Old Sep 04, 2006, 11:41 AM
flying evader is offline
Find More Posts by flying evader
Back in the game
flying evader's Avatar
United States, TX, Frisco
Joined May 2006
V-Tail, T-Tail, Conventional? Where to go?
Hi There,
Can someone provide a link or provide a good description of the pro's/con's of each tail characteristics? I know the basics such as:
Conventional Tail
Pro's: Ease of construction, sturdy
Cons: Any?
T-Tail
Pro's: Places Stab on top of wing turbulence which can lead to smoother flights, Looks (looks neat!)
Cons: Not as easy to construct, fragile, Tail heavy plane may need significant nose weight
V Tail
Pro's: Less drag, combines 2 functions (ele, aile-rud) in one
cons: medium diffculty (as compared to conventional)
Other thoughts regarding:
Overall weight of model? ability to fly in windy days? stability? ability to detect thermals? compatible with dihedral? Poly-D?
Any other comments or links are appreciated!
flying evader is offline Find More Posts by flying evader
Old Sep 04, 2006, 01:07 PM
Langenase is offline
Find More Posts by Langenase
Ace of glue
Langenase's Avatar
Barcelona, Spain
Joined Apr 2006
Visit
http://www.charlesriverrc.org/articles_modeldesign.htm
Lots of info on V-tails, hope it helps.
I myself prefers the T configuration for smoother control and easyness of assemble/disassemble, but recognize its inherent building complications (scratchbuilder here) and weight increase just where you want less weight
Langenase is offline Find More Posts by Langenase
Old Sep 04, 2006, 04:43 PM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guy,
Bob in Seattle here. I have been in this hobby for 3 1/2 years now. I have one of each kind of tail in my collection of planes. Maybe it's just because I'm new at this, but when they are up in the air, the differences between them are very suttle. The V tail on my Omega tends to do the wag wag, dog tail dance at slower speeds. My T tail hasen't broke off yet. Some folks think they tend to break off on hard landings. My normal tail plane flies just fine. For me, the work involved in doing a V tail rigging was very hard, my first one. I think in the end, it's really about what you like to see going through the sky. You could debate this for years. They all work. Right now I am leaning towards the "standard" tail design. Go with what you like visually and what your confortable with. There is no best one answere. It's a personal thing. Good luck.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Sep 05, 2006, 03:15 PM
Ace of glue
Langenase's Avatar
Barcelona, Spain
Joined Apr 2006
Originally Posted by flying evader
........Conventional Tail
Cons: Any?............
I forgot this one. With a conventional tail, depending of the type of terrain you make your landings, there are much more risks of getting your stabilizer damaged or even torn off than with T or +......
Old Sep 05, 2006, 06:52 PM
MrThermal is offline
Find More Posts by MrThermal
MrThermal's Avatar
NE Indiana
Joined Sep 2001
No problem, just use a bamboo skewer heated into a U bolt shape roughly and
mount into 2 alum tube pieces inside fuse.
Broke my first one the other day after using for more than 125 flights.
Came home and made a new one in about 20 minutes, installed and
flew next day.
I call them landing skegs
Great for protecting conventional tails
Steve
MrThermal is offline Find More Posts by MrThermal
Old Sep 07, 2006, 11:23 PM
Back in the game
Joined May 2006
i looked at the links.. great resources!
Old Sep 08, 2006, 05:56 PM
66tbird is offline
Find More Posts by 66tbird
To many projects
66tbird's Avatar
USA, AZ, Litchfield Park
Joined Aug 2004
After building/designing hundreds of gliders, the V tail/ conventional tail question really comes down to that quote above. Plus if you tend to ground loop(spin) a little, the V tail will rise, which tends to keep the nose down.
If its a heavy ship that lands at mach 7 on a smooth field, build what you like
66tbird is offline Find More Posts by 66tbird
Old Sep 09, 2006, 08:02 AM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Mr. Thermal,
Bob in Seattle here. Where in the fuse did you mount it ? Under the tail ? or at the CG under the wing or ???? Can you post a photo for us unimaginative people. Thanks. Bob in Seattle
Old Sep 10, 2006, 06:26 PM
MrThermal's Avatar
NE Indiana
Joined Sep 2001
Originally Posted by Bob Cook
Hi Mr. Thermal,
No rocket science here Bob. Knew the tail would be in danger @ landings so I decided to protect it when building the fuse. I came forward of the end/fuse ~8" to a former and blocked/glued an AL tube in verticle, flush with bottom. Did the same thing ~4" rear of that (or next former). Made sure the pushrods were clear. AL tubing was whatever I had on hand that would work with my bamboo skewers.
Used a candle flame to heat/bend the water soaked bamboo.
Go slowly ! ... I gained about 2.5" of clearance below bottom/fuse
Full disclosure: Knew about the bamboo bending from my kite building days which I still do to some degree.
Sorry no pix, ..... Steve
Old Sep 11, 2006, 04:44 PM
Bax is offline
Bax
Find More Posts by Bax
Bax
Central Illinois
Joined May 2003
Or you can make a wire skid and have it below the tail. Did that on an old glider. Made it just long enough so that the stab tips would not touch the ground when the wingtip did.
bax
Bax is offline Find More Posts by Bax
Old Sep 15, 2006, 05:06 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
V tails are much harder than T or cross tails at getting the incidence or decalage set perfectly without a lot of trial and error.
T
target is offline Find More Posts by target
Old Sep 15, 2006, 05:48 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Bob in Seattle here. Target is VERY right about that. I have an Omega V tail that flew really bad for a long time. It turns out that the V tail and the wing were mis- alligned by 3 degrees !!!! I couldn't move that tail, I had to move the trailing edge of the wing up about 1/4 " to make the decalage equal. I will now check before I glue any V tails for that problem. Invest in 2 Robarts incidence meters. That's how I found the error in the alignment. Bob in Seattle
Old Sep 16, 2006, 04:05 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Conventional Tail
Pros: Easy construction, separate elevator/rudder
Cons: Highest drag, can be vulnerable when landing
T-Tail
Pros: Low drag, easy rigging, separate elevator/rudder, won't snag when landing
Cons: Heavier, more complicated construction and linkages
V Tail
Pros: Low drag, lightweight, easy construction, unlikely to snag when landing
Cons: Combined elevator/rudder, more difficult to install accurately
I put in separate elevator/rudder as a pro because it's often considered better for aerobatics since there's less coupling and more power is typically available on each function.
Aio_1 is offline Find More Posts by Aio_1
What is the advantages of a V-tail over a t-tail? Mat Modeling Science 12 Feb 22, 2005 12:15 PM
fs: sokol, filip 400 V/T tail. Top models nike. Astro, jeti, graupner mpjet.... snowfallonme Aircraft - Electric - Airplanes (FS/W) 9 Mar 15, 2004 09:07 PM
FS: filip 400 rg. V/T tail. NIKE astro, jeti, sokol, graupner. snowfallonme Aircraft - Sailplanes (FS/W) 0 Mar 13, 2004 01:38 PM
Filip 600 - V or T Tail adrian Electric Sailplanes 7 Apr 15, 2003 02:01 AM
v-tail mini pleaser can't get off ground nhearnest Parkflyers 3 Jul 24, 2002 10:52 AM
