Joined Oct 2002
info@astroflight.com |
Joined Oct 2002
Alex,
To clear up things......which motor are you going to use from post #50 ? http://www.rcgroups.com/forums/showp...8&postcount=50
Joined Oct 2002
Per Model Motors Web Site:
http://www.modelmotors.cz/index.php?...495%20-%20652g) No. Of cells max. 32 max. 10s Li-Poly RPM/V 249 RMP/V Max. efficiency 92% Max. efficiency current 10 - 36 A (>85%) No load current / 10 V 1,4 A <--- Means @ 10 Volts constant! Current capacity 50 A/60 s Internal Resistance 57 mohm Dimensions 63x54 mm Shaft diameter 8 mm Weight with cables 495 g Recomended model weight 4000 - 8000 g Recomended prop without gearbox 8s Li-Poly 23"x11"APC-E 10s Li-Poly 18"x12"APC-E Recomended speed controller JETI ADVANCE 77 -------------------------------------------------------------------- Models Parameters: Wing Span: 1600mm = 63 inches Wing Area: 50 sq.-m. = 538.2 sq.-in. Weight: 5300grams = 12.27 lbs. Based on using some larger and more robust Li-POLYs such as the KOKAM 3200SHD with a maximum 20C discharge rate, they are on the heavy side at 2.83oz. each cell so, they will load down the model but, you get the full advantage of motor performance as these cells will not starve the motor when it comes to AMP draw. I am using 10S2P and the APC "Pattern" 15X12 propeller. Just take a look at your airspeed..... Static pitch speed (90mph) is within the range of approximately 2.5 to 3 times the model's stall speed (33mph), which is considered ideal for good performance. Also, take a look at your static thrust-to-weight!!!! Really, no need for any larger propeller as you need airspeed on this very heavy wing loaded model Static thrust (176.1oz) to weight (146.2oz) ratio is 1.2:1, which will result in extremely short take-off |
Carlos thanks again...no I won't be using a huge prop on this project unless it's completelly necessary...I mean for scale looks otherwise I'm pretty sure that with the AXI 5320/18 and a 15x10 or 15x12 prop I should get away very well.
Batteries will be 2 packs of Thunder Power at 10-12C rating of 8000mAh capacity and built on 5S4P each. Motocalc shows about 1000-1200 Watts using this configuration so should be more than enough for this bird I think. Well I won't be reporting much progress until I get Esprit's motor supports and I figure out how to fix batteries inside and other bits like finish the landing gear wells. Alex
| Thread Tools | |
| Cool My New 1/6 scale BF-109 E-4 | Herr_Fredrik | Scale Fuel Planes | 7 | Aug 30, 2007 04:06 PM |
| Build Log C-160 Transall by CMP e-conversion. | Alex B | Glow to Electric Conversions | 33 | Nov 13, 2006 09:15 AM |
| For Sale Guillows 1/28 B-17G-perfect E-conversion!! | Pilot_Tony | Aircraft - Electric - Airplanes (FS/W) | 0 | Jul 22, 2005 07:18 PM |
| Beta Build -- 1.6 Meter Glider from e-flightrc.com | rcav8r2 | Electric Sailplanes | 8 | Oct 14, 2004 03:43 AM |
| Anyone do the E-conversion on Air Foil Aviation's 1/4 scale powered parachute? | EFoil | Electric Plane Talk | 0 | Jul 23, 2001 05:35 PM |
