Old Sep 03, 2006, 03:40 PM
MattinAZ is offline
Find More Posts by MattinAZ
MattinAZ's Avatar
United States, AZ, Gilbert
Joined Jan 2005
Yippee!
Eurofighter Maiden Flight Video
Well today was the day. Maiden flight went well despite a few aborted takeoff runs. Flew with canard function off. Programmed the canards as flaps and linked to elevons. I can fly with or without canard function but still able to trim canards in flight with rocker switch.
Plane flew well and my first landing was a high alhpa touchdown - way cool.
The begining of the movie is a little shaky but the wife got the video thing down after the first circuit. The last half of the flight I got her pretty well trimed and it picked up some speed.
Got in 4 flights
After I got her on the ground and inspected the plane noticed the fan blades were all chewed up and there was a layer of fine stone/dirt mix. Cant believe it flew as well as it did like that. One of my prior aborted takeoffs before the maiden ended up with the nose in a mud puddle. Should have checked.
Will change fan and fly her again soon. Plane will need more power but first have to fly it with a good fan. Then will try adding intake ring to fan housing as my internal ducting is probably not optimum. Then if all else fails to provide the level of performance I am looking for going to rebuild as twin.
http://www.rcgroups.com/forums/showa...hmentid=974815
Matt
MattinAZ is offline Find More Posts by MattinAZ
Old Sep 03, 2006, 09:03 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Hey Hey!!! Looks like it flew real nice Matt!
AND we got our field back!!
I look forward to seeing it out there! Man, I can see it flying REALLY nice as a twin!
But the Single fan version looks promising!
Good job!
Vic.
AceMigKiller is offline Find More Posts by AceMigKiller
Old Sep 04, 2006, 04:30 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Took her up again today with the new fan and it was a little better but not what I was looking for. Styffed a 4S pack in the plane and we were getting somewhere. Take off in about 60 ft and some good vertical performance.
Thought about rebuilding as a twin fan.
but then I had a better idea.....
Single minifan with Het 2W20 and 4S PQ 3700.
Old Sep 04, 2006, 05:23 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
wow that thing is going to be a rocket with mini and 2w,i would use a lot of glue.
good luck.
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Sep 04, 2006, 11:06 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
yeah budy! now your talking!
corsair nut is online now Find More Posts by corsair nut
Old Sep 05, 2006, 08:47 PM
TBolt is online now
Find More Posts by TBolt
TBolt's Avatar
United States, AZ, Chandler
Joined May 2004
Congrats Matt,
You can NEVER have too much power.
TBolt is online now Find More Posts by TBolt
Old Sep 06, 2006, 01:59 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
TBolt,
AGREEEED! Should be able to re- maiden on Sat.
Matt
Old Sep 09, 2006, 10:45 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
report,report,report
ben
Old Sep 10, 2006, 02:28 AM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Took it out Sat for re-maiden and think I have a bad speed controller. Could not get the Minifan into a high rpm. Might exhchange the motor/battery/esc with the one in my Kyo T33 Het 2w, 3S 4200, 45 amp esc and try again next week.
Matt
Old Sep 10, 2006, 08:59 AM
scratchandbash is offline
Find More Posts by scratchandbash
scratchandbash's Avatar
Grove City PA basement/park
Joined Feb 2005
Great job! Was just watching the Eurofighter on the Military Channel about 20 minutes ago. Looked like it had a nice wing area for flying, and then I saw this video.
Bill
scratchandbash is offline Find More Posts by scratchandbash
Old Sep 10, 2006, 08:52 PM
J. Kendrick is offline
Find More Posts by J. Kendrick
J. Kendrick's Avatar
Arizona
Joined Sep 2006
Hey Matt, this is Joey, i hope you get that power problem fixed, i think you have the right idea on whats going wrong...i'll video the EuroFighter anytime you want me to.
J. Kendrick is offline Find More Posts by J. Kendrick
Old Sep 20, 2006, 12:21 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
any thing new.
ben
Old Sep 25, 2006, 12:17 AM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Yes, Even though V1 was a simple box design it really flew well. I liked its flight characteristics.
Working on V2 - will be a more scale model and a twin fan. Currently working on the bulkheads in CAD. V2 will be in 6mm and 3mm depron with built up wings.
Work has been quite busy and has slowed me down a bit on this project.
Matt
Old Sep 26, 2006, 05:04 AM
just_steve51 is offline
Find More Posts by just_steve51
Joined Aug 2004
Congradulations on a great build........
I was considering buying the Greatplanes HYPERFOW with a brushless AMMO motor....
If you think the Weomac Midifan is better..........Pls say so, and save me from headaches and lost money........
Thanx Steve
just_steve51 is offline Find More Posts by just_steve51
Old Sep 27, 2006, 11:27 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Just steve51,
The minifan and hyperflow fan are two different sizes - 70mm for minifan and 56mm for hyperflow. If you want a scale look in a small airframe the smaller fans are the way to go. I think they are both great fans for thier sizes. It is just a matter of which fits in the size airframe you want, plus you need bigger batteries, esc, motor for the minifan which means more weight.
Matt
Video Eurofighter Maiden Flight Video MattinAZ Electric Heli Talk 3 Sep 12, 2006 12:03 AM
GWS A-10 Maiden Flight Video. hsuusa Parkflyers 21 Sep 11, 2004 10:40 PM
Yippee! RBC HUCK Maiden flight video (finally posted..) Jeremy_D Electric Ducted Fan Jet Talk 9 Oct 28, 2003 04:31 AM
liaudio's P-51 Mustang maiden flight VIDEO in Orlando Florida. LESLIEx317537 Parkflyers 15 Feb 25, 2003 03:37 PM
Wattage F-22 maiden flight video posted steve neill Foamies (Kits) 5 Sep 22, 2001 02:53 PM
