New Zealand, Waikato, Hamilton
Joined Aug 2005
lets see someone 3d this one.....http://www.techmodelproducts.com/twinn_rexx.htm
A Lynx Mk9 or Merlin would be very good aswell.
Sorry again Ed Ed - have you considered using a shaft driven tail instead of the belt drive? it would probably require less work and parts would be easier to find or build. Also you wouldn't need to worry about incorperating a 'belt adjustment system' of some sort, which could be tricky to create without loosing the scale apperence. ACE |
Yes, I have thought about a shaft system. Very hard, in fact. I started designing one. The biggest problem is getting bevels to take power off the main shaft. They need to be very small... I like the idea of model boat hardware - that's how I came into the hobby. I sorta gave up when I realized that I would probably have to machine parts to fit into the back end of 'Rexy. However.... I think I maybe rexamining the issue. Based on cursory measurements, I think shaft maybe the only way to go. I suspect any belt that long is going to run into significant drag and harmonic vibration issues...
ed. |
Okay, I am officially re-examining the issue. I will need to find 90 degree, 1:1 mitre gears for 3mm shaft, then I can get power off the tail rotor drive system into a shaft, then...
I will need to make my own tail rotor transmission. !Does anyone know of any heli's in the T-Rex's size class that use a shaft driven tail? That might be easier.... More pics: (Darth, I didn't hack up the body, just a very rough fit (held together with medical tape....) )ed |
The shogun has one version that is shaft drive and uses a bevel gear system on the tail box and I think it uses a gear to pull the tail drive off the the drive end
here is one location to take a look shogun off the big main gear. As far as mini beveled gears go try this place SDP/SI Good luck and keep us posted |
| Thread Tools | |
| New Product AH-64 Apache @target | briankshow | Micro RTF | 110 | May 23, 2008 11:38 AM |
| Discussion Anyone tried this? AH-64 Apache RTF | Goose68 | Micro Helis | 7 | Dec 18, 2007 09:09 PM |
| Build Log Micro AH-64 Apache | darthdrk | Micro Helis | 41 | Dec 24, 2006 12:37 PM |
| Build Log BCP/HBcp2 (Micro heli) AH-64 Apache Body | darthdrk | Micro Helis | 35 | Nov 14, 2006 08:40 PM |
| ModelTek AH-64 Apache Card Model for Micro helis | Hoverup | Micro Helis | 4 | Jan 12, 2004 06:03 PM |
