Old Nov 13, 2006, 01:37 PM
Powerbook is offline
Find More Posts by Powerbook
Have Fun !
Joined Aug 2006
Hello,
I try to convert the PDF to DXF (to cut BlingBling on my little CNC cutting tool) but i have some problems with scale after conversion.
No pb with the wingspan, i would need other dimensions.
Could you help me ?
Thank you.
Powerbook.
Powerbook is offline Find More Posts by Powerbook
Old Nov 13, 2006, 02:51 PM
lastuaja is offline
Find More Posts by lastuaja
Joined Jun 2004
Originally Posted by power
The design is well thought out, it can be built incredibly light yet rigid. The moments are perfect for component placement in realation to C.G. I was a bit worried about hitting C.G. using a 12 gram motor with a superlight pack. But it came out perfect
What is your setting for C.G?
lastuaja is offline Find More Posts by lastuaja
Old Dec 02, 2006, 10:41 AM
ededge2002 is offline
Find More Posts by ededge2002
ededge2002's Avatar
Newmarket,Ontario, Canada
Joined Dec 2002
im looking at these plans and notice a strange right thrust. is this an oversight or am i missing somthing? i usualy build to have a 0-0 motor set up so this seems strange to me....
ededge2002
ededge2002 is offline Find More Posts by ededge2002
Old Dec 02, 2006, 11:54 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
I am flying my Bling at 185 mm back from the nose (center) of the fuse. This is about 6 mm "aft" from the plan C.G. I like the way it flys so I left it.
power is offline Find More Posts by power
Old Dec 02, 2006, 12:01 PM
power is offline
power's Avatar
Joined Apr 2003
Originally Posted by Powerbook
Hello,
Could you help me ?
Thank you.
Powerbook.
I just measured my plans and I got 762 mm on the length and 206 mm on the height. Hope this helps.
Old Dec 06, 2006, 01:56 PM
Have Fun !
Joined Aug 2006
Hi Power,
Thank you !
I cut a BlingBling, flight great with a MicroDan 2003-F3P, it's a dream ;-)
Powerbook.
Old Dec 06, 2006, 03:39 PM
matchlessaero is offline
Find More Posts by matchlessaero
matchlessaero's Avatar
Tennessee/Mid-South US
Joined Mar 2002
ededge2002
Are you kidding or are you serious?.......
matchlessaero is offline Find More Posts by matchlessaero
Old Dec 06, 2006, 04:08 PM
ededge2002's Avatar
Joined Dec 2002
im being serious there looks to be a considerable amount of right thrust on the horizontal part of the fuse... it might just be me but it looks like the front of it is not at a 90deg angle.
ededge2002
Old Dec 06, 2006, 04:10 PM
fish2keel is offline
Find More Posts by fish2keel
Just fly,its just money.
edge is right look at it closely.
fish2keel is offline Find More Posts by fish2keel
Old Dec 06, 2006, 04:15 PM
whopper is offline
Find More Posts by whopper
Helicrack Addict
whopper's Avatar
Australia, QLD, Forest Lake
Joined Dec 2003
ededge2002
yeeesssssss........it has right thrust. What is so strange about this??
It's probably needed for the correct thrust line in hover, apart from all the usual right thrust reasons, (do we really have to revisit that one...??????)
I'm with Matchless, I thought you were kidding with your question.
whopper is offline Find More Posts by whopper
Old Dec 06, 2006, 04:26 PM
power is offline
power's Avatar
Joined Apr 2003
Hi Power,
Thank you !
Powerbook.
Your welcome Glad to hear you got one flying. The plane almost flys itself. I love it!!
ededge2002, hard to believe that you have not seen right thrust in model aircraft before, it is very common. It is to compensate for "P" factor and or motor torque. In a perfect setup, adding throttle and not having to feed in rudder to keep the aircraft in a straight heading is what the designers are after. In pattern, smooth, perfect transitions are desired so the less input from the pilot the better.
Old Dec 06, 2006, 05:57 PM
ededge2002's Avatar
Joined Dec 2002
ok sorry for my stupidness but ive never built right thrust into a foamy lol i guess i just fly it out..... i do know the reasons of right thrust (started flying in 1984) but never bothered to apply it to foamys ...... (you know that thing where right thrust is backwards upside down....(grin!)) also i guess different prop/motor combos would need different amounts of thrust angle because of the different P factor.
thanks
ededge2002
"Kit designers try to help by building right thrust into the
engine mount in an attempt to counteract the P-factor. But the
yaw force is to the right when the plane is inverted, so the builtin
right thrust just makes the problem worse, and it would
require a lot of drag-producing left-rudder correction to
overcome it. Understanding the source of these forces and
learning to give the correct control inputs result in lower overall
drag through maneuvers."
(pg 3 paragraph 3)
http://members.aol.com/KMyersEFO/aerobat.pdf
Old Dec 06, 2006, 06:07 PM
Joined Mar 2002
Not stupidness, and I did not mean to sound condescending. Please accept my apologies if I did.
However, I've only flown 2 foamy designs ever that did not need right thrust. Everything else that I've ever designed or flown required right thrust to track correctly......
Old Dec 06, 2006, 07:13 PM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
thanks
ededge2002
(pg 3 paragraph 3)
I wouldn't necesarily agree with the P-factor/reversed inverted analysis. Most of the necessity for right thrust is often due to the distribution of fuselage area in the wake of the prop. The airflow in the wake rotates in the same direction as the prop. Since there's typically more side area above the thrustline behind the CG there's typically a net yawing effect to the left. This effect is dependent on the direction of propellor rotation and distribution of fuselage area so thrustline compensation will be equally effective inverted.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Dec 06, 2006, 08:40 PM
whopper is offline
Helicrack Addict
whopper's Avatar
Joined Dec 2003
My app's also. I just take it for granted that everything (conventional.... ) will need some right thrust to avoid carrying rudder trim (which is a can of worms on its own since this is airspeed dependant not power setting dependant, so not so good for cancelling/compensating for P-factor).
Free 3D p-40 plan (Autocad) by "Me" hate The Builders Workshop 5 Jul 21, 2005 08:45 PM
FuntanaMini by Didier Pjotrrr 3D Flying 27 Mar 20, 2004 12:41 PM
