Old Sep 30, 2006, 06:58 AM
Alex B is offline
Find More Posts by Alex B
MG ZS180 proud owner
Alex B's Avatar
Balaguer in Lérida - Spain
Joined Jul 2005
Originally Posted by wolw
Looks you're getting close to maiden
I want to hear about easy takeoffs, graceful landings etc with video of course
There's been too much building and too little flying
Have a Moritz for me will 'ya
Cheers,
Peter
You're too right Peter I haven't flown for 3 weeks now and tomorrow I won't either as I want to get things going and finish both planes for next weekend.
Video as usual we'll try our best of course...no maiden without video as it wouldn't be fair for those following this thread...and specially those who have contributed activelly to it.
Cheers,
Alex
Alex B is offline Find More Posts by Alex B
Old Sep 30, 2006, 02:16 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Strut covers are done and partially glued...cowl fixing blocks done too.
Old Sep 30, 2006, 03:16 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Well cowl has been fitted and man it really is tight...it's not rubbing the motor or prop by 1 or 2 milimeters.
Finally didn't use those blocks to retain the cowl in place instead I used factory marks on cowl which I had not seen
Please let me know if prop looks sort of scale what's your opinion ???
Alex
Old Sep 30, 2006, 06:17 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Well actual weight without batteries and with everything else on the plane is 3.450 gr. Batteries 1.586 gr. so total weight finished will be 5.036 gr. which is exactly 177,64 oz. or 11,10 pounds...not bad as its end weight is less than expected / predicted
So if take that previous rule I said some posts back at a minimum of 1500W divided by 5,036 kg. is roughly 297 W/Kg. woooowwww.
After all I'm happy as it could have been worse ....wing loading will be in between 33-34 oz/sq.ft. a bit heavy maybe ? but batteries are 10S4P 8000mAh. so if I find it too heavy I might look for a lighter pack.
Alex
Old Sep 30, 2006, 06:46 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Well here's me and my plane...it's really heavy and I'm starting to shake and I'm not finished yet
Alex
Old Sep 30, 2006, 07:42 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Don't Worry!!!!
Alex,
I am at the University of Central Forida (UCF) chatting on some computers in the Student Union!!! I don't have too much time....my daughter is taking salsa dance classes!
That weight is not bad at all because recall that you have flapps and a large wing area.....the use of flapps will make her float in with no problem...you will be amazed!!!
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Oct 01, 2006, 12:23 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
No hurries Carlos won't be flying it until next weekend.
Going to use a Jones Witch switch...you can build one home or just buy it at Vampower
Alex
Old Oct 01, 2006, 01:20 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
I've decided to delete this posts as I think it's not fair to those that have put the time to develop the product and it'll save you time to buy them directly.
Sorry
Alex
Old Oct 01, 2006, 01:24 PM
Account closed
Joined Oct 2002
Alex,
Excuss me for my ignorance here....but, exactly what does this switch do "or" what is it's function for your model?
Old Oct 01, 2006, 01:36 PM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
Thanks Carlos for asking
//Peter
wolw is offline Find More Posts by wolw
Old Oct 01, 2006, 02:05 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
It's easy my friends...I first heard of it when reading a FlyRC mag article about the AT6 Texan from Hobby Lobby and on the pics I saw it then read the article and it said something about a battery switch or so...searched internet and found that VamPowerPro is selling them, I've bought some but being so expensive to get them sent to Spain for just 1 or 2 and finding the needed parts at Esprit I had to try.
This switch will cut the power of your batteries, the positive pole of this switch will cut the power from outside the bird so no need to unbolt the wings to cut power anymore...this is specially usefull when you have big packs running as a safety item and when you've got high amp capacity batteries and you don't want to use them all in one flight you land and then cut the power
Hope you get the point...so on my birds I use 2 switches one for batteries and one for the Rx pack.
Alex
Old Oct 01, 2006, 02:32 PM
wolw is offline
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
Oh , I get it
You can put your LiPos in and when you're ready to fly (after instructing wife etc) you power it up, right ?
Think I'll give it a try next time I order from Vammy, (you really should PM him from RCG, best deal that way )
Peter
Old Oct 01, 2006, 02:56 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
deleted aswell
Alex
Old Oct 01, 2006, 04:44 PM
Alex B is offline
Alex B's Avatar
Joined Jul 2005
Deleted too.
Alex
Old Oct 01, 2006, 05:39 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Alex,
Very good, great idea, thanks for posting the information and the pics. I have one question and one request.
Question:
1. What camera are you using to get those close up pictures.
Request:
Tonight, while you are giving instructions to your wife, please push and pull that switch 100 times just to make sure the epoxy holds the plastic and the connections still make contact.
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Cool My New 1/6 scale BF-109 E-4 Herr_Fredrik Scale Fuel Planes 7 Aug 30, 2007 04:06 PM
Build Log C-160 Transall by CMP e-conversion. Alex B Glow to Electric Conversions 33 Nov 13, 2006 09:15 AM
For Sale Guillows 1/28 B-17G-perfect E-conversion!! Pilot_Tony Aircraft - Electric - Airplanes (FS/W) 0 Jul 22, 2005 07:18 PM
Beta Build -- 1.6 Meter Glider from e-flightrc.com rcav8r2 Electric Sailplanes 8 Oct 14, 2004 03:43 AM
Anyone do the E-conversion on Air Foil Aviation's 1/4 scale powered parachute? EFoil Electric Plane Talk 0 Jul 23, 2001 05:35 PM
