Old Sep 12, 2006, 04:11 AM
alessio70
alessio70
Guest
n/a Posts
RC Joystick NG^2 (DIY RC to USB interface)
for those who are interested in our little project of an RC to USB
interface...
- from firmware version 3.2.0 the interface become a full speed USB
device to get around constraints on speed and report size imposed for
low speed devices by USB specifications; this means that at last we can
have more proportional axes per joystick without loss in resolution: the
current version implement two joysticks with 8 proportional axes each
(up to about 5000 points resolution each) and 8 buttons for a total of
16 proportional axes and 16 buttons (32 controls). Anyway the
traditional low speed interface firmware binary with 4 axes per joystick
is still available inside the software package and is compilable by just
setting a define; polling interval for interrupt transfer is now set to
5 ms (and could also be set to 1ms) to minimize input latency. The new
version does NOT need any hardware mod... only firmware changes.
a summary of the other features:
- smd (4x2cm) or through hole (6.5x2.5cm) PCB and very few components
- uses the new chips from microchip 18f2455/2550 that have a flash
program and data eeprom and then are programmable more than once (useful
for programming firmware updates available on our site)
- assignments of channels and joystick controls are configurable by
editing a txt file configuration and programming it directly via usb
with a simple utility; assignments configuration remain stored inside
PIC non volatile data eeprom so there is no need to reprogram it after
disconnecting
- it should be compatible with virtually all radios equipped with a PPM
output, and it's also able to decodify some type of PCM signal (for now
Futaba PCM1024 and Sanwa/Airtronics PCM1/2)
- it should be compatible with virtually any RC or flight simulator that
can make use of the system joystick
- the firmware work also under linux (and the assignments utility should
be quite easily ported on linux linking against libusb instead of
LibUSB-Win32) and as an HID peripheral should work under every OS with
HID USB support
- an extensive manual is provided on our site, with hardware, software,
assignments, and also modulations description
- the source is extensively commented for the ones who need to
personalize it
- the project is totally free and suggestions and reports about it are
very appreciated
you can find it at
http://rcjoyng2.qstep.net/
enjoy it
alessio e andrea
homepage: http://alessioandrea.qstep.net/
(take off sneakers to reply)
New Product RC Joystick NG^2 alessio70 DIY Electronics 79 Mar 17, 2014 02:04 AM
Discussion RC Joystick NG^2 now with PCM support alessio70 DIY Electronics 24 Sep 25, 2006 04:59 AM
