Old Sep 08, 2006, 11:25 AM
crashdummy6 is offline
Find More Posts by crashdummy6
crashdummy6's Avatar
Joined Dec 2005
Question
Question on P connecting lipos
Two batteries, same voltage and cell count (3S) but differing capacities, say 700 and 800mah. Can they be connected with an adapter into a 3S2P without worries of different capacity, or does the capacity have to match as well. I am guessing they have to match but am hoping I am wrong.
crashdummy6 is offline Find More Posts by crashdummy6
Old Sep 08, 2006, 11:42 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
This will start another great debate but no they do not have to be the same capacity.
They need to be very close to the same voltage and it is best to connect them in paralel while they are mostly discharged and charge them in parallel. It is also best if they have approximatley the same C rating and past history.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Sep 08, 2006, 01:16 PM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
My experiments and experience supports Charles'.
After you've gained some experience, you may find you can be a little less conservative, but I would advise you to get the experience first.
Your example of 700 and 800-sized packs is fortuitous. The smaller the packs, the easier it is to contain collateral damage if there's an accident.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Sep 08, 2006, 03:29 PM
Joined Dec 2005
I will be charging them separately with a balancing charger so the voltages should be fine. I was just wondering how the depletion of the stored energy would balance out. If current flow is the same in all parts of a circuit, I was thinking the lesser capacity battery would drain low well before the larger capacity battery causing its cells to drop in voltage sooner. I am probably missing a basic principle somewhere. It has been a while.
Old Sep 08, 2006, 03:39 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
I find it easier to hit the same voltage by charging the two packs. Since the LiPo charger automaticly stops at the same voltage every time... (+/- less than .02 v)
I then connect - to - and put a resistor between + leads... and verify my self-ranging DVM indicates 0V across the resistor. (that indicates less than 1 milivolt differential...)
If you take the step of doing the differential voltage check across a resistor.. you won't have a problem paralleling packs of the same cell count. (3S, 4S... Parallel count doesn't matter)
Once they are paralleled... if thats your primary use of the packs... keep them paralleled. one charge ballance pack A... next charge ballance pack B... or parallel the taps plugs too (using the resistor trick) and you can ballance both packs at once.
Smaller pack may indicate a lower voltage under load than the larger pack... but that will reduce the current draw on the smaller pack... You'll find that as soon as the load is off, both packs have the same voltage.
Internal resistance of the cells will take care of keeping one pack from draining before the other. (also with them paralleled... the high pack would charge the low pack until they hit the same voltage. This is why parallelling cells works)
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Sep 08, 2006, 03:41 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
If they are in parallel, they will always have equal voltage. The "weaker" battery will supply less current.
rpage53 is offline Find More Posts by rpage53
Old Sep 08, 2006, 03:57 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
The current flow is only the same in all parts of a SERIES circuit. It's voltage that is always the same in a PARALLEL circuit. The current in each part of the circuit depends on the effective resistance of each side. In general there's nothing stopping you have ing 2A flowing in one side of the circuit, 1A in the other side and you will then have 3A once they have joined together.
Since the voltage is always constant on the 2 batteries they basically balance the load between them. One cannot drop the voltage sooner so it sort of compensates by reducing its current output to suit the voltage that it's held at. The most powerful one will contribute more current than the weaker one. So provided they're reasonably well matched batteries (particularly C ratings) they will both end up exhausted at approximately the same time.
If you had something like a 700mAh 20C battery and an 800mAh 6C battery things would get more interesting .
Steve
slipstick is offline Find More Posts by slipstick
question on my GWS P-51D Mustang build golddigger Parkflyers 3 Oct 05, 2005 05:43 PM
simple noob question on new lipos cells clearconcepts Batteries and Chargers 9 Dec 20, 2004 01:15 PM
Question on G.P. Pitts JSZ Giant Scale Airplanes 1 Feb 24, 2004 11:37 AM
Question on lipos 2100MAH Lipos and APACHE charger kushal_22 Batteries and Chargers 8 Feb 09, 2004 12:51 AM
Another GWS P-51 Question on CG fly4fun Parkflyers 3 Jan 10, 2003 08:17 AM
