Old Jan 22, 2007, 02:32 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Bump in Korea
Here is a video of a a Bump built from a kit. Builder is Yukio Takahashi from Korea:
Bump Maiden Flight (2 min 20 sec)
Michael
epilot is offline Find More Posts by epilot
Old Jan 22, 2007, 07:29 PM
Gopeewee is offline
Find More Posts by Gopeewee
Korea
Joined Nov 2005
Dear Michael
Thank you for sharing the BUMP kit. She flew very well at the maiden flight. Also, thank you for putting the link to my maiden flight video. I like the BUMP so much. Despite it was my first micro size craft ,the kit was so easy to assemble due to its sharp cuttings. As you reccomended on the instructions, the matching with the Minor Receiver, 7mm Didel Motor and 50mAh Lipo looks like a good choice. The maiden flight made me so happy and so amazed. How controllable and stable she was! I even did a loop! Believe your BUMP kit is one of the best choices for someone like me just stepping into the world of micro size airplanes, on the other hand, sad to know the sales didn't go well and no longer you are selling the kit.
Again, thank you so much for sharing the kit and your knowledges.
Yukio
Gopeewee is offline Find More Posts by Gopeewee
Old Jan 23, 2007, 07:30 PM
Kelley is offline
Find More Posts by Kelley
Kelley's Avatar
Goodyear, AZ
Joined Jan 2003
Does anyone have a BUMP kit they are willing to part with or are there plans available? I should have bumps quicker and got one while they were still around. I just got all the electronics together :-(
Kelley is offline Find More Posts by Kelley
Old Jan 23, 2007, 10:33 PM
dave brelsford is offline
Find More Posts by dave brelsford
catonsville md.
Joined May 2002
I want one too dag-gon-it.....I just got into this indoor stuff, and am really hooked.....
dave brelsford is offline Find More Posts by dave brelsford
Old Jan 24, 2007, 05:07 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
//Magnus
MagnusEl is offline Find More Posts by MagnusEl
Old Jan 25, 2007, 07:41 AM
gerdi is offline
Find More Posts by gerdi
germany south, bavarian alps
Joined Mar 2004
BUMP goes brushless
Hi,
My first BUMP as described in post no.178 is a winner and has meanwhile gathered much airtime. Therefore i decided to use the trusty BUMP-design as a carrier for my homebuilt brushless micro-outrunners. Currently i finished a tiny 3,6 gramm outrunner with only three teeth and four poles, which i made from the stator of a small brushed motor. This machine has not the highest efficiency, but the output is more than enough for a little Bump. My friend StephanB sent me a few weeks ago a parts-set cut from 1mm foam called styrodur. I added a Falcon Breezeblock, a single lipo 145 mA, an YGE4BL brushless controller and my new motor. Total flying weight with a STO 2,7 x 2,6 prop is 23 gramms. I could not wait till next indoor-session and maidened it outside, although the weather was really cold and a breeze has sprung up. It went straight away with just a little bit of throttle used. The wing from the 1mm styrodur turned out to be too fragile to withstand the gusts and bent a little under the loads, so i have changed meanwhile to a wing from 2,5mm depron. I'am really happy with my new brushless BUMP, very good flight-performance. Once again a success with a BUMP!. Have fun with the pictures :-).
Dieter
gerdi is offline Find More Posts by gerdi
Old Jan 25, 2007, 09:22 AM
StephanB is offline
Find More Posts by StephanB
Restricted User
StephanB's Avatar
Frankfurt-region, Germany
Joined Mar 2003
Hi Dieter,
again, a nice one. I'am happy, that the parts-set worked. I wasn't sure, whether the material is strong enough. Good to know, that you could replace the wing with something stiffer before damaging this jewel of a motor.
Question: The propmount is integral part of the bell? That prop seems to have a huge bore.
Stephan
StephanB is offline Find More Posts by StephanB
Old Jan 25, 2007, 09:55 AM
gerdi is offline
Joined Mar 2004
Propmount
Yes, the propmount is integrated.
That was necessary, because the outside diameter of the ball bearings amounts to 4mm. The original drilling of the prop is 4mm. I have it drilled out on 4,5mm.
That was for me the simplest solution.
Dieter
Old Jan 28, 2007, 11:52 AM
MagnusEl is offline
MagnusEl's Avatar
Joined Jan 2004
Maiden!
No problem to fly this little beauti, very responsive on the rudder, OK on elevator.
Tried a loop, but didn`t had the oomp. Almost made a roll, but it "cut out" by itself after half a turn. Maybe trying it outside some calm day...
Old Jan 28, 2007, 01:02 PM
epilot is offline
Joined Nov 2000
You might have the CofG too far forward and perhaps a stiff elevator hinge. Try to mass balance the elevator. My Bump loops easily.
Michael
Old Jan 28, 2007, 01:28 PM
MagnusEl is offline
MagnusEl's Avatar
Joined Jan 2004
The elevator hinge is running very smoth now, after I expanded the holes where the cf rod runs throu. Mass balancing it is a very good ide, as I think you are right about the CoG, and since it only weight`s 9,02g.
And, off course you was right about the 3mm act, plenty off power for a 9 grams modell!!
Just had to get every hinge pin running smoooth....
Magnus
Old Feb 03, 2007, 09:06 AM
busta1 is offline
Find More Posts by busta1
Joined Jul 2005
my bump came in at 18.9grms with a 50mh cell and 20.6 with a 130mh cell. I am using the micoinvent gear with the 0.7grm actuators but I soldered larger wires to the actuators and that makes them a gram each!
Does anyone think this is to heavy for the orange 7mm DD motor? It flew great earlier with the wattage microflyer gear and th 7mm motor but I didn't weigh it.
Also has anyone got any advice on the setup of the DD motor , I didn't put in any right thrust earlier and didn't notice any problems, how about downthrust?
Great model Michael, I spent most of the morning trying to get my micromoth to fly, your model only took me an hour from scratch and it flew great straight off.
busta1 is offline Find More Posts by busta1
Old Feb 04, 2007, 12:50 PM
busta1 is offline
Joined Jul 2005
well it flew great at that weight but loops weren't possible. It had a tendency to porpoise a little but I didn't want to add any weight to the front so just flew it around as it was for half an hour.
Started to build a 10" version and then decided to build it into a stick fuesalage. It AUW is 13.6 grams, I think it could do with more control surface for the rudder but I will give it a go tomorrow.
Old Dec 10, 2012, 07:05 AM
rogenstein1983 is offline
Find More Posts by rogenstein1983
rogenstein1983's Avatar
Joined Feb 2012
Such a shame these kits arnt avalible any more, I would love to see one in 1/72 scale with a dt rx52 and Plantraco motor etc, please tell me 1/72 kits could on day be a reality there so many kits id love to build in that scale the bump being one of them
rogenstein1983 is offline Find More Posts by rogenstein1983
Old Dec 14, 2012, 11:55 PM
night fox is offline
Find More Posts by night fox
semarang ,indonesia
Joined Mar 2006
my BUMP model with differential motor for turn left / right
note : minggu = sunday......., it's in indonesian bahasa (bahasa indonesia)
night fox is offline Find More Posts by night fox
Rob Smith's E-Sport 10 Pilot's Report EricBjorn Sport Planes 355 Mar 09, 2015 11:48 PM
how many E-Flyer's also fly glow barn buster 50 Electric Plane Talk 29 Jan 23, 2009 04:06 PM
E-Pilot's Sad, frustrating Moment genovia Parkflyers 20 Sep 05, 2002 11:40 PM
Phrases Only an E-pilot Will Say... Brian Nixon Electric Plane Talk 42 Aug 07, 2001 07:06 PM
Push-E Cat's first flight, and mine. :-) Steve-S Electric Plane Talk 7 Jun 06, 2001 01:54 PM
