Old Dec 04, 2006, 10:16 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
as long as you dont get any CA on the plastic, and the transparency is high quality (what i ised was not high quality), you will get a good pic. what you could use are microscope slide covers which are very thin slivers of glass.
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Dec 04, 2006, 10:18 AM
Ghost 2501's Avatar
stoke on trent
works well though,
Old Dec 04, 2006, 11:12 AM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Use Elmers white glue for the windows. It dries clear, won't make a mess like CA and can be cleaned off with care when dried.
green-boat is offline Find More Posts by green-boat
Old Dec 04, 2006, 11:42 AM
Roger in France is offline
Find More Posts by Roger in France
85110 Chantonnay, Vendee, France
Joined Sep 2005
Microscope Slide Glass
GHOST 2501 Can you still get slide glass? I can't find it anywhere. maybe it is just my part of France. Any contacts would be welcomed.
Roger in France
Roger in France is offline Find More Posts by Roger in France
Old Dec 04, 2006, 11:46 AM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Have you tried a lab supply or maybe a pharmacy.
Old Dec 04, 2006, 01:02 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Nice camera and mounting Bbcliffe.
I look at all those cameras anytime I get down to the local "Fry's" electronic warehouse.
So fiddling around with the plumbing the last day or two, and finally got the setup I wanted. Had to heat bend some of the CPVC pipe, but it was the perfect size for the stacks. Here is some of the latest work, and the results the extra plumbing.
JJC "Smoke" generator picked up from Harbor Models. It's not on his website yet, but a very good price, $99.
Turbo Desiel Sound Generators are backordered.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Dec 04, 2006, 01:16 PM
smart_racer is offline
Find More Posts by smart_racer
Canada, BC, Victoria
Joined Feb 2006
Very Nice...
smart_racer is offline Find More Posts by smart_racer
Old Dec 04, 2006, 01:24 PM
Ghost 2501's Avatar
stoke on trent
Roger in France
maybe from a photographic supplier, as you can get glass plates for 35mm slides to protect them, they go over each side of the slide in the case.
Umi, can you kill the motors im choking on diesel fumes here! *cough*
Old Dec 04, 2006, 01:27 PM
Ghost 2501's Avatar
stoke on trent
perhaps having a fan linked to the motor, so at "idle", the smoke just flows from the stacks, but as power is applied, the fans force blow air to simulate engines revving harder
Old Dec 04, 2006, 02:14 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I was just checking the plumbing to be sure it was adequet.
The unit instructions describe it as fully proportional for steam, diesel, and
puffing desiel operation. I played with the show mode, and the "puffing" is a bit soft, as it only increases and decreases the fan speed. It seems to produce more of a high flow, low flow rather than a "puff".
Until I get all the ESC hooked up, and all the electronic installed, I won't get a full test of the JJC smokers abilities.
Old Dec 04, 2006, 02:55 PM
offshore1987 is offline
Find More Posts by offshore1987
United Kingdom, England, Portsmouth
Joined Nov 2006
looks great tho very cool shes going to be a stunner when you finish it
offshore1987 is offline Find More Posts by offshore1987
Old Dec 04, 2006, 03:14 PM
bcliffe is offline
Find More Posts by bcliffe
bcliffe's Avatar
Joined Jun 2004
Umi_Ryuzuki that is simply outstanding. Almost makes me want to try and retrofit it on mine.
Cheers
Ben
bcliffe is offline Find More Posts by bcliffe
Old Dec 04, 2006, 05:50 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
The smoke system is awesome!!
Kmot is offline Find More Posts by Kmot
Old Dec 04, 2006, 11:46 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Very nice Umi.
I want one, maby Santa- na.
Don M.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Dec 05, 2006, 12:19 PM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Umi, a friend purchased a used 12 volt air compressor and took it apart and just used the pump section. He put a pully on the shaft of the boat and on the pump and using a belt drive pumped this to the smoke unit. As the rpm on the motor increased the pump output also increased. At idle the smoke just eased out of the stack but as the motor shaft rpm increased the smoke pulsated until it became a strong emission. I have often thought of using a worn out small model airplane engine and trying the same process. Jerry J
jerryj98501 is offline Find More Posts by jerryj98501
Build Log Orca -- Another One Comes to Life!!! P. Tritle Scale Boats 64 Jun 19, 2007 11:45 AM
Discussion Tito Neri unclecrash Dock Talk 0 Jul 09, 2006 06:03 PM
Tito Neri Capt J Scale Boats 2 Jan 14, 2005 11:20 PM
*deleted* #1 comes to life - consider the beans spilled! Martin Hunter Parkflyers 50 Jun 23, 2003 10:25 AM
Aspire Comes To Life!!! aireze Electric Sailplanes 7 Jan 31, 2002 11:28 AM
