion and if it will fit.....If not, need to find a different motor....no problem. I'll find the perfect fit for this plastic fantastic(as I like to call em)..... I say it's an awesome heli for 108.00. With 215mm blades and 5mm main shaft.....hmmmm what other parts will fit this main shaft......T-REX and many others I'm sure.....
Old Sep 13, 2006, 10:30 PM
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
looks very nice more pictures
L0stS0ul is offline Find More Posts by L0stS0ul
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
You asked for it..... here they come....
Old Sep 13, 2006, 11:16 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
You Got It!!!
What's that more you say? Ok......
Ken
Old Sep 13, 2006, 11:25 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Check this out......
The designer must have had my favorite lipo in his hands when he designed this heli....THUNDER POWER 1320 3S baby! Fits like a glove.....
Gotta love it..... More To Come....
Ken
Old Sep 14, 2006, 12:34 AM
Isaiah 40:31
Rare Bear's Avatar
United States, CA, Lodi
Joined Mar 2006
Keep it comin', Ken!!!
Quick question, though; this heli is looking quite a bit more complex than my humble Esky King - are the instructions up to snuff when it comes to setting this bird up, or are guys like me going to be lost without hope? My King manual was awful - left a lot of guesswork; I'm praying this isn't the case, because if so, I'm in a lot of trouble!!
One other question: I have a DN 2150 LiPo on order with the dimensions of 23mm x 34mm x 100mm - will this work? I sure hope so!!
God bless - "Rare"
Rare Bear is offline Find More Posts by Rare Bear
Old Sep 14, 2006, 01:04 AM
Joined Nov 2005
Coooooooool!!!
SkyBooger is offline Find More Posts by SkyBooger
Old Sep 14, 2006, 06:28 AM
Hong Kong
Joined May 2004
I will have one of this on order from the mainland where it was produced. I believe this is a 400 size heli which I think the TP 1320 is a bit under-powered. Even for the King I am using a 1500 mah Lipo for running my 400TH outrunner. Please post your flying report once ready.
DWKN is offline Find More Posts by DWKN
Old Sep 14, 2006, 07:30 AM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
The manual is OK, the heli is an ARTF, so not much assembly is needed. The exploded views are great, as well as complete parts listing w/part numbers. The assembly portion of the manual is very good as well(if it was a kit, all the information for assembly is there). Unfortunately the setup portion of the manual leaves much to be desired....Link lengths are provided as well as basic electronics setup ie:which servo into which channnel etc....but that's about all that is covered in the setup portion of the manual.
Old Sep 14, 2006, 07:36 AM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
I think I'm going to return this HeliMax motor and find a better suited motor for this heli.....(read that less expensive) The motor I found only has a KV of 2580, I want to find a motor close to 3800KV or near there... that way i can use some pinions I have available to me.
Old Sep 14, 2006, 07:57 AM
Taking a break from RC to ride
Bud Morrison's Avatar
Lancaster Pa
Joined Jun 2003
What for pinion would that motor need ?
Bud Morrison is offline Find More Posts by Bud Morrison
Old Sep 14, 2006, 08:04 AM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
With the HeliMax 2580KV motor for approx 2300 Head speed......14 tooth pinion with a 11.1 VDC 3S lipo, figuring 80%efficiency.......
Old Sep 14, 2006, 08:37 AM
Joined Sep 2006
reciever hookups for cp belt
Great pics, do you have pics of where each servo gets connected to the receiver.
rcflyer1960 is offline Find More Posts by rcflyer1960
Old Sep 14, 2006, 08:55 AM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
The requested "Beauty" Pics.......
Coming up soon......I'll point the individual servos out in the pics.... Its pretty easy to figure out.....it's CCPM with mechanical linkages to the servos instead of direct connect.
I'm kinda hosed on the build for a bit...I have no suitable batteries and I need to swap the motor I purchased for one closer to specs. Somewhere around 3800kv or so....
Enjoy..... Ken
Closed Thread
Help! HELP! Esky belt cp setup scootercp2 Mini Helis 12 Oct 09, 2011 04:20 PM
Build Log Esky Belt CP - Beginner's Build Rare Bear Mini Helis 132 Aug 07, 2009 01:51 PM
Discussion Esky Belt-CP fx20v Micro Helis 11 Mar 30, 2008 02:46 PM
Help! ESky HB2 CP and Hitec Radio Setup KidNovak Micro Helis 2 Mar 16, 2008 11:43 AM
Sold New Barebones Esky Belt CP Bud Morrison Aircraft - Electric - Helis (FS/W) 0 Oct 13, 2006 09:39 AM
