Old Sep 06, 2006, 11:13 AM
thermal is offline
Find More Posts by thermal
thermal's Avatar
Maryland's eastern most shoreline
Joined May 2004
Question
TD Glider for Hyperion 3019-10
I have a Hyperion 3019-10 motor (weight 142g, 1067 Kv) and a Hyperion 50 Amp with BEC ESC, both from AlleRC. I'd like to use these in an electric TD glider, preferably one with ailerons. Can anyone suggest some suitable TD gliders that would mate well with this setup? Also, what size folding prop and what size Lipo battery. I'm not interested in it being able to go vertical, just in being able to get to hunting altitude in a reasonably short time. I'd like the largest wingspan that would be compatable.
Bob
Edit...I want to use this motor direct drive.
thermal is offline Find More Posts by thermal
Old Sep 06, 2006, 11:37 AM
jfrickmann is offline
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
A couple of suggestions:
http://www.icare-rc.com/magellan_e.htm
http://www.nesail.com/detail.php?productID=131
There is some prop data here for your motor, to give you an idea of a suitable prop and battery combination.
Jesper
jfrickmann is offline Find More Posts by jfrickmann
Old Sep 06, 2006, 01:28 PM
thermal is offline
thermal's Avatar
Joined May 2004
jfrickman, thanks for the suggestions, I like the look of the magellan.
Any other thoughts on good match-ups?
Bob
Discussion Hyperion 3019/10 for a LT 25 DBono99 Power Systems 28 Aug 07, 2009 12:40 PM
Video Soaring Star glider with Hyperion 3019/10 Tailgunner1 Sailplane Talk 11 Mar 20, 2007 06:26 PM
Discussion hyperion 3019-10 motor failed after 4 flights Orion_V Electric Heli Talk 4 May 01, 2006 04:04 PM
Help! Conversion for a Hyperion Z3025-10? DominicM Sport Planes 11 Dec 23, 2005 09:17 AM
What Plane for Hyperion Z3019-10 eran_k Power Systems 0 Nov 20, 2005 05:58 AM
