Old May 06, 2007, 08:29 PM
fuzzyhead is online now
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
Thanks Tommy. Sounds like the best approach. Got access to plenty of longer screws. This is my first GWS b/l motor. Not sure why the shafts are soo short. After that the build is done. Everything else is cosmetic. Hope to maiden her this weekend.
fuzzyhead is online now Find More Posts by fuzzyhead
Old May 07, 2007, 11:47 AM
Mountain Models is offline
Find More Posts by Mountain Models
BYOP - Build Your Own Planes
Mountain Models's Avatar
United States, WI, Appleton
Joined Mar 2001
Hey guys,
On the motor, try using a small 1/16" or 1/8" shim behind the motor mount. I'm not sure why it's short, though... it was very close on mine, but it still fit??? Sorry about that.
Brian
Mountain Models is offline Find More Posts by Mountain Models
Old May 09, 2007, 06:09 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Not sure how, but the prop problem is solved. I added spacers both behind the motor and mount. Stopped by my LHS to find props that might have a longer hub. Suddenly the light bulb came on. I pulled out all the spacers and used a collet type prop adapter. Guess what? All fits nicely with more than enough clearance. Haven't built in a while and missed the obvious. Anyway, I'm done except for decals. Hope to maiden this weekend. Thanks to all for your help.
Rick
Old May 12, 2007, 05:09 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Finally finished. Just a bit to breezy today for the maiden. Tomorrow morning should be good. Not to impreesed with my covering job but that is one of my weak points. Looks real good from 5 feet away though.
The decals are from Parkzones J-3 Cub. My LHS had a set for $4.95. You can order them from Hobbytown USA among other places but add $5 shipping. The wing letters/numbers are a little bigger than I'd like but look ok. I used the motor decal to ad the exhaust pipe and the Continental decal on the silver covers. Of course the Cub decal was worth the price. Don't have a scale so not sure what the auw is. I am using 2s 1600 which adds a little extra. Hoping for the best tomorrow.
Rick
May 13
The maiden didn't go quite so well. The weather was good. Set her down and throttled up. Went about 6 feet then made a hard left turn. Tried again and the same result but this time pulled right. For some reason the wheels were sticking. Pulled them apart and cleaned up the axles. In my haste I glued the wrong tubing to the axle. Have to wait until my LHS opens up Tuesday to get more tubing. Very frustrating.
Old May 15, 2007, 09:04 PM
ajreynolds is offline
Find More Posts by ajreynolds
I need a bigger garage...
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
I'm getting close on mine as well. I've finished it in red Solite. I'm having a problem painting the cowl though. I've tried some Pactra racing finish that I had sitting around and some Model Master Acryl (Italian red is very close to red Solite), and both of them peel off the plastic really easily.
This is my first cowl, so maybe I'm missing something. Is there anything I need to do to prepare the cowl for painting? Is there a better brand of paint to use for this? I'd really appreciate any help.
I'll post pictures once I have a decent looking cowl.
Thanks!
Andy
ajreynolds is offline Find More Posts by ajreynolds
Old May 16, 2007, 10:25 AM
Joined Mar 2001
Andy,
I always was plastic pats with just a bit of dishwashing liquid and make sure it's very well rinsed afterwards.
For a good Red So-Lite match, try the Tamiya Bright Red (TS-49). It's what I used on my clipped wing cub and it looks like a good match.
Brian
Old May 16, 2007, 12:50 PM
56S is online now
56S
Find More Posts by 56S
56S
Certified Balsa Breaker
56S's Avatar
Joined Nov 2006
Originally Posted by ajreynolds
Is there anything I need to do to prepare the cowl for painting? .
Thanks!
Andy
I used ajax or comet scouring powder on plastic prior to painting. A soft toothbrush works well. For primer, instead of the expensive two part vari-prime auto primer, pick up a can of self etching primer from NAPA. Last time I checked they were about 7 bucks for a standard rattle can. Let that dry and scuff prior to color coat.
56S is online now Find More Posts by 56S
Old May 16, 2007, 05:24 PM
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Thanks guys, I'll try that out. I'm taking too long building this thing... I want to get it in the air!
Andy
Old May 27, 2007, 06:55 PM
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Finally done!!!
I finally finished and maidened mine today (clipped wing version). I was pretty nervous, being my first kit build and all, but everything appears to have come out straight and the plane flew great! My setup is as follows:
400XT
TBird 18 ESC
APC 8x3.8SF
FullyMax 1050 3S lipo packs
HS55 servos for the tail
GWS Naro servos for the wing
AUW is just over 16 oz.
I definitely recommend putting thin carbon rods on the inside of the cabin pieces, as suggested by someone earlier in the thread. I would have broken the balsa several times over during building and covering.
Great kit Brian!
Andy
Old Jun 18, 2007, 12:20 PM
Figure.N9ne is offline
Find More Posts by Figure.N9ne
Miami, FL
Joined Mar 2007
i just recieved my cub kit today, everything appears to be in great shape and will start building as soon as i get home. this is my second attempt at a kit, my frist being a fundango that ended prematurely when my cleaning lady smashed the wing i just finished building, but wow this cub seems 500x's better quality and 500x's easier to build. kinda worried about the covering, but i'll cross that bridge when its reached.
i'm planning on using an esskay 400xt and the recommended servo's. havent decided on a prop yet. only issue i have is that i have 6 3s2100mah lipo's and would really prefer not to buy something smaller. will this be toooooo heavy or will it be doable? if it'll ruin the models characteristics i guess i'll spring for some 3s1320mah's as i've been wanting a couple but i'd really like to use the 2100's. Brian, what do you think of using the 3s2100's? anyone tried it? if anything i'll give it a try and if it flies to heavy i'll get the lighter batteries.
Figure.N9ne is offline Find More Posts by Figure.N9ne
Old Jun 18, 2007, 12:26 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
*cough* L-4.. *cough*
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jun 18, 2007, 02:02 PM
buzzltyr is offline
Find More Posts by buzzltyr
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Yani, the 2100's will add a couple of ounces, at least, I would think. If you are building the stock J-3 (not clipped wing), it will probably handle the weight OK. But if you want nice slow flight, I'd suggest getting lighter batteries. I'm flying mine with the 400XT and a 3 cell 800mAh battery. I'm still flying at less than half throttle.
Enjoy the build, as it will go quickly!
Mark
buzzltyr is offline Find More Posts by buzzltyr
Old Jun 18, 2007, 02:26 PM
Miami, FL
Joined Mar 2007
Mark
yea its the full size wing, i wanted a slow relaxing plane with long flight times. i guess i wont get that with the 3s2100, apart from long flights but i'll try it just to make sure, no harm in experimenting.
Old Jun 18, 2007, 04:28 PM
Joined Mar 2001
*caugh* getting there... strengthening some areas...*caugh*
On the 2100 packs, it'll be a couple ounces heavier, It won't fly quite as slowly, but it should still be fairly slow.
Old Jun 18, 2007, 04:31 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
*cough* youdaman.. *cough*
Discussion Mountain Models J-3 Cub released buzzltyr Scale Kit/Scratch Built 12 May 28, 2009 01:06 PM
Discussion Need plan for scale 70'' Piper J-3 Cub (going to build in 6mm Depron) ! ruben Scale Kit/Scratch Built 8 Mar 13, 2006 07:29 PM
World Models J-3 Cub EP What Servos? karl51 Parkflyers 4 Sep 02, 2005 08:14 PM
World Models J-3 Cub and floats?? BrandoUno Waterplanes 3 Jun 03, 2005 10:23 AM
World Models J-3 Cub-48 Trroscoe Aircraft - Fuel - Airplanes (FS/W) 0 Oct 27, 2003 03:20 PM
