Old Sep 08, 2006, 04:11 PM
Charle & Peggy Robinson
Guest
n/a Posts
Tower Kaos 40 Plans?
Anyone have a set of these that they don't need? I need to build a
fuselage.
TIA,
CR
Ed Paasch
Ed Paasch
Guest
n/a Posts
Re: Tower Kaos 40 Plans?
I know you'd probably rather build the replacement yourself, but:
http://www2.towerhobbies.com/cgi-bin...?&I=LXADK0&P=7
Ed
"Charle & Peggy Robinson" <ccrobins@ktc.com> wrote in message
news:7bKdnWpLDKjbSZzYnZ2dnUVZ_rWdnZ2d@valortelecom .com...
> fuselage.
> TIA,
> CR
Old Sep 08, 2006, 06:11 PM
Guest
n/a Posts
Thanks Ed,
I knew this was available. It contains a bunch of stuff that I don't
need. A fellow club member has a NIB kit that he'll sell me for the
price of the ARF fuse. I just thought that if I can get the plans I
can build a better fuse than that in the ARF.
Has anyone built the kit? Are there better materials in it than in
the ARF?
TIA,
CR
> Ed
>> fuselage.
>> TIA,
>> CR
Old Sep 08, 2006, 08:11 PM
Ed Cregger
Ed Cregger
Guest
n/a Posts
news:4501ED17.6040400@ktc.com...
> Thanks Ed,
> need. A fellow club member has a NIB kit that he'll sell me for the price
> of the ARF fuse. I just thought that if I can get the plans I can build
> Has anyone built the kit? Are there better materials in it than in the
> ARF?
> TIA,
> CR
What is wrong with the stock ARF fuselage, other than it is really a Super
Kaos design? Just curious.
Ed Cregger
Old Sep 08, 2006, 10:11 PM
Guest
n/a Posts
The fuse sides are made from very thin balsa laminated to a thin lite
ply skeleton. The top and bottom are thin sheeting over small
cross-section longerons. If you crash it, it disintegrates to the
point that it's tough to piece it back together. Ask me how I know! ;^)
If I had the fuse plan I'd make a new one from 3/32" balsa, doubled
from the wing saddle forward. I'd also get rid of the mild steel
pushrods. As it is, I can fix it but I think I can build a better one.
Regards,
CR
> Ed Cregger
Ed Cregger
Ed Cregger
Guest
n/a Posts
news:4502176C.4000603@ktc.com...
> The fuse sides are made from very thin balsa laminated to a thin lite ply
> skeleton. The top and bottom are thin sheeting over small cross-section
> longerons. If you crash it, it disintegrates to the point that it's
> If I had the fuse plan I'd make a new one from 3/32" balsa, doubled from
> the wing saddle forward. I'd also get rid of the mild steel pushrods. As
> Regards,
> CR
Thanks for the explanation. I wasn't aware of the thin fuselage sides, etc.
I have two of them NIB in the garage. Gotta get busy and put one of them
together. <G>
Ed Cregger
Guest
n/a Posts
You won't regret it. It's a good flying model. I just let the bottom
end of a stall turn get too close to the ground. :-(
CR
>> Regards,
>> CR
> together. <G>
> Ed Cregger
Old Sep 09, 2006, 12:11 PM
Martin X. Moleski, SJ
Guest
n/a Posts
On Fri, 08 Sep 2006 20:22:52 -0500, Charle & Peggy Robinson <ccrobins@ktc.com> wrote in <4502176C.4000603@ktc.com>:
Take measurements from the pieces you have left,
draw lines for any missing pieces, and start
cutting and pasting stuff to glue into place.
It's a little tougher than working from plans, but
it can be done. Your fuselage may look a little
different from the original, but it's YOURS, all
yours.
Don't ask me how I know about rebuilding fuselages. (
Marty
Discussion Tower Kaos .40 MustangAce17 Glow to Electric Conversions 15 Oct 27, 2006 07:40 AM
Help! Bridi Super Kaos 40 plans skylane42 Fuel Plane Talk 2 Aug 21, 2006 09:00 PM
Sold Tower Kaos 40 Kit, NIB kloz Aircraft - Fuel - Airplanes (FS/W) 0 Jan 16, 2006 10:08 PM
What repair covering for Tower Kaos 40? wxerman Fuel Plane Talk 5 Sep 02, 2005 02:27 PM
