Old Aug 14, 2002, 03:48 PM
JStory is offline
Find More Posts by JStory
United States, TX, Dallas
Joined Jun 2001
My first post in this forum :) Question about Modeltech Extra 300
Ok im running a 11 x 7 prop but it is not a E prop is that ok? I running a Aveox geared setup. I have a 8 cell and 10 cell battery pack of RC1700's for it. Im going to keep some CP1700's though or should i get some 2400's? What is the best way to mount the pack? I need some detailed pics of how you guys setup a removable battery slot. I saw one pic of the hinged canopy that is probally what i am going to do. Also i have heard this little sucker snaps if you pull back to hard, at what speed do you have to be going and what do the throws have to be at. Thanks!
JStory is offline Find More Posts by JStory
Old Aug 15, 2002, 02:08 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Modeltech Extra
Here is a long thread about some Modeltech Extra-300 conversions. http://www.rcgroups.com/forums/showt...odeltech+extra
I am still flying mine and it is a great show off plane. As you'll see in the thread, I did a few mods to get it lighter and have some more aerobatic agility. The best thing I did though was go to bigger ailerons. It increased the wing area and lowered the wing loading noticeably. I would say that you will want to ditch the gas prop as soon as possible but it may fly with it ok for now. You will see a big difference after you switch. What Aveox do you have going in it? I am running a 1409-2Y on a 2.38 Astro Gearbox, swinging a 12X6 APC-E on 10-11 cells 2400mah. With moderate throttle management, I am getting between 5-6 minute flights depending on how much vertical stuff I do.
I can't help you much on the throws since I am running bigger control surfaces, but I'd say use the reccommended throws in the instructions.
Troy is offline Find More Posts by Troy
Old Aug 15, 2002, 02:10 AM
Troy is offline
Troy's Avatar
Joined Feb 1999
Battery hatch and hold down. I built a 3/32" thick balsa deck (cross grain) for the battery and use velcro to hold it in; wrapped around AND stuck to the floor with it.
Old Aug 15, 2002, 02:13 AM
Troy is offline
Troy's Avatar
Joined Feb 1999
My motor mount also, simple and easy.
Old Aug 15, 2002, 02:13 PM
ChrisD is offline
Find More Posts by ChrisD
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
JStory,
See my pics at http://chrisd-rc.freeservers.com for the canopy hinging. Can't take credit for that. Another conversionee was the author of that one.
I've flown it well with APC 12x8 prop on Endo/4.6:1/10 CP-1700's.
I'd go larger on the cell mah's if you have them for longer flights.
Chris
ChrisD is offline Find More Posts by ChrisD
Discussion My first post..noob question included SMaxxin Micro Helis 2 Mar 25, 2007 11:45 AM
My first post and i have a question. Giglimesh Simulators 12 Aug 13, 2005 10:33 PM
No more threads about member/vendor behavior in this forum please. Cash Traylor Vendor Talk 12 Apr 26, 2002 04:41 PM
Re: Requirement for posting in this Forum. Mark Wood Life, The Universe, and Politics 51 Jul 05, 2001 07:55 AM
