Old Aug 15, 2002, 12:33 AM
Tor is offline
Tor
Find More Posts by Tor
Tor
Denver. Colorado
Joined Aug 2002
Building Tiger Moth Wing
Due to various mistakes of my first building and flying of a Tiger Moth, I am going to build another wing or possibly a new TM.
I was thinking of ordering the Wing kit for the Tiger Moth at:
http://www.horizonhobby.com
Anyone know if this includes the plastic piece that holds the lower dihedral?
One problem I had building the Tiger Moth wing, was getting the dihedral to stay at the numbers given in the instructions.
For the upper wings I sat a small weight in the center of the wings, then propped up the ends of the wing, so they were the required 38mm off the table. I then filled in the center gaps using epoxy mixed with microballons, as advised here. Unfortunatly, when the wing was dry and left to stand on it's own, I had around 25mm height on one wing, and 30mm on the other.
I again used epoxy and the plastic piece on the lower wing, and again the wing sagged to 10-15mm height less then that given in the manual.
BUT, the plane seems to fly fine.
Still if I build another wing or whole new kit, I'd like to know if there was a proper technique for getting the dihedral angle you want.
Thanks all!
Tor
Tor is offline Find More Posts by Tor
Old Aug 15, 2002, 12:37 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
The whole design of the Tiger Moth is based on TLAR engineering. TLAR = That Looks About Right.
I'm not sure why they say 38mm, but if you've got any dihedral in there, you're fine. As you said, the plane flies good, so why worry? It's not a critical measurement. If you have less, she will self-correct and self-right ever-so-slightly more slow than if you had more, but I doubt in the real world you'd ever notice the difference.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Aug 15, 2002, 12:42 AM
duanecowgill is offline
Find More Posts by duanecowgill
duanecowgill's Avatar
Sunnyvale, CA
Joined Jun 2002
I just got my GWS Tiger Moth Wing Tail set, p/n GWSAS2T. It did not come with the necessary dihederal brace. I am very disappointed.
duanecowgill is offline Find More Posts by duanecowgill
Old Aug 15, 2002, 04:46 PM
Tor is offline
Tor
Tor
Denver. Colorado
Joined Aug 2002
I am very sorry to hear that Duane.
Hope all other TM folks read this. So others don't find out the hard way as well.
Anyone have any suggestions on the best way to scratch build the missing plastic piece that holds the lower wing angle?
Tor
Old Aug 15, 2002, 04:53 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
==One problem I had building the Tiger Moth wing, was getting the dihedral to stay at the numbers given in the instructions. ==
Me too. I ended up raising the wing about 50% higher than the recommended spot, epoxiing it, letting it cure, then removed the blocking and is "sagged" to the right spot!
Tres Wright is offline Find More Posts by Tres Wright
Old Aug 15, 2002, 05:40 PM
CheeseWing is offline
Find More Posts by CheeseWing
Tantrums Rock!
CheeseWing's Avatar
Joined Jul 2001
Hey fellas,
The technique I discovered to hold the wing dihedral during building the wing was very simple and effective. First I took a scrap piece of 4x6" piece of 1/8" balsa. I measured out two strips of the 38mm and two strips of the 40mm lenths and cut them out. I took a 12x36" piece of 1/4" plywood I had laying around and placed the wing I was working on on top. I marked the plywood where the edges of the wings were and then CA'd the 38mm strips at those marks, built that wing while the strips held the dihedral. Then for the next wing, I tore of the 38mm strips and CA'd the 40mm strips in their place and then built that wing . . . very simple and effective! I used 5 minute epoxy w/ baking soda and it works wonders to hold the wing dihedral instead of that silly double-sided tape in the kit. Just remember to always sand-away the paint where you use epoxy so it can "bite" into the foam and get a permanent hold.
Best of Luck,
CheeseWing
CheeseWing is offline Find More Posts by CheeseWing
Old Aug 15, 2002, 05:59 PM
Perminator is offline
Find More Posts by Perminator
Perminator's Avatar
Västerås, Sweden
Joined Aug 2002
I agree on Dreamer's TLAR theory. Don't mess around too much with GWS 38mm instructions as it WILL sag no matter how you do it. Not work all the work as you probably won't notice any difference in the end.
Perminator is offline Find More Posts by Perminator
Old Aug 15, 2002, 06:15 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Since nobody mentioned it so far, another way to set the dihedral is install flying wires. I had the same problem with the sagging, and also thought the whole wing assembly seemed floppy.
So I reinforced the outer struts with cf rod on the front and back edges and made flying wires out of dental floss. The wires were partly for looks and partly for strength. It made a big difference in wing flex while looping or whatever.
BC
my tigermoth
Basketcase is offline Find More Posts by Basketcase
Old Aug 15, 2002, 08:14 PM
Tor is offline
Tor
Tor
Denver. Colorado
Joined Aug 2002
Thanks again.
I did not know if the Flying Wires would also allow me to set the wing dihedral. That is my next 'addition' after I get it repaired from the last mishap.
Any suggestions for replacing the missing lower dihedral brace when building the Wing Kit?
Think it's ok to just use glue to fill it in, and hold it, as with building the upper wing?
Maybe some carefully placed packing tape?
Tor
Old Aug 15, 2002, 08:38 PM
spinnetti is offline
Find More Posts by spinnetti
SCCA, EAA, M.E.
spinnetti's Avatar
United States, TX, Frisco
Joined Nov 2001
Easy way for me...
1. Attach the lower wing stiffener plate as stock
2. glue all the struts on, making sure to seat them in so that the full arc of the struts is glued to the wings.
3. Install the wings on the fuse.
4. glue the top wing, put a little tension on the wings (upward) and put a bit of clear packing tape on to reinforce.
Viola. Dihedral is set without having to measure a thing.
The less dihedral you have, the better the top end, and the more you have the better the turns. Adjust to suit. Thats the fun part.
spinnetti is offline Find More Posts by spinnetti
Old Aug 15, 2002, 08:49 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi Tor, that sounds like a great idea. I think it would probably work just as well. You might want to use a couple of layers.
After I broke my bottom wing right at the edge of the doubler for the forth time I added a strip of packing tape and never had any more problems with that side. (I did however fold the other side without tape.)
BC
Old Aug 16, 2002, 12:13 AM
Tantrums Rock!
CheeseWing's Avatar
Joined Jul 2001
Flying Wires
Hi Tor,
I put the Flying Wires on after I attached the two wings together and the epoxy was set overnight. The wires (kevlar thread) DEFINITELY increase the integrity of the wing structures and also enhances the way the plane looks!
- CheeseWing
Broken Tiger Moth Wing AussieParkflyer Parkflyers 15 Jan 10, 2002 01:37 PM
Tiger Moth Wing Joining ? Daveairway Parkflyers 13 Dec 01, 2001 10:11 AM
Tiger Moth Wing Stuts chiozza Parkflyers 4 Nov 25, 2001 02:46 PM
Tiger Moth Wing Hold Down Mods Ben Lanterman Parkflyers 11 Oct 01, 2001 09:49 PM
tiger moth wing struts Beige Parkflyers 10 Sep 27, 2001 12:15 PM
