Old Sep 12, 2006, 03:42 PM
kdill2160 is offline
Find More Posts by kdill2160
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Build Log
LA Heli MaxiR Standard Kit Full Build Thread... Lots Of Photos and Full Text
Here I go.......
My Standard MaxiR kit arrived today from Pete at ElektroRc.com. Great place to do business with, Pete's a great guy and cares about his customers. Here's a pic of the kit box along with the upgrades I plan on installing. The upgrades include:
Aluminum Swashplate (silver)
Aluminum Rotor Head (silver)
Auto-Rotation Gear
Carbon Fiber 3D Paddles/Short Flybar
Carbon Fiber Main Blades
Carbon Fiber Tail Blades
Additionally I'll be installing one extra bearing in the tail boom, this requires the purchase of part # Y0424. These are small plastic "cups" which adapt the bearings OD to the ID of the tail boom.
Here's a pic of the kit box and upgrade parts:
BTW: I Purchase all of my kits done in my reviews(so far) as well as upgrade parts. No freebies here.
DISCLAIMER: This thread documents how I build MY heli. If you find the information here useful that's great. But I assume no liability for anyone else or their heli or any other aspect of their lives that chooses to follow this thread as an instruction manual. Build and fly your heli's at your own risk. And always fly safely.
Ken
kdill2160 is offline Find More Posts by kdill2160
Old Sep 12, 2006, 03:47 PM
truthunter is offline
Find More Posts by truthunter
MaxiR SE~E620SE
truthunter's Avatar
Campbell Hall, NY
Joined Jan 2005
Hey Ken,
Is this the one your going to use with the fuse?
truthunter is offline Find More Posts by truthunter
Old Sep 12, 2006, 04:28 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Yes it is....
hey how's it going???? LTNS
Old Sep 12, 2006, 04:31 PM
trashmanf is offline
Find More Posts by trashmanf
SCAMMERS WELCOME!!!!!!!!!
trashmanf's Avatar
Kent, WA
Joined Dec 2003
Ken
Although I believe MJP stopped making them, you should try and get your hands on a carbon frame set. Pete was able to hook me up a carbon base plate my first crash, even though they were sold out on the site. check with glen also, those CF frames look great on this thing! can't wait to see the finished product!!!
Fletcher
trashmanf is offline Find More Posts by trashmanf
Old Sep 12, 2006, 04:39 PM
MaxiR SE~E620SE
truthunter's Avatar
Campbell Hall, NY
Joined Jan 2005
Why use carbon frame if it's only going to be covered by the fuse?
MJP does not make the carbon frames anymore but you can get the LA Heli ones now... unfortunately I got the last set Pete had yesterday I would assume he will be getting another set in on the next order from LA though.
Old Sep 12, 2006, 04:54 PM
Mochaboy is online now
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
What's this fuse you speak of?
<edit>
oooohhh
"fuse"-lage
<-- dum dum
Mochaboy is online now Find More Posts by Mochaboy
Old Sep 12, 2006, 04:56 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Frame assembly Part 1.......
Part one consists mainly of installing the two main shaft bearings in the Upper and Lower Main Shaft Housings, and assembly of the Battery Holder Plate and the small white Battery Plate Clips which secure the Battery Holder Plate to the Undercarriage Rods on the front of the frame. The other thing you do in step one is install the Swashplate Lead(anti-rotation device).
For each step that requires installing bearings, I set the bearings for that step on a folded piece of paper towel and put one drop of tri-flow oil on each bearing. At the same time I check for bad bearings, if a bearing is even slightly gritty feeling, REPLACE IT! A bad bearing will give you nothing but problems.
NOTE: Since I'm installing the metal swashplate upgrade, the Swashplate Lead Pin is not installed in this step of my build, the metal swashplate uses a different anti-rotation device: Cyclic Plate Guide which is secured with a screw.
Here's a pic of the parts needed in step one of the build:
Ken
Old Sep 12, 2006, 04:57 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
It's a really nice Fibre Glass fuselage, somewhat FAI style, very sleek....I'll post a pic in a few
Ken
Old Sep 12, 2006, 05:12 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Pics of the Fuselage......
Ask and you shall receive...
There ya go...
Old Sep 12, 2006, 05:18 PM
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Yep keep em coming...
Creosote is offline
Find More Posts by Creosote
Blade CP/MaxiR SE
Mississauga, Canada
Joined Jul 2006
They certainly are!
Creosote.
Creosote is offline Find More Posts by Creosote
Old Sep 12, 2006, 05:23 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Step one completed.....
This is what you should have after completing step one.......
Coming up...the start of the frame assembly.....
Ken
Old Sep 12, 2006, 05:25 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
The easiest way to install the small white Battery Plate Clips is to grasp them with a GOOD pair of needle nose pliers, squeeze the open end together and push them into the openings in the Battery Holder Plate....open end first
Ken
Old Sep 12, 2006, 06:15 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Frame Assembly Step two......starting on the actual frame....
Here's a pic of the parts you'll be using in step two. Mostly you'll be working with the right side frame plate, installing the Undercarriage Triangles, Servo Holders and Upper and Lower Main Shaft Housings. Leave the main shaft housing screws loose until you have the main shaft in place and aligned properly. You also need to install the two Electronics Plates.....
In the next post I'll show the completed step two.
Old Sep 12, 2006, 07:17 PM
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Frame Assembly Steps One & two completed.....
Combining the sub-assemblies from step one and the parts for step two you should end up with this........ As I stated before; leave the Upper and Lower Main Shaft Housing screws loose for now. I'll tighten them up after the main shaft is installed and aligned. Here's a couple pics after step two of the frame assembly is completed.....
Ken
Cathode's Mooney - The short kit build thread. TheLost Parkflyers 269 Nov 03, 2011 09:58 AM
Mini-Review Instant RC "Cutlass" Kit, Beta Build Thread LBMiller5 Foamies (Kits) 20 Oct 19, 2009 04:49 PM
Build Log Roxxter 11 Full Build Thread....... kdill2160 Mini Helis 118 Dec 09, 2006 05:22 PM
Poll To be or not to be.....A full LA Heli MaxiR build & reveiw kdill2160 Micro Helis 29 Sep 09, 2006 05:33 PM
Where should I post my kit-build thread? Gerald Electric Plane Talk 11 Jan 15, 2004 11:57 AM
