Old Sep 03, 2006, 02:34 PM
RetroFlight is offline
Find More Posts by RetroFlight
Retro
Iowa
Joined Mar 2006
SR-71 Dual Turbines Axisymmetric Thrust
Would like to build a dual turbine SR-71 model. However I'm concerned about
axisymmetric thrust (off center) with the motors seperated so far at the aft end of the model. Wondering if anyone had suggestions has how to tune and synchronize (ECU) the two turbines, fuel system set-ups. Can one ECU handle both turbines, any manufacture better than others for this kind of set-up. How to handle control if one turbine stops running in flight.
Retro???
RetroFlight is offline Find More Posts by RetroFlight
Old Sep 04, 2006, 08:13 AM
guaraguao is offline
Find More Posts by guaraguao
Puerto Rico
Joined Jun 2002
I think jetcat ecu can can control twin turbines..
guaraguao is offline Find More Posts by guaraguao
Old Sep 04, 2006, 09:50 AM
joeflier is offline
Find More Posts by joeflier
joeflier's Avatar
United States, MI, Plymouth
Joined Jan 2005
Some guys with twin turbines send both engines, ECU's, and pumps in for service to have the engines matched to each other. I suggest that you contact your manufacturer's service center to discuss.
Joe
joeflier is offline Find More Posts by joeflier
Old Sep 04, 2006, 06:42 PM
B58 is offline
B58
Find More Posts by B58
B58
Joined Nov 2004
Sr
One ecu cannot control two turbines. All parameters are different for each individual engine. Not like just a throttle control on glow engines. You can build or buy a kit with a single center line thrust turbine hidden in the fuselage or mounted beneath. However, if you really want twin engines then you should not have a problem as long as you use two of the same type turbines. It also is very rare to have an engine fail unless you have a problem with your installation. I have only had one flameout, and that was on a first flight of an F-16 when I had an air bubble in the fuel line. Hope that helps. Bob Oh, the full scale SR-71 flys fairly well on one engine. I have observed that up close and personel.
B58 is offline Find More Posts by B58
Old Oct 31, 2006, 10:00 PM
charlieoneseven is offline
Find More Posts by charlieoneseven
Aircrafting is noisey...what?!
charlieoneseven's Avatar
United States, CA, Long Beach
Joined Dec 2005
I agree with B58 the fuel pump would not be able to supply two engines and if it could with one out the fuel would continue to flow to the dead engine. I think the reciever gets a Y harness to the seperate ECU's.
The airliner guys swear by gyros on rudder for that senario and on ailerons for turbulance. Getting a matched pair sounds like good advise but you should be able to program their ramp and top RPM the same and get it right out of the box.
I have a twin turbine project started and I'm just learing about this too.
charlieoneseven is offline Find More Posts by charlieoneseven
Old Nov 03, 2006, 12:58 AM
EngineerW is offline
Find More Posts by EngineerW
Yorba Linda Ca
Joined Apr 2004
I think given all of the challenges and problems associated with a twin turbine SR-71, asymetric thrust is WAY down the list. and I mean WAY down the list. Give me a break
EW
EngineerW is offline Find More Posts by EngineerW
Old Nov 04, 2006, 02:09 PM
Robrow is offline
Find More Posts by Robrow
Joined Sep 2004
Twin turbine 30% Hunter.
We use twin Merlin 160 turbines in this 33% Hunter. 2 totally independant systems, the Fadec ecus are pretty good at keeping both engines in syncro. Video of test flight here
30% Hunter test flight (6 min 29 sec)
I would think that you could match both engines pretty close on the bench but as with fullsize there will still be small differences.
Rob.
Robrow is offline Find More Posts by Robrow
Old Aug 10, 2009, 10:32 PM
jlmmiller2 is offline
Find More Posts by jlmmiller2
Joined Aug 2009
German SR-71
I saw a video clip of an SR-71 being flown by man who sounded German. Does anyone have any information about that plane? A friend and I are try to figure out if it had two engines or on in the middle.
jlmmiller2 is offline Find More Posts by jlmmiller2
Old Aug 12, 2009, 06:11 AM
Charged is offline
Find More Posts by Charged
Estonia,Tartu
Joined Jan 2005
http://www.mmrca.org/lance/sledframe.html ,you should contact this guy , he has an incredible sr-71 on the way ,he has bulidng it for several years , you can get the contact in the habu.org link
Charged is offline Find More Posts by Charged
Old Aug 12, 2009, 06:38 AM
TJK is offline
TJK
Find More Posts by TJK
TJK
United States, PA, Harrisburg
Joined Feb 2001
The German SR-71 you most likely reference has a single turbine on the aircraft centerline, exhausting below the stinger at the tail.
TJK is offline Find More Posts by TJK
Old Aug 24, 2009, 01:27 AM
AFTERBURNIN is offline
Find More Posts by AFTERBURNIN
VANCOUVER WA
Joined Aug 2008
contact sunset models ... he is the SR 71 guy he would know out of anyone
I believe he is finishing up an 18ft model of the black bird... i have a set of plans for the 9 ft scratch build version i would be more than happy to run off some copies ... i would have to charge what ever the copies cost of course
AFTERBURNIN is offline Find More Posts by AFTERBURNIN
Old Aug 24, 2009, 06:15 AM
Charged is offline
Estonia,Tartu
Joined Jan 2005
It has two turbines , he has molds of the whole fuselage and everyhting
Old Sep 02, 2009, 05:41 PM
hockman5 is offline
Find More Posts by hockman5
Joined Aug 2009
http://www.fark.com/cgi/vidplayer.pl?IDLink=4464984
awesome
hockman5 is offline Find More Posts by hockman5
SR-71 for EDF 50 (Closer than we might think) Thomas B Electric Ducted Fan Jet Talk 187 Feb 22, 2011 10:56 PM
SR-71 anyone? steve neill Electric Ducted Fan Jet Talk 71 Oct 08, 2007 07:34 AM
Has there ever been a R/C SR-71 Blackbird? snowman610620 Electric Ducted Fan Jet Talk 15 Mar 08, 2005 10:01 PM
hobbylab sr 71 bushpilotx1 Sport Planes 7 Mar 06, 2002 12:53 AM
Electrics that can outperform the SR-71? SchiessCo Electric Plane Talk 4 Jul 30, 2001 08:44 PM
