Joined Oct 2007
Well I got my A4 yesterday. This will be my first EDF. I think the kit is very nice, Getting the entire thing for $100 shipped is huge. The fit and finish looks very good, and the kit itself looks easy to assemble. I cannot wait to fly this bird! I do have problems with my fan assembly also though. Without even running it up I can tell that my fan will rub on the housing. I'm not even going to attempt to run it up without getting a prop balancer first, it looks like there have been a few issues with that so far. Overall though I think this kit is pretty darn good. I like the size of the A4, though I realize it's probably going to be pretty heavy. I guess I'm not as worried as most are about overall speed of it. Being my first EDF, I think something a little slower and more stable will benefit me in the long run. Good job to GWS for making a great bird for an honest price.
What are some other fan options for us if I wind up having some of the same problems with rubbing? I looked and found a couple 69mm fans. But measuring the fan DIA with my calipers last night it measured over the claimed 70mm |
Andy |
However, you need a good Li-Po which able to give enough current. A 2200mAh 3 cells 20~25C will be a good match.
I like to tell you how GWS EDF75 recently had tested with proto type brushless outrunner motor to get such result:
![]() EDF75 4 blades: 1728g at 5 cells 81A ( 1498W ) 3260KV ![]() EDF75 4 blades: 1180g at 4 cells 50.2A ( 743W ) KV=? Any one here may be even already got better test datas? ![]() Hope this increasing of speed and thrust will bring GWS EDF75 powered models up grade their performance a lot! ![]() However, need to be careful not to bent the wings!
Some of the old test datas that measured by using GWS BL22xx out runner BL motors during 2007 summer for your reference. However, I feel that were not good enough at that time.
Volt Amp TRUST=g RPM Watts g/Watts 2208/24T 3606kv 7 13.45 235 20575 94.15 2.496017 10.5 24.06 405 28400 252.63 1.603135 11.1 26.26 445 29525 291.486 1.52666 14V 35.87A 635g 34475RPM 502.18W 1.264487g/W 2208/20T 4273kv 7 18.8 280 22825 131.6 2.12766 10.5 33.58 520 30775 352.59 1.474801 11.1 36 560 31825 399.6 1.401401 2213/14T 3606kv 7 15.41 323 21725 107.87 2.994345 10.5 27.99 465 30325 293.895 1.582198 11.1 30.95 525 31425 343.545 1.528184 14 42.35 755 37725 592.9 1.273402 2213/12T 4273kv 7 19.39 320 23650 135.73 2.357622 10.5 35.39 590 32950 371.595 1.58775 11.1 38.74 650 34475 430.014 1.511579 2216/12T 3322kv 7 13.85 235 20675 96.95 2.42393 10.5 24.95 400 29625 261.975 1.526863 11.1 27.09 505 30950 300.699 1.67942 14 37.61 715 37525 526.54 1.357922 2216/10T 3872kv 7 18.39 295 23250 128.73 2.291618 10.5 33.91 590 32675 356.055 1.657047 11.1 36.97 650 34150 410.367 1.583948 2216/8T 4706kv 7 27.69 380 26375 193.83 1.960481 10.5 49.01 725 36025 514.605 1.408848 11.1 52.7 785 37925 584.97 1.341949 2221/8T 3596kv 7 16.67 285 22025 116.69 2.442369 10.5 29.94 495 31475 314.37 1.574578 11.1 32.85 615 33100 364.635 1.686618 14 45.68 820 39900 639.52 1.282212 2221/6T 4440kv 7 26.67 375 25900 186.69 2.008677 10.5 47.86 690 35825 502.53 1.373052 11.1 51.58 750 37575 572.538 1.309957 |
