Old Feb 12, 2011, 10:19 AM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
And, though very light, the design is exceptionally strong!
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Feb 25, 2011, 03:57 AM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
I've been working on my Cub a few minutes at a time for the past few days. I have the fuse done to the point of where I build the landing gear next. Hopefully can knock that out tomorrow before work. Gotta say it's been one of the more enjoyable builds that I've done in a while. Very smooth and straightforward.
I cheated and skipped ahead and built all three motor mounts as I have a power system to work with all of them. One of the sweetest is an old Astro Flight 10 turn 010 brushless in a GWS gearbox. I can gear it to use a smaller prop if needed. I'll have to do some testing. It needs to get used again rather than just rot in the "old stuff" box.
At the rate I'm going I figure it'll be a month or so before I have her finished. I've decided not to do any modifications (flaps etc). I'll finally build a MM kit bone stock....
Joe
turbojoe is offline Find More Posts by turbojoe
Old Feb 26, 2011, 10:31 AM
shafferama is offline
Find More Posts by shafferama
READY!
shafferama's Avatar
seattle, wa
Joined May 2008
Joe
I finished my MM J3 a couple months ago. I tried to build my J3 as stock as possible, and had fun adding some scale details, and awesome vinyl graphics. I suppose by the end of it all I may have spent 30-40 hours on it. Having built many Guillows kits, the J3 was my first build to fly electric balsa kit. It was fun. I love this plane!
I tried programming flaperons and it just didn't need them. This plane flies great, and really slow with the stock scale wing.
shafferama is offline Find More Posts by shafferama
Old Feb 26, 2011, 11:05 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Yep, my first J-3 flew perfectly without flaperons, and like you, I found they didn't do anything to improve the flight characteristics.
My L-4 BirdDog won't have them either, That's next on my list.
NoFlyZone is offline Find More Posts by NoFlyZone
Old Apr 03, 2011, 01:41 AM
campaholic is offline
Find More Posts by campaholic
Campbell River BC
Joined Nov 2002
Just finishing up the MM Cub after being out of the hobby for about 8 years so still using 72MHz equipment. Mounting the receiver so any suggestions what to do with the full length antenna would be appreciated?
Roger
campaholic is offline Find More Posts by campaholic
Old Apr 03, 2011, 02:28 AM
turbojoe is offline
turbojoe's Avatar
Joined Jul 2002
Roger
My MM Cub is almost done and like you I'll be flying 72mhz in this bird. I use short Azarr antennas on almost all of my 72mhz stuff. They work great in everything but especially well in these smaller planes. The entire antenna can be concealed inside the fuselage. The price has gone up quite a bit since I bought my last one but they're worth every penny.
Joe
Old Apr 04, 2011, 11:31 AM
Campbell River BC
Joined Nov 2002
Would rather not cut the antenna as I stole it from a glow plane and may need to out it back in.
Roger
Old Apr 05, 2011, 06:25 AM
Mountain Models is offline
Find More Posts by Mountain Models
BYOP - Build Your Own Planes
Mountain Models's Avatar
United States, WI, Appleton
Joined Mar 2001
Roger,
I took the antenna out the bottom, along the left side bottom, to the back, and then back up the right side bottom edge.
It did reduce the range very slightly. Try it and just do a range check before flying it, but that should work fine.
Brian
Mountain Models is offline Find More Posts by Mountain Models
Old Apr 05, 2011, 05:30 PM
skorski is offline
Find More Posts by skorski
No conspiracy in theory
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
I always had good reliable results by wrapping just enough of the antenna around a dowel so that the total length was reduced just enough to fit inside the fuselage (or wing). I started with a dowel that was just long enough to fit the length, tape or heat shrink the tip of the antenna to the end of the dowel, then straight along the dowel to a point where you can wrap the excess and still have enough to reach the Rx mount location. Secure the wraps with tape or hot glue but avoid any overlap. You are essentially making a base or mid loaded antenna of the stock antenna.
Mike.
skorski is offline Find More Posts by skorski
Old Apr 14, 2011, 05:37 PM
Campbell River BC
Joined Nov 2002
I tried wrapping the antenna around a straw. So far it looks like it should work but I haven't done a proper range check yet.
Thanks for the ideas.
Roger
Old Apr 23, 2011, 01:29 AM
Campbell River BC
Joined Nov 2002
The coiled antenna around the soda straw worked great. And the plane flew amazing. Great kit Mountain Models.
Roger
Old Jul 06, 2011, 05:27 PM
peterreebok is offline
Find More Posts by peterreebok
Australia, VIC, Ferntree Gully
Joined Nov 2010
Pete here from Australia.
Only heli and ARF trainer experience so far, decided on a MM cub as a sensible first build - always admire the scale like planes more than the 'whatever ' generic shapes our field seems to be populated with.
Kit should arrive this week or next - then I will take my time with the build and get in some flying experience before flying the cub.
Can see already quite a few more MM planes coming.
peterreebok is offline Find More Posts by peterreebok
Old Jul 06, 2011, 06:29 PM
READY!
shafferama's Avatar
seattle, wa
Joined May 2008
I had maybe a half dozen Guillows build under my belt when I built the MM J3 but it was the first plane I built for electric powered flight. It was a good place for me to start and I'll bet it'll work out well for you. The only hiccup I can recall was the sheeted area around the nose. Tip: don't lose your patience when you install those sections.
As for flight characteristics...as they say..."Flys like a Cub" This plane is a beaut!
Keep us posted!
Old Jul 06, 2011, 07:03 PM
ajreynolds is offline
Find More Posts by ajreynolds
I need a bigger garage...
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Great choice for a first build. The clipped wing version was my first kit build as well. I'm still happily flying it four years later (although I need some new batteries now, four year old lipos aren't cutting it any more...) The cub can really fly nice and easy, you're going to like it.
Andy
ajreynolds is offline Find More Posts by ajreynolds
Old Aug 06, 2011, 12:31 AM
Joined Nov 2010
It arrived a couple of weeks ago.
Been clearing an area to build!.
Have only opened the bags, and had the plans copied for the inevitable bugger up of the originals with a knife, glue, etc etc.
Looks like it will go together pretty quick.
Discussion Mountain Models J-3 Cub released buzzltyr Scale Kit/Scratch Built 12 May 28, 2009 01:06 PM
Discussion Need plan for scale 70'' Piper J-3 Cub (going to build in 6mm Depron) ! ruben Scale Kit/Scratch Built 8 Mar 13, 2006 07:29 PM
World Models J-3 Cub EP What Servos? karl51 Parkflyers 4 Sep 02, 2005 08:14 PM
World Models J-3 Cub and floats?? BrandoUno Waterplanes 3 Jun 03, 2005 10:23 AM
World Models J-3 Cub-48 Trroscoe Aircraft - Fuel - Airplanes (FS/W) 0 Oct 27, 2003 03:20 PM
