Old Sep 11, 2006, 09:10 AM
tocano is offline
Find More Posts by tocano
tocano's Avatar
Perth, Australia
Joined Sep 2003
How to test nicad battery cells?
I have 3 packs subc cell 8 cells Sanyo CP2400.
They are 3 years old but I have not used them that often since I don't fly regularly.
Now I found that they don't discharge high current for long anymore.
I use them for my Corona heli and I have very short flight with them but fine with other battery packs.
The problem packs are all Sanyo CP2400 cells.
Is there a simple way to test the cells individually. I am thinking of disassembling the packs and use the good cells.
Maybe I can get a couple of packs out of them.
tocano is offline Find More Posts by tocano
Old Sep 11, 2006, 09:18 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
CP2400 leak a lot, bad cells
hall woo is offline Find More Posts by hall woo
Old Sep 11, 2006, 09:40 AM
soar-ne is offline
Find More Posts by soar-ne
soar-ne
omaha ne
Joined May 2005
tocano:
Try a slow charge at around 240ma for 14-16 hours, they may wake up... From what I understand nimhs dont like to lay around totaly discharged like nicads so they may be history, but I would give it a try anyway I would check them every so often for excessive heat though if you decide to C/10 charge them!!!!!!!!!!
Good Luck
Bob
soar-ne is offline Find More Posts by soar-ne
Old Sep 11, 2006, 12:22 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Might have to do it a couple of times
hoppy is offline Find More Posts by hoppy
Old Sep 11, 2006, 01:39 PM
sjslhill is offline
Find More Posts by sjslhill
Joined Jan 2001
Question for you Hal
Where do they leak Hal? We have sold thousands of these cells and they have been used in Combat Robots for years and last hundreds of cycles.
DMA uses hundreds of thousands of them.
sjslhill is offline Find More Posts by sjslhill
Old Sep 11, 2006, 01:41 PM
sjslhill is offline
Joined Jan 2001
My thoughts
If you have not used these very often they can be recovered easily with a few cycles. CP2400 cells will last 500 cycles if they were not abused.
thanks,
Steve
Old Sep 11, 2006, 08:21 PM
tocano is offline
tocano's Avatar
Perth, Australia
Joined Sep 2003
Thanks everyone.
I will do a slow charge on them.
The 3 packs seem to have lost the high discharge soon after I replaced my supernova 250S charger with a swallow/hyperion charger. I had ebayed the supernova.
I don't know if it's a coincidence or the supernova charger has a better charging system? They still take 2000 mah+ charge though.
Old Sep 11, 2006, 08:40 PM
sjslhill is offline
Joined Jan 2001
oh...
I expect your not getting them fully charged.
Thanks everyone.
how to test a battery? 60ndown Batteries and Chargers 3 Oct 18, 2004 04:56 PM
How to test mAh value for 9.6v battery pack Maxx1010 Beginner Training Area (Aircraft-Electric) 8 Aug 13, 2004 05:25 PM
How to test for balance in li-poly cells? gotak Batteries and Chargers 3 Oct 17, 2003 06:05 PM
How to test a Battery cubsflyer Batteries and Chargers 3 Aug 19, 2003 10:12 PM
How to test if a nicad is properly charged John Webb Electric Plane Talk 11 May 09, 2001 10:52 AM
