Joined Sep 2006
A first RC plane? (balsa and styro construction) need clear plans!!!
Hello!
A few days I had an idea to build a Little Extra from these instructions http://www.rcgroups.com/forums/showt...ns#post1650046 but now I'm a liittle bit confused because it looks like it's not a good first model and there will be much trouble with speed because it has to much wing load. The thing that was the purpose of this choice was the way the plans and instructions look....they are very clear! It's important to me because I'm not a very experienced builder but I want to build the plane myself (without bying a kit:P)And there is the point: Have You got any plans of building a good trainer with a wing span about 90-100cm, for a speed 400 motor, with 4 channel steering (elevator,ailerons,rudder, motor rpm)????? Aha...I would like to build it the same way the little extra is done: balsa construction of fuslage and wing cores made of styro! If You find someting that wood be useful for me please give me a link or send it to my e-mail patryk@profnet.pl I'll be very pleased because i was looking for plans many hours in the internet and i can't find anything suitable ![]() Thanks for all! BW |
Joined Jun 2006
If this is going to be your first plane, and ARF trainer would be the easiest way to go.
If not then an established kit trainer would be my next suggestion. Making a plane from plans is quite a bit more involved, it's a lot easier if you have some experience first before tackeling one. Most of the people here seem to think a slow stick is a good first plane, check out the threads, or post one looking for a trainer plane. If you are still determined for a plans built I'll see what I can get you. check out this thread http://www.rcgroups.com/forums/showthread.php?t=566066 |
If you want to scratch build your first plane, it is going to be a little bit hard. When I say a little bit hard, I mean really hard. First of all, you probably won't know what half the stuff is. Second of all, if you have no experience building a plane from scratch, there is no way you would be able to build it. There is plenty of arf planes out there that are really really good. For example, the gws slow stick (which I personally hate) which a really lot of people say it is good. Arf planes still take a long time to build if you are new to rc airplanes. Also one much similar to the gws slow stick, the gws tigermoth. It looks sooooooooo much better than the slow stick. It is a biplane, but it flies just as good as the slow stick. It is only about 5 dollars more than the slow stick. Anyways, good luck on finding or building a plane
Once again, I wouldn't reccommend building your own rc airplane from scratch. Bill |
S. Calif.
Joined Mar 2005
I would recommend against building your first plane, unless you have someone who can provide a lot of guidance, especially with setup and teaching you to fly. Otherwise I'd recommend getting a tough trainer like RTF like an Easy-Star or T-Hawk, which will get you in the air quickly and survive the inevitable crashes. Also get a simulator of some sort, if only FMS. Have fun and good luck!
Philip |
| Thread Tools | |
| Help! need help on picking first rc plane | bbomber | Electric Plane Talk | 16 | Oct 19, 2006 10:43 AM |
| First RC plane ? | dvint | Sport Planes | 4 | May 05, 2002 11:20 AM |
| First RC Plane for me and Kids | NC Joe | Electric Sailplanes | 11 | Apr 12, 2002 10:53 PM |
