Old Sep 06, 2006, 05:32 AM
supi7 is offline
Find More Posts by supi7
supi7's Avatar
CHICAGO
Joined Feb 2004
Mini-Review
Giant Scale and F3A Pattern Brushless motors from TrueRC
Hi All,
Please check out the video of a 25% 3D Katana by Pacific Models
set up with our new 5340-7 Brushless outrunner.
Here is a little background to the video.
Lou of the Suburban R/C Barnstormers was finally fed up with his Super Tigre engine after a couple of dead stick landings and a crash.
www.TrueRC.com set him up with brand new 5340-7 250RPM/V Brushless Outrunner
And a pair or 15C 5S3P 6600mAh custom packs to run as 10S3P.
With a 18x10 Zinger this combination delivered 2800W of power, enough to give Lou over 1.64:1 power to weight ratio needed to enjoy his Pacific Models 25% 3D Katana once again.
ESC: CC Phoenix 85HV
Total weigh of the model is 17lb. This includes the battery packs and motor + extensive frame repair.
25% 3D Katana Video
Enjoy,
Dan
TrueRC
more video links at http://truerc.pitsbros.com/
supi7 is offline Find More Posts by supi7
Old Sep 06, 2006, 06:39 AM
davecee is online now
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Link was not useful. No information available there.
davecee is online now Find More Posts by davecee
Old Sep 06, 2006, 09:06 AM
bobber is offline
Find More Posts by bobber
Flyin brick
bobber's Avatar
Joined Feb 2005
Pure advertising.......... Dan, we ARE NOT in "for sale" or "vendors talk" section..... Watch for moderators
P.S. I didn't see anything interesting in that video Nothing what can be called "more than 1.64:1 ratio"......Just slow flying....
bobber is offline Find More Posts by bobber
Old Sep 06, 2006, 01:09 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
Guys the link is for the video only, I do not know what other info I could provide for you to be interested to watch it.
bobber, The plane is a 3D plane not meant for speed and I can not tell the man to change his flying style. 2 pilots flew the plane that same day and were impressed by it's performance and low cost of the setup. The gentelman that purchased this setup is also interested in converting his 25% YAK, that has to be good.
The thread is meant as an Information for the RCG members that are interested in the good performance that the "house" brand motors deliver.
The 2800W of continuous power is based on the actual Wattmeter results during WOT for 5min. Based on recomended 150W :1lb power to weight ratio this 17lb setup would deliver 164.7W per pound.
Best Wishes,
Dan
TrueRC
Old Sep 06, 2006, 01:53 PM
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
What I meant was your link didn't take me anywhere that could provide information about your products, just a couple of e-mail addresses.
Dave
Old Sep 06, 2006, 02:08 PM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
click enter
//Peter
wolw is offline Find More Posts by wolw
Old Sep 06, 2006, 02:29 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Watts "IN" and watts "Out" are not the same---given the likely efficiency of the motor in the low 80% range you really will have more like 130-135 watts/lb. Still pleanty of power to fly well, but it is possible to have lower weight power systems deliever more watts/lb by a fair amount. Just for example the 102 inch Yak54 that one of our club members flies has a watts/lb of 235. Plane weighs in at 23 lbs and has 6000 watts full power.
Steve
sneu is offline Find More Posts by sneu
Old Sep 06, 2006, 03:02 PM
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Originally Posted by wolw
click enter
//Peter
There is no "enter" on the page I see. However I didn't think to click on the blank portion of the page, duh.
Dave
Old Sep 07, 2006, 08:31 AM
joesiphers is offline
Find More Posts by joesiphers
suppomodel
Joined Aug 2006
use the wrong propeller!!! too small and under-load!!
should try APC-20X12WE instead!
we test it with Hacker-acro90 0timing
APC-20X12WE
34v
82A(start) 75A-Normal
result: 7100RMP
joesiphers is offline Find More Posts by joesiphers
Old Sep 07, 2006, 08:53 AM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
yes that's one of the things I sugested to the pilot. At the time thats te largest prop he had available, still great power on this setup.
Dan
Old Sep 07, 2006, 09:07 AM
suppomodel
Joined Aug 2006
you are right,
also the True Motor KV is different even with Hacker and phoenix ESC.
The phoenix's is 15% higher
We test with Hacker so as the KV is 250. but with Phoenix, it will be 287
New Brushless Motors from Lensrc.com Tbow100 Foamies (Kits) 5 Nov 01, 2004 10:19 AM
New Brushless Motors from Lensrc.com Tbow100 Power Systems 10 Jul 28, 2004 10:14 PM
New brushless motors from Castle birdie_in_texas Castle Creations 3 Dec 09, 2003 05:55 PM
Mega SHORT brushless motors from hobby lobby. ???? I FO nut Power Systems 0 Jun 22, 2003 03:43 PM
DC Brushless motors from computer fans? Matthew Allen Power Systems 39 Aug 30, 2002 03:45 PM
