Old Sep 05, 2006, 12:41 PM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Performance of PZ Mustang, Focke Wulf, HZ Supercub with Lipo?
I am considering springing for a 3s 2100mah pack for use in my Focke-Wulf (and my Super Cub that's coming in the mail as we speak)... but I am wondering what kind of performance I should expect..
Has anyone tried this? Is vertical climb possible? What kind of run times have you found? Is it necessary to add nose weight?
The guy at the LHS said that the electronics in the new HZ Supercub are the same as the PZ units and can be made to accomodate Lipos by moving a jumper...he verifided this by talking with a Horizon Hobby tech..
Is this news to anyone else?
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Sep 05, 2006, 06:53 PM
Joined Jun 2005
nobody?
Old Sep 06, 2006, 12:50 AM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
if the rx/esc units are indeed the same and i have no reason to suspect they are not, then, yes, what the horizon hobby tech advised is correct...by removing a jumper on the rx/esc board (manual should state which one), the rx/esc is then programmed for the correct lvc for lipo use...
as to the fw190, the stock setup generated peak input watts of 123.5...using a 3s 2100 lipo, it generated 194.2 peak input watts...over a 33% gain in watts...as to flight time, you can expect 10-15 mins depending on throttle use...
i believe the super cub uses the same motor and prop as the fw190...just not sure if the same gearbox/gearing is used...
gunracer is offline Find More Posts by gunracer
Old Sep 06, 2006, 01:53 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
It won't go vertical, but it's faster, flies longer and lighter. I think it's a good mod. I prefer a 1500 mah 3S pack. The 2100 ought to fly for 30 min.
blucor basher is offline Find More Posts by blucor basher
Old Sep 06, 2006, 08:13 AM
Joined Jun 2005
Thanks for the info!
Would a TP 3s 1320mah be overtaxed in this application?
Old Sep 06, 2006, 08:52 AM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
with a 1320 you'll have to add dead weight to the FW-190. A regular 2100 PL wont balance it in the stock position. IF you put it vertically up front it will balance it out. The 1320 would require dead weight so you might as well get some usefull battery power with the weight.
I get about 20 min of flying out of a 2100 lipo on the stock motor and gearbox.
Steve
Vintauri is offline Find More Posts by Vintauri
Old Sep 06, 2006, 12:58 PM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
with a fresh 15c 3s 2100 lipo, the fw190 will go vertical for a short distance...
Discussion PZ Focke Wulf 190 Brushless Mods Thread Tommy D Electric Warbirds 153 Apr 08, 2015 11:21 AM
Question Parkzone P-51 Mustang or Focke Wulf 190? UKPilot Electric Plane Talk 27 Dec 12, 2006 11:21 PM
Poll the Mustang or Focke wulf???? ace128 Electric Warbirds 93 Aug 31, 2006 04:51 AM
Help! PZ FOCKE WULF 190- Is mine repairable? Help! Smokescreen38 Parkflyers 21 Jun 11, 2006 08:57 AM
For Sale Great Planes Focke Wulf 190A With OS61 and Spring Air Retracts Pilot44 Aircraft - Fuel - Airplanes (FS/W) 11 Sep 18, 2005 01:18 AM
