This thread is privately moderated by mrm1, who may elect to delete unwanted replies.
Old Sep 02, 2006, 01:13 PM
mrm1 is offline
Find More Posts by mrm1
Fly a LiL' Lower Will Ya!
mrm1's Avatar
North Central Florida
Joined Sep 2004
Field Test of the Tower Pro 3520-07
Gas-to-Electric Conversoin Maiden
Tower Pro 3520-05
The Motor
This is the first field test of this budget Outrunner motor From Tower Pro. It is in my friend Otto's Phoenix Super Decathlon Gas to Electric conversion. This was his first conversion and first large electric model.
The plane can be had for $120 from Tower and is very sweet indeed.
The specs of the plane with a gas engine are suppose to be 7 lbs, but the plane did not feel that heavey to me - more like 5 lbs. See the pic of the manufactures specs below. His cowl was broken from a previous gas crash.
The model was set up with:
- the Tower Pro 3520-07 from Gorrilla Bob's - $45
- Tower Pro 65 G2 ESC - $40
- Reciever Battery
- 14x7 prop APCe
- 4s 10c - ?3700 mAh? (i think) pack from Common Sense - could not confirm mAh as their site seems to be down.
Shipping to Fl for motor and ESC from Bob was 2 days.
We used the Eagle Tree Data Logger for in flight Data. Tried to connect the temp probe to the back of the bell, but it did not read?? But got in flight amps / watts / volts. Check the graphs below. Amazing power output.
Flight Summary:
All I can say is wow. This 66" gas to electric conversion was over powered. Flew beautifully. took off in about 25' with only 3/4 throttle from rough grass and we flew it for nearly 8 minutes and still seemed to have plenty of power.
I took the controls at about 5 minutes into the flight (no video), and did loops, stall turns (not enough throws), rolls and high speed low passes. The thing that I was wondering about with this budget equiptment was how well the linear throttle control would be. I was very impressed. I did not do any programing of the controller, but just in flight it seemed as good as the hi dollar ones to me. I did not notice any difference. Very nice controller and nice feel. I am ordering one today.
As to the motor. Excellent! look and construction. Great power, and very quite. No vibration or noise or slop. Over all great set up.
Otto is in the process of selling or giving away all his gas stuff. He is a true convert today
Here is the video of this little power plant:
Video of the Super Decathlon Conversion
If you are looking for a nice .46 - .51 size conversion motor, I could highly recommend this one. BP Hobbies has them in 2 Kv sizes: the 650 which we flew today, and the 730 kv.
Later
mrm1 is offline Find More Posts by mrm1
Old Sep 02, 2006, 01:41 PM
BIGDANO is offline
Find More Posts by BIGDANO
AMA #851612
BIGDANO's Avatar
Alameda, CA
Joined Dec 2005
Nice!! GorillaBob is the man!!
BIGDANO is offline Find More Posts by BIGDANO
Old Sep 02, 2006, 09:04 PM
hermperez is offline
Find More Posts by hermperez
know it all
Miami, Fl
Joined Nov 2003
Very nice, so what is the rtf weight? That battery is holding good voltage, 3.75v at 45amp
Herm
hermperez is offline Find More Posts by hermperez
Old Sep 02, 2006, 09:57 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
Herm, we did not have an RTF weight, only what it was "supposes" to weigh according to spec (7lbs) and what if felt like (more like 5 or 6). But it did balance correctly and handled very well in the air.
Old Sep 04, 2006, 03:25 PM
know it all
Miami, Fl
Joined Nov 2003
How was the vertical performance?, hammerheads?, spins?
Herm
Old Sep 04, 2006, 08:55 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
vert was not overly determined. not enough throws to do spins. (and this would not be overly dependent on power/thrust - except in flat spins IMO). Plenty of power to do hammerheads.
Seems the motor would be good at any of the above based on power displayed.
Old Sep 07, 2006, 07:18 PM
DIALED/CHUCK is offline
Find More Posts by DIALED/CHUCK
Rc's Best Friend
DIALED/CHUCK's Avatar
Virginia Beach, VA
Joined Dec 2005
Motor setup looks like it would be a screamer on a little plane I am looking at....thanks for the readout....hats off!
--C
DIALED/CHUCK is offline Find More Posts by DIALED/CHUCK
Old Sep 07, 2006, 07:54 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
Thanks --C
Old Oct 07, 2006, 02:53 PM
charlatan is offline
Find More Posts by charlatan
charlatan's Avatar
Liverpool, UK
Joined Jun 2002
Mike, thanks for that. Looking at that EXACT setup for my China Models Cessna that I want to electrify!
charlatan is offline Find More Posts by charlatan
Video Super Star EP with Tower Pro 2908-10 Test mrm1 Electric Plane Talk 0 Dec 06, 2006 08:38 AM
For Sale Tower Pro 3520-7 with Dynam 60 amp ESC Milton Aircraft - Electric - Power Systems (FS/W) 1 Dec 04, 2006 09:04 AM
For Sale New Tower Pro 3520-7 Milton Aircraft - Electric - Power Systems (FS/W) 3 Jun 22, 2006 11:17 PM
For Sale Tower Pro 3520-7 Out Runner Milton Aircraft - Electric - Power Systems (FS/W) 0 Mar 25, 2006 11:46 PM
