Old Sep 09, 2006, 02:57 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
I bought a gallon of toluene at my local "do-it center" a couple months ago. They didn't have it in stock, but had no problem ordering it for me.
It's still listed at thier online store
Boz
theBOZman is offline Find More Posts by theBOZman
Old Sep 09, 2006, 09:08 PM
Utahrd is offline
Find More Posts by Utahrd
Flounder
Utahrd's Avatar
Three turns into Eddie’s High Nowhere
Joined Aug 2006
Well, I dropped by my local Ace Hardware this afternoon and they did indeed have Toluene, as some of you suggested they would. I picked up a gallon for about $12. Thanks again for all the info, guys!
Charlie
Utahrd is offline Find More Posts by Utahrd
Old Feb 26, 2007, 05:02 PM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Paint Thinners to thin Goop
Hey, breaking open an old thread here.
Has anyone used "Thinners". Thet's what we call it here in Australia. Paint Thinners.
Thanx
Psi
Psionic001 is offline Find More Posts by Psionic001
Old Mar 11, 2010, 06:29 AM
TheKwijibo is offline
Find More Posts by TheKwijibo
Joined Apr 2008
What's a good mix ratio of Goop to Toluene/Xylene?
TheKwijibo is offline Find More Posts by TheKwijibo
Old Mar 11, 2010, 06:44 AM
Psionic001's Avatar
Joined Apr 2006
What are you covering/painting?
For EPP I thin mine down so it's as thick as say milk. Maybe a little thicker.
HTH.
Old Mar 11, 2010, 01:10 PM
CptMike is offline
Find More Posts by CptMike
Abundantly deficient.......
CptMike's Avatar
Orange County, CA
Joined May 2004
Anyone use Goof-Off as a thinner? Might be a good and cheap alternative if you just need a smaller amount. It's like $4 for 4.5oz and it's 95% Xylene. Might actually make a pretty good jar-full.
M
CptMike is offline Find More Posts by CptMike
Old Mar 11, 2010, 01:24 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
I thin Goop until it hits cheap maple syrup texture. I use Xylene. I get it at Home Depot. The wife likes the smell of sharpies (Xylene-based I think). A used rag was airing out in the garage. She came in with a load of clothes and a smile on her face. I think I need to keep an eye on her.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 11, 2010, 05:34 PM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
IIRC the ratio is about 1:1. I use it thinner on wings than fuses. You can tell when you're applying it if it's too thin it'll run pretty fast. If it's too thick you'll feel the foam brush stick a little too much
1000MPH is offline Find More Posts by 1000MPH
Old Mar 11, 2010, 05:38 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
I've heard that xylene doesnt work quite as well, but I forgot why. Yes Ace is the only place I've found it in Cal, home depot has none.
I'm thinking of switching to thinned epoxy, goop is not nearly as strong a bond, if its anything like "shoe goo" which I think its the same, it peels too easily.
rotagen is offline Find More Posts by rotagen
Old Mar 11, 2010, 05:51 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Ummm...not so. I get my Xylene by the gallon at the Mira Mesa HD.
mw
Old Mar 11, 2010, 07:49 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
I've heard that too but can't confirm. I've only used toluol.
What are you going to do with thinned epoxy?
Mark, I think he means Ace sells Toluol and HD don't.
Goop works well for me so far...
Old Mar 11, 2010, 07:56 PM
Psionic001's Avatar
Joined Apr 2006
OT, sorry...
@1000MPH. Can you tell me about that pretty looking fin? Is that a symmetrical section? How'd you make it?
Matt
Old Mar 11, 2010, 10:25 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Just balsa, basswood and sandpaper. I used to use a coroplast core and balsa sandwich but ditched the coro.
This isn't the same one but it gives you the idea.
Old Mar 12, 2010, 09:17 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Thinners
Thanx
Psi
I have been using general purpose spray paint thinners to thin Goop. Or Shoe Goo which is what we get here in Aus.
It seems to work fine, and is much cheaper.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Mar 15, 2010, 01:32 AM
Fred_L is offline
Find More Posts by Fred_L
If it flies - it's good
Fred_L's Avatar
Joined Sep 2003
Psionic001
I had a look in Bunnings when seeking a solvent for Shoe Goo. The paint thinners they had were quoted at something like 35% Tolulene. I dont think they quoted what the balance of the volume was, so I purchased the 1 litre can of Xylene (95%). It works well.
The only issue I has was on my Moth fuselage. I applied four or so coats of the thinned Shoe Goo and after it all dried I tried to paint it with a spray can of automotive touch up paint (black). I got a very splotchy matt type finish with some areas only being light grey. Anyway after about four more coats of paint and no improvement to the quality of the finish, I covered it in black Profilm. I think there is an incompatibility between the spray paint solvent and the Tolulene/Zylene in the Shoe Goo.
Fred_L is offline Find More Posts by Fred_L
Discussion Goop Thinning, toluene vs xylene mjswider Hand Launch 19 Dec 12, 2014 03:24 PM
Question Thinning Goop, toluene vs xylene mjswider Slope 5 Jan 02, 2007 04:41 PM
Discussion Tape directly over thin goop or 3m77 first? ave Slope 11 Jul 02, 2006 12:40 AM
Other names for tolulene or xylene ? Chadh Slope 9 Mar 30, 2004 11:07 AM
apc slow flyer prop or apc thin electric prop for SS? Nik-rc Parkflyers 1 Mar 23, 2004 11:19 PM
