Old Sep 04, 2006, 12:11 AM
Ted Campanelli
Ted Campanelli
Guest
n/a Posts
Help needed with Saito 82 exhaust manifold.
The stock "hard" manifold on my 82 is about 1/2" - 3/4" to short and the
flex exhaust is way to long.
I have had no luck searching this.
Does anyone make/have any of the following:
1. A longer hard exhaust manifold (12 mm dia ) for the 82. (about 1 1/2"
longer than a stock manifold would be ideal )
2. A 12mm threaded female union. (I can join 2 stock manifolds together)
3. A 12mm threaded pipe nipple. (think plumbing )
Any suggestions ? I am certain SOMEONE must have had a similar problem
and found a way to solve it without welding 2 stock exhaust mainifolds
together.
Old Sep 04, 2006, 04:11 AM
MLB
MLB
Guest
n/a Posts
Re: Help needed with Saito 82 exhaust manifold.
> the flex exhaust is way to long.
> 1/2" longer than a stock manifold would be ideal )
> together.
Hello,
I have a Saito FA-56, with a 10 mm metric manifold. When I needed a
replacement I found a perfect fit in the home appliance local store.
(threaded tube used to make table lamps).
For your 82 you need to find 12 mm metric bolds and have to bore it at
the right diameter.
Its better to use bolds instead of the threaded tube I found because of
the better quality of the threading.
Hope to help you,
MLB
Old Sep 04, 2006, 08:11 AM
Robert Scott
Robert Scott
Guest
n/a Posts
http://www.korlokusa.com/products/tube_fittings/uu.htm
Good flying,
desmobob
"Ted Campanelli" <tcamp@grumpyoldmen.com> wrote in message
news:YTMKg.14665$1f6.9311@newssvr27.news.prodigy.n et...
> Any suggestions ? I am certain SOMEONE must have had a similar problem and
> together.
Robert Scott
Robert Scott
Guest
n/a Posts
Ooops... that's for tubing. Anyway, Google 12mm fittings and see what comes
up.....
Good flying,
desmobob
"Robert Scott" <desmobob@earthlink.SPAM.net> wrote in message
news:cqUKg.5882$xQ1.3536@newsread3.news.pas.earthl ink.net...
> Good flying,
> desmobob
>> together.
Sold or trade hangar 9 aresti with saito 82 RTF everything needed drogue4027 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 04, 2007 07:07 PM
Help needed with biplane dimensions Rekit Power Systems 2 Apr 11, 2002 10:22 PM
Hornet Help Needed With Ccpm Mixing JUSTGLUEIT Electric Heli Talk 3 Apr 09, 2002 07:55 PM
Quick help needed with HF9, GWS gyro on the Housefly ruf Electric Heli Talk 1 Feb 01, 2002 09:47 PM
Picalo help needed with triming...I think mrtim Electric Heli Talk 1 Sep 08, 2001 01:49 AM
