Old Sep 03, 2006, 12:50 AM
Accu157 is offline
Find More Posts by Accu157
Joined Aug 2004
How do you cap a rib with a carbon fiber strip? How much strength does it add?
It's something that has intrigued me for some time, and it's something I might try if it's useful enough, and cost worthy, but, how do you do it? Where do you get the strips for it?
Accu157 is offline Find More Posts by Accu157
Old Sep 03, 2006, 03:07 AM
Barnsey is offline
Find More Posts by Barnsey
Where'd it go?
Bonnie Scotland
Joined Feb 2006
I've only seen carbon cap strips used in conjunction with carbon trailing edges, kevlar thread-wrapped carbon/balsa shear web/carbon spars and carbon D boxes, a technique pioneered and used by free-flight flyers for many years.
The carbon cap strips link the leading edge assembly with the carbon trailing edge, resulting in a structure of great lightness but immense strength, especially torsional rigidity. The cap strips themselves are simply cut from sheets of carbon of the right thickness.
I once had the pleasure of spending a weekend with Mike Woodhouse, a free-flight flyer at WC level, to see first-hand just how these structures are fabricated. Mike showed me how I could make a replacement T tail stabiliser/elevator assembly for a model I had which needed substantial nose weight. The foam/glass/veneer original weighed 80g and was pretty torsionally rigid. Mike's sample weighted 5g before covering and was bulletproof. One of the most worthwhile 1800km journeys I've ever undertaken .
Mike sells all the products needed for such structures from this Aladin's Cave.
John
Barnsey is offline Find More Posts by Barnsey
Old Sep 03, 2006, 03:30 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
If the balsa rib has medium density, it has compression strength of 1700 pounds per square inch (PSI) along the grain and 300 PSI cross grain. However, the tension strength is about two times more.
The strength of unidirectional carbon with epoxy depends on the layup process, wet with tow, wet with Uni-web, prepreg, compressed (or not), Pultruded Carbon, and Modulus (standard, medium of high). So, the carbon compression strength can vary from ~75,000 PSI to over 300,000 PSI. With very, very small cross section area (skinny) carbon compared to its length, the problem is buckling far before it uses its compression strength. So the skinny carbon needs its support to prevent bucking.
The team work with balsa and carbon makes a strong, stiff and light structure such as rib.
I suggest use manufactured carbon prepreg only 0.007" sheet and strip it with the rib thickness (1/16 or 3/32 inch) depending the size of the rib and spacing between ribs. Glue the balsa to carbon strip with epoxy or thin CA. See:
http://www.deltronix.net/cgi/acp_display.exe
Or
http://www.cstsales.com/carbon_fiber...nates.html#925
Prepreg carbon sheet 0.007" x 1/16" has a compression strength of about 95 pounds!!!
Ollie is offline Find More Posts by Ollie
Old Sep 05, 2006, 02:57 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
One of my Soprano wings came with a slight twist in it. I tried to take the wist out by the usual heating the covering method but it would not stay. The only way was to carefully strip off the carbon rib cap from one side of the rib and weight the wing down to a flat surface. I then CA'd the cap back on and it is still straight and in use today. It was amazing how much torsional strength was on that wing panel using so little carbon.
Mark
Mark Miller is offline Find More Posts by Mark Miller
Old Sep 07, 2006, 08:43 PM
Accu157 is offline
Joined Aug 2004
Thanks guys! Sounds like a done deal to me.
Ah, a related question.
None of the planes I've seen using this design had a hollowed-out rib. Is there some engineering reason why I shouldn't hollow it out when using a carbon rib cap?
Old Sep 08, 2006, 02:27 AM
oakman7004 is offline
Find More Posts by oakman7004
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
The reason is probably the time, needed to hollow out the rib. If you would have laser cut ribs them mabye you would program that process.
And the effect(weight saving) is probably not that much, in a 100-150" design...
It's just not worth it!
cheers Jonas Ekman
oakman7004 is offline Find More Posts by oakman7004
Old Sep 08, 2006, 04:36 AM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
"Is there some engineering reason why I shouldn't hollow it out when using a carbon rib cap?"
You don't get it? Read and understand post #3 again.
With very, very small cross section area (skinny) carbon compared to its length, the problem is BUCKING far before it uses its compression strength. So the skinny carbon needs its SUPPORT to prevent BUCKING. If you take away the SUPPORT (like balsa or rigid foam) the skinny carbon doesn't work to resist the compression load.
How much SUPPORT? It depends on how much you hollow out the ribs. That's why you test the sample or you learn to apply engneering math. If you want specific answers, then you must give specific numbers like specific dimensions (thickness, shape, height and length) and materials (balsa density, which epoxy and which carbon).
Old Sep 09, 2006, 03:19 PM
Accu157 is offline
Joined Aug 2004
I guess there is such a thing as a stupid question? I understand it now.
Old Oct 31, 2008, 09:32 PM
bwalt822 is offline
Find More Posts by bwalt822
USA, WA, Edmonds
Joined Aug 2008
That failure mode is called buckling BTW. When I see it in caps a few times I feel the need to correct.
bwalt822 is offline Find More Posts by bwalt822
Old Oct 31, 2008, 10:21 PM
nuevo is offline
Find More Posts by nuevo
nuevo's Avatar
United States, AL, Madison
Joined May 2002
Couldn't resist that urge, huh? From 2 years ago, no less.
nuevo is offline Find More Posts by nuevo
Old Oct 31, 2008, 11:01 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
Crap, I didn't see the date and there was no way I was that deep into this forum. I hate it when people do that. Oh wells. I swear this thread popped up next to the forum title.
Old Oct 31, 2008, 11:06 PM
nuevo is offline
nuevo's Avatar
Joined May 2002
sorry, no ill will. I just thought it was funny.
Old Nov 01, 2008, 01:12 AM
T.D. is offline
Find More Posts by T.D.
T.D.'s Avatar
Vancouver, Canada
This reminds me of how much Ollie is missed around here.
T.D.
T.D. is offline Find More Posts by T.D.
Old Nov 01, 2008, 08:29 AM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Yep, we miss Ollie. This is still an interesting read. From what I heard about the process during manufacture of these models... They make a balsa block, wide enough to make say, 100 ribs, with a CNC router that is the shape of the rib they need... say R-14... They use a sheet of cf the same size and glue it to the block, top and bottom. Then they slice the ribs off, ready to use. Now that have 50 sets of R-14 for their tapered wing. No tedious gluing of tiny strips to 3/32" ribs.
Jack
schrederman is offline Find More Posts by schrederman
Old Nov 01, 2008, 11:04 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
still the teacher
Well I learned quite a bit reading this ...soooo THANKS
ozmo01 is offline Find More Posts by ozmo01
Discussion were do you run the antenna on carbon-fiber boom bosco49 Radios 6 Jan 27, 2006 03:56 AM
How Much Do You Increase Thrust With Two Motors WillowPtarmigan Power Systems 3 Sep 30, 2003 08:03 PM
carbon elevon rods...how do you do them? gouch Foamies (Kits) 7 Aug 25, 2003 12:50 PM
How do you make decals with a computer? Andy W Scale Kit/Scratch Built 50 May 24, 2003 09:12 PM
How do you balance a PicoJet with NIMHs?? Dunc Foamies (Kits) 7 May 17, 2003 09:34 AM
