Wow
Thanks for the help. i have built a peter Rake 1-1/2 strutter that flew rudder and elevator but I have not built a true four channel that I have flown ( built a Sopwith camel 36 inch peter rake but never flew it). The parkzone P51 is aeleron and elevator and I have enjoyed it. I do not know if parkzone builds a four channel reciever. The idea behind the parkzone gear was to be able to use the combat module, drop module etc. I hope I have not taken too much from the original thread, if I am I will be more than happy to start a new one. I just love these WWI planes. The look, size, etc. makes them perfect.
Thanks Jim |
The Lewis Gun kit is ready to be ordered for those interested...
http://www.tanks-hangar.com/index.html Mike |
I have ordered mine. By the way the drum used by aviators held 47 bullets but most pilots but one in the breech for 48 shots before replacing the drum.
Latest blog entry: New receiver packs and asking Castle for...
I've got a couple of Esskay 400XT's that I got from HobbyLobby that don't have a home. I've also got an e-flite Park 400 920kv motor that needs a home. I think either motor would work but I don't know much about the 400XT's specs. Just know hobbylobby says up to 16 ounce planes. I know the e-flite motor will work but would have to be reversed which I've not done on the e-flite motors. Not sure how big a pain that would be.
Any ideas? Thanks |
Mike,
The Lewis gun looks GREAT! Tank really did a nice job on the laser cutting, and of course Doug's painting is unreal as usual. You and Doug need to make it on Saturday for sure, the weather looks really good, albeit cold(low 50's) but sunny with very light winds. I'll be ready to get some in-flight shots of Doug's SE5 and the DVII! Ronnie |
Hey Ronnie:
You can be my wingman/cameraman anytime. I look forward to more of your pictures on the Fokker D VII. I can't find my kit of the second SE5a as it is trapped in boxes and boxes we are going through from storage right now. Hopefully tonight to trial fit a 480 motor. Mike |
SE5 and problem with speed control
Michael, I've also had this same type of problem, twice with a word models Voodoo Reno racer, and once with the my electrifly Fokker, all three times during initial test flights using the supplied or recommended motor/prop.
I had the same experience, about 3-4 minutes into the flight, and flying at 1/2 throttle or less(with spec battery pack or close, TP 1320) should not be anywhere close to max load) and with silver series speed control mounted in airflow(so should not be over heating, and without large aerobatic moves so should not be loading the BEC). Two times, once with each plane, the motor shut off but I retained control and was able to land on the runway. The third time, the motor kept running and I had no control and it went in in heavy wind in a swampy area. Fortunately only a little firewall damage with the Voodoo and a destroyed cowl where the folding prop crushed it when it folded while still running as it impacted, but no water damage. I was using different physical packs(with a venom 1800 20C 3S and the other two times with 1320 TP 15C packs, different motors, different receivers(all with good ground range), (FUTABA, and berg) and all with either futaba 3110 or HS55 servos. I was the only flier at the field in all cases and testing with a hobbico frequency tester showed no other interference beforehand or after. These happened on three different days. The only constant in all of these cases were the two 25A silver series speed controls. I believe they have a flaw, these were all purchased within the last month and a half. In each case when I landed, or recovered the plane, when the plane landed, and I put the throttle at low setting, it beeped, when I increased throttle it beeped again, and then reset at low throttle. In all cases the servos responded normally immediately after landing/crashing. In each case it acted like the speed control had completely reset into safe start, but in no case did I have enough time to try re-enabling in the air. I'm using good deans plugs well soldered. I believe the speed controls are re-setting in flight, and in one case disabling the BEC, it acts like it is overheating, but the loading should not be doing this. In all cases, I kept all components the same, battery, connectors, motor, receiver, and replaced the speed control with a 25A CC phoenix, and in one case an electrifly 20A brushless control, and have not had one issue at all. these all have similar specs to the silver series controller and they are fine. I was able to return these to the LHS for a cost credit and replace them, but I will never use one of these again. I have not had trouble with the brushed controllers by electrifly. I contacted electrifly and the tech couldn't come up with a good reason other than they are overheating and shutting down, but it's not worth it to me to try them again. Quote:
Latest blog entry: Spaceship One
| Thread Tools | |
| Wanted Great Planes S.E. 5a WWI ARF | rz22g | Aircraft - Electric - Airplanes (FS/W) | 4 | Apr 23, 2007 12:00 AM |
| Sold Great Planes ElectriFly S.E.5a WWI biplane | LRHann | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 05, 2007 06:11 PM |
| Found Great Planes ElectriFly S.E.5a | ASAMech | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 23, 2007 06:40 PM |
| Alert S.E.5a WWI arf in stock towwer hobbies | yamakawazuki | Electric Warbirds | 3 | Oct 23, 2006 05:47 PM |
| New Product Great Planes S.E.5a WWI EP ARF | P-51C | Electric Warbirds | 6 | Jul 13, 2006 03:20 PM |
