Old Sep 06, 2006, 01:35 PM
Alex B is offline
Find More Posts by Alex B
MG ZS180 proud owner
Alex B's Avatar
Balaguer in Lérida - Spain
Joined Jul 2005
Thunder1 I'm finally going to go for the 5320/28, wing loading is what motocalc showed after I typed all the info of empty weight as per programme demand, wing area and wing span given by manufacturer.
It has flaps by the way...otherwise I'd say it would be unflyable
Thanks for the input.
Here are some pics of tail and elevator construction and 2 pics along the F4U I built from Phoneix Models for size comparisson, this one is larger and fatter
Alex
Alex B is offline Find More Posts by Alex B
Old Sep 06, 2006, 02:04 PM
thunder1 is offline
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
It looks about the same size as the H9 P-47. Most of those end up weighing 8-9 lbs. The motor of choice is the 4130/16 or E-Flight Power 60. But at your weight, those are out of the question.
Your's looks very well built. Definitely a good glow model.
I'm a little leery of the wing area listed on the box cover. What's the root chord and tip chord (at the aileron tips)?
thunder1 is offline Find More Posts by thunder1
Old Sep 06, 2006, 02:07 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Here's a neat wing loading calculator !!
http://www.coloradogliders.com/wingl...calculator.htm
guapoman2000 is offline Find More Posts by guapoman2000
Old Sep 06, 2006, 02:10 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Now who's going to give a lesson on how to messure all those parameters ???
I haven't got a clue my friends but if somebody gives me a hand I'll fill in the info and tell you.
Alex
Old Sep 06, 2006, 02:12 PM
Account closed
Joined Oct 2002
Alex
Alex,
It is rather simple.....on a non-rectangular wing airfoil...such as your model and that of say a SpitFire...you need to measure across the wing cord with say 4 - 5 measurements and average them out.....this is what you input....
Carlos
Old Sep 06, 2006, 02:49 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Here's a measurement that will be pretty close. Measure the red lines. Those are the tip and root chords. The tip chord should be measured at the point where the leading edge starts to curve.
Then enter those numbers as if the wing has the planform indicated in green.
Old Sep 06, 2006, 02:52 PM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
It really looks nice
Those flaps is going to be useful giving you valuable lift at landings.
//Peter
wolw is offline Find More Posts by wolw
Old Sep 06, 2006, 04:46 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Ok guys once I get to the wing I'll messure everything as accurate as possible and then calculate the real wing loading.
Peter it is nice although I would have liked the older version but wasn't available except on a bigger size and fiberglass fuse...anyway once I get used to fly this sort of birds I'd like to built a 2+ mt. warbird as my final project.
Thanks a lot to everyone for your input.
Alex
PS: Post 11 edited with new final weight due to a little calculation error.
Old Sep 06, 2006, 06:41 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Some pics of battery testing and size reference and tailwheel
Alex
Old Sep 07, 2006, 01:39 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Here are tail and elevator control horns...good quality items
Old Sep 07, 2006, 02:44 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
That hardware does look durable. But one of the drawbacks of not having the control horn hinge point (where the clevis joins the horn) centered over the hinge line is that you're going to have uneven throws (differential)
If you have a computer radio you can set the endpoints to even the throws out. Otherwise the up/right travel will be different than the down/left travel. As it is it looks like the up/right travel is going to be greater than the down/left travel. Probably no big deal.
I highly suggest using the little plastic clevis keepers as on such a heavy plane the clevis can weaken and pull through the threads and/or open at the horn end. All it takes is a slight bump of the control surface to make this happen.
Old Sep 07, 2006, 03:09 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Overkill
There looks like plenty of movement available in any direction, but this looks like severe over kill.
The big question, how strong do you need the parts to be? If you hold back the rudder and elevator with your two fingers you will cause the wood to crack and break with just the normal servos and hardware. This is not a 3D plane, don't waste your money on any more heavy duty stuff. It's better to have some flex, it will save the wood.
Like I said, the wood underneath will break if the control pressure is too great, even from standard $13.00 servos.
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old Sep 07, 2006, 03:32 PM
wolw is offline
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
It's the Graupner way.
Like a Mercedes Benz, built to last
Alex, I think it looks great.
This is the tailplane on my Graupner Extra 300
//Peter
Old Sep 07, 2006, 03:43 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Exactly that hardware came with the kit so I thought it would be ok if they design it for this bird ??? and what the plastic clevis keepers ??? never heard of that before.
Alex
Old Sep 07, 2006, 04:13 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
I think he meant the plastic clevis keeper to be the fuel hose type.
Ya know, you cut off a 1/4 inch piece of fuel hose and slide it over the clevis.
Hey, if the hardware came with the kit, great. No problemo. I'm wrong and will be willing to admit it.
I made the mistake of buying this Robart stuff that was so heavy duty that I threw it away. I belive in severe over kill, but, the super heavy duty stuff that got shipped to me looked silly on a Hangar 9 Corsair. It looked as silly as if I bought cabinet hinges at Home Depot and put them on the plane.
All kidding aside, I saw the heavy duty stuff on extra giant scale 3D planes, but not on balsa elevators or rudders that can crack easy.
Keep up the good work, how much time do you estimate that you have left untill completion? I want to see videos of this baby flying.
Al
Cool My New 1/6 scale BF-109 E-4 Herr_Fredrik Scale Fuel Planes 7 Aug 30, 2007 04:06 PM
Build Log C-160 Transall by CMP e-conversion. Alex B Glow to Electric Conversions 33 Nov 13, 2006 09:15 AM
For Sale Guillows 1/28 B-17G-perfect E-conversion!! Pilot_Tony Aircraft - Electric - Airplanes (FS/W) 0 Jul 22, 2005 07:18 PM
Beta Build -- 1.6 Meter Glider from e-flightrc.com rcav8r2 Electric Sailplanes 8 Oct 14, 2004 03:43 AM
Anyone do the E-conversion on Air Foil Aviation's 1/4 scale powered parachute? EFoil Electric Plane Talk 0 Jul 23, 2001 05:35 PM
