Old Jan 12, 2008, 09:58 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
shrub wacker,
GREAT looking build you've got going on there! I have no experience with the 400XT but I felt compelled to comment on such a nice looking Cub!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Jan 12, 2008, 11:13 AM
buzzltyr is online now
Find More Posts by buzzltyr
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Glenn, I used the 400XT in my beta. I don't recall any problems clearing the cowling. But I was using a collet type prop adatper, rather than the prop saver type. Maybe that put the prop out far enough. My suggestion would be to put some washers between the motor and the ply mount to move it forward. Alternatively, perhaps you could slide the cowl back down the fuselage a bit more.
Let us know how you make out!
Mark
buzzltyr is online now Find More Posts by buzzltyr
Old Jan 12, 2008, 01:31 PM
shrub wacker is offline
Find More Posts by shrub wacker
Got Epoxy
shrub wacker's Avatar
Salisbury Ma
Joined Dec 2004
Thanks aeronca, I know it can be built quite quickly but I've been taking my time on it.
Mark , I'll locate a collet adapter to see if if that will work. I thought of maybe heating up the cowl a bit to widen it some as well, I sanded the balsa pretty good around fuselage to make sure it would fit before I covered the fuse, once covered with the So-Lite it just didn't slide on as far.
I'll keep ya posted,
Thanks again
Glenn
shrub wacker is offline Find More Posts by shrub wacker
Old Jan 12, 2008, 04:28 PM
Got Epoxy
Salisbury Ma
Joined Dec 2004
Found one, it was right above my head the whole time I pulled it off my old Sig Lil Rascal that is not the prop Im using just a test fit and it will work and just monkying around with that HZ S Cub cowling but what if
aeronca thanks again.
Glenn
Old Jan 12, 2008, 11:39 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Ooohhh... I like the looks of the Super Cub cowling!
I bet it could be made to work with a lil' help!
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 13, 2008, 09:14 AM
Got Epoxy
Salisbury Ma
Joined Dec 2004
It could work but you would have to remove about 3/4" of cowling right down the center and mate it back together, with a little re-work I think it could be done , If ya mess one up it's only 2 bucks and change
Glenn
Old Jan 14, 2008, 12:44 PM
citabria is offline
Find More Posts by citabria
Under tension
citabria's Avatar
Johnstown, Colorado
Joined May 2002
Super Cub!
I think that Super Cub cowl looks excellent! I have a MM J3 Cub kit waiting to be built but would really, really like to make it into a Super Cub. I think for the the $2 investment, it's worth a try.
Is there any visible difference on the Super Cub vs. the J3 besides the cowl and flaps?
Scott
citabria is offline Find More Posts by citabria
Old Jan 14, 2008, 02:58 PM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Scott, There are several differences. By the way, not all Super Cubs had flaps. Most if not all of the early 95 horsepower ones didn't have them. There is also quite a bit of variation in the cowls amongst the Super Cubs. Most of the later ones had the rounded, tapered tunnel on the bottom that housed the air cleaner.
From the windshield pillars forward, the fuselage is shaped differently. The J-3 is wider at the top, where the Super Cub is about as wide at the top as at the bottom. The Super Cub has a lot less taper from the windshield forward to the nose.
The skylight at the top of the cabin is much larger on the Super Cub.
The Super Cub rudder is rounder at the rear, and a little more pointy at the top.
The Super Cub also has balancers on the ends of the elevators where the J-3 elevators terminate straight out from the hinges.
Most Super Cubs have propeller spinners, most J-3s don't.
Some of the later Super Cubs have metal flaps and ailerons.
I'll try to post some Pic's to show some of the differences.
AmpAce
AmpAce is offline Find More Posts by AmpAce
Old Jan 14, 2008, 03:55 PM
citabria is offline
Under tension
citabria's Avatar
Johnstown, Colorado
Joined May 2002
AmpAce,
Wow, thanks! That's a lot of great info and photos too.
Scott
Old Jan 14, 2008, 06:24 PM
AmpAce is offline
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Scott, I've been through a conversion sort of like this. I converted a Dare 60" J-3 kit to a Super Cub. There is a long-winded thread about it, (and much else), over in the "Scale Electric Planes" Forum.
The thread is found here: http://www.rcgroups.com/forums/showthread.php?t=241260
AmpAce
Old Jan 14, 2008, 06:53 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Scott- AmpAce is the Cub guru around these here parts..
Old Jan 14, 2008, 07:35 PM
Got Epoxy
Salisbury Ma
Joined Dec 2004
I'd say . Wow what a thread Its going to take me the rest of the night to read through it, nice job Amp It gave me incentive to head back in the basement to work on mine
Glenn
Old Apr 11, 2008, 11:12 AM
Mountain Models is offline
Find More Posts by Mountain Models
BYOP - Build Your Own Planes
Mountain Models's Avatar
United States, WI, Appleton
Joined Mar 2001
In preperation for our move next week, Cub kits are on sale for 10% off through the weekend:
SALE
I already damaged the Cub wing on the way back from the Arizona show, so I need to build another one I think...
Mountain Models is offline Find More Posts by Mountain Models
Old Apr 30, 2008, 08:31 PM
Doogman is offline
Find More Posts by Doogman
Doogman's Avatar
Joined Dec 2003
The week I put the finishing touches on my cub! The plane had already flown 4 or 5 times by the time I took these pictures. I wanted to make sure I got all the kinks-out of the plane before applying the graphics.
The plane is your basic MM J-3 cub with the full 48" wing. For covering I used dark yellow solarfilm. LED marking/strobe lights on the wing tips with controllable landing lights. Balsa bungee bags on the gear and ping-pong wheel covers add a bit of detail. Vinyl graphics by Callie.
Power is supplied by a CustomCDR cool-wind single via a Phoenix 25 controller using a 2s 1300 Loong-Max battery and a 9060 prop. Receiver is a Berg 7P with 2 HS-55 and 2 GWS Pico servos.
The plane's empty weight is a portly 14.0 oz with the AUW of 16.8 oz. Unfortunately, the plane came out a bit heavier than I wanted (too many options), but it still seems to fly fine.
The first few flights were ROG, but generally the grass is a bit high at my field for this plane so lately I've just been hand-launching it. My field is kinda small, so the big worry for me was whether the plane would be nimble enough at low speeds to feel comfortable in flight. No problem. Usually I just roll the plane a bit and use the very effective rudder to complete the turn.
Even with just the 2s pack, I'm still only cruising around at 1/2 throttle. For any more aerobatics beyond simple loops some more power would be required, which is easily obtained with a change to a 3s 1000 mAh pack and a 8040 prop. So far, though, I'm completely happy with the low, slow and looking good flying for which this plane seems very well suited.
I still consider myself a "noob" with balsa planes, but I consider this an excellent kit for beginners. You get good instructions and a very complete kit.
Doogman is offline Find More Posts by Doogman
Old Apr 30, 2008, 08:53 PM
echoplanar is offline
Find More Posts by echoplanar
echoplanar's Avatar
Lafayette, CA
Joined Aug 2002
Very nice plane! If that is your noob work I can't wait to see what you do a few builds from now! I like the lights too.
-Jon
echoplanar is offline Find More Posts by echoplanar
Discussion Mountain Models J-3 Cub released buzzltyr Scale Kit/Scratch Built 12 May 28, 2009 01:06 PM
Discussion Need plan for scale 70'' Piper J-3 Cub (going to build in 6mm Depron) ! ruben Scale Kit/Scratch Built 8 Mar 13, 2006 07:29 PM
World Models J-3 Cub EP What Servos? karl51 Parkflyers 4 Sep 02, 2005 08:14 PM
World Models J-3 Cub and floats?? BrandoUno Waterplanes 3 Jun 03, 2005 10:23 AM
World Models J-3 Cub-48 Trroscoe Aircraft - Fuel - Airplanes (FS/W) 0 Oct 27, 2003 03:20 PM
