| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#31 | |
A man with too many helicopter
Sometimes you can purchase one with an engine and muffler then sell the parts you don’t need and get a cheaper helicopter that way. You have lots of parts that you can sell on ebay (engine, muffler, fuel tank, header tank, motor mount, remote glow cable, …) RC
#32 |
wow! thanks RC Man!
i am awaiting (hopefully) some gear from the US for the conversion.... Axi 4130/16 and a Castle Creations HV 85. looks like the ttpacks is the way to go! ill order one in then ![]() cheers |
#33 |
Renewed interest
not many have had luck with the Axi motors in helis, just keep it in mind.
#34 |
oh....
can you please elaborate? even for simple AP work? |
#35 |
Renewed interest
The Axi's usuall run hot , very hot in heli apps. There were cases of magnets falling out quite a while back and ever since then most stear clear. You hardly see or hear about anyone using an Axi in helis these days.
#36 |
after doing some research, it seems that the Axi motors need to be kept cooler than 130°C to avoid damage.i may have to direct some of the propellor air over the engine. i cant see a top mounted engine being any good for the centre of gravity... ill have to see when i have the engine in my little hands... or even build a little protoyype of the motor and see where it could fit.
cheers |
#37 |
I got it flying yesterday and it really flies beautifully. It is much smoother than my Raptor 50 – just the thing for AP or someone who wants a real easy to fly helicopter – incredibly smooth. The power system I have is only good for 1750-1800 headspeed so it is not a wild 3D helicopter but very nice for come relaxing sport flying.
I was a little concerned that this motor would run hot but it stayed about 140F with an air temperature of 72F. This is cool for Neu motors, as they are good to 200F. I was using an old TP 10s2p 4200 pack that had several hundred flights on it. I did one flight at 1550-1600 headspeed mostly hovering and flight to simulate AP work. At a weight of 11.6 lb it draws about 18 amps. This is with Mavrikk 680mm CF blades and stock tail blades. With the 10s LiPo that comes out 62.8 watts per pound. I would say that if you use 65 watts per pound you would get a very good estimate of the flight time for an AP application. Be aware that the power requirement goes up rapidly with headspeed so if you run higher headspeed you flight time will go down a lot. I got a PM from Steve Neu indicating that the helicopter version of the big ORK (1915 with fan and new design of rotor to shaft attachment) would ship from the factory late this week so they should be in stores in a week or two. This should be the ultimate power for those who want a large 3D helicopter. All in all this project turned out better than I expected RC
#38 |
Big Kid / Big Toys
Real nice work in short order RCMan.
#39 |
Hear are some photos of the complete helicopter. I used two TP4200 5s2p packs, one in front under the radio tray and the other in the fuel tank area. This helicopter has lots of room for batteries. The Phoenix HV85 ESC is also in the tank area. I use a UBEC for radio power.
In this configuration it is slightly lighter than with the OS70 and an empty tank of fuel. Does anyone know the conversion from fuel volume to weight? RC
#40 |
Das Universus Elektrikus
A gallon of alcohol weighs about 6.6 lbs and I guess the tank on that raptor is about a quart so it should hold about 1.6 lbs of fuel. Oil being about 20% by volume should weigh the same or a little less per unit but I really don't know what the weight of Klotz is
Al |
#41 | |
It sounds like I am way lighter than a nitro raptor with a full tank of fuel. With some lightweight upgrades and a little larger propulsion system the Raptor 60/90 will definitely fly better than the nitro version. I am really amazed that there aren’t more Raptor 60/90 EP’s flying. It’s really a very easy and low cost conversion. RC
#42 |
Renewed interest
Job well done RC, the speed in which you moved is impressive.
#43 |
dam straight! my raptor 60 is sitting on top of my bench waiting for paypal to send me its stupid location letter and then i can finally get my parts sent over from the states.
well done RC Man, that thing is hot! |
#44 |
Big Kid / Big Toys
I am suprised that this has not been done before , especially since the adapters
fit so easily. I have sold my swift to satisfy the wife so that I can add a 60 or 90 to the fleet, too many heli's in the shop and I get the old , "you can't fly them all" routine kudos again to RCMan and his quick build MT |
#45 |
For those who are interested in a wider choice of pinion gears there is an alternate conversion method that you may be interested in. Use a 5mm shaft and couple then you can use standard 5mm mod 1 pinion gears. Logo, TT, Swift and others use these pinions and there are available down to 8t.
Boca has 5x15x5mm and 5x19x6mm bearings that can be fitted to the bearing block so you can use a 5mm pinion shaft. The Raptor bearing block will have to be modified slightly for the wider 5x19x6 bearing since the bottom bearing grove is only 5mm wide. A few seconds with a dermal and it will drop right in. SDP-SI.com has 5mm shafts and couplers. They have 5mm to 5mm and 5mm to 6mm shaft couplers so you can use outrunners with 6mm shafts. If you have problems finding these parts I will look up the link. This is the method that is used on the XeroG 600EP when mounting a motor underneath without The Box and works very well. RC
| Thread Tools | |
| For Sale TT Raptor home build ccpm&electric conversion kit | Hsin Liu | Aircraft - Electric - Helis (FS/W) | 0 | Jun 13, 2007 10:01 PM |
| XeroG 600EP Electric Raptor 50 CCPM conversion kit in stock | rcheliman | Electric Heli Talk | 2 | Dec 21, 2005 04:15 AM |
| Raptor Electric Conversion Kit | Steph280 | Aircraft - Electric - Helis (FS/W) | 1 | Oct 15, 2004 02:01 PM |
| Does LMH offer a gas to electric conversion kit? | totalboss | Electric Heli Talk | 1 | Nov 24, 2002 01:51 PM |
| Great Planes electric conversion kit | crash rebuild | Power Systems | 4 | Sep 08, 2001 01:58 AM |
