Old Aug 13, 2002, 12:54 AM
putt_13 is offline
Find More Posts by putt_13
putt_13's Avatar
Minneapolis, MN
Joined Aug 2002
Car Batery Charger As 12v DC Power Supply???? Will This Setup Work
Hello,
I am am purchasing a GWS Battery Charger GWS-MC2002. It is a 12v DC charger. You can find them at http://www.aeromicro.com Now, Since I dont want to always have to hook it up to the car battery, would I be able to use a car battery charger as the 12v power supply. Heres my idea......
The Car battery charger(CBC) has a 120v AC input and a 12v DC Continous output at 10 amps(which I will be using). Now I am thinking that if I hook up the CBC alligator clips to the GWS charger alligator clips, It will be just like hooking the GWS Charger to a 12V battery, because 12v of DC current will be coming out of the CBC. Do you think this would work. Thanx Patrick
putt_13 is offline Find More Posts by putt_13
Old Aug 13, 2002, 03:55 AM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
It wont work as the car battery charger's output is unregulated, and may damage your GWS charger.
Adam
Foxy is offline Find More Posts by Foxy
Old Aug 13, 2002, 01:13 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
NOT recommended. The power coming off of a car battery charger is too "dirty". You can charge from a car/RV battery while such a charger is also attached, however.
I think the computer power supply idea being discussed in your thread in Parkflyers is probably a better bet, even though it will require getting a power supply with a hefty 12V rating (at LEAST 5A - the charger is fused at 20A on the input side).
BEC is offline Find More Posts by BEC
AC/DC Power Supply...will this work? park-n-fly Batteries and Chargers 5 Jun 02, 2005 01:05 AM
WTB -12V DC Power supply flyingdoc Aircraft - Electric - Airplanes (FS/W) 0 Apr 18, 2005 10:48 AM
FS: Summit Charger and 12V DC power supply Mattydiah Aircraft - Electric - Airplanes (FS/W) 2 Nov 10, 2004 04:30 PM
**WANTED Hobbico 12V DC power supply nod Aircraft - Electric - Airplanes (FS/W) 0 Oct 23, 2004 06:21 PM
power supply Will this work for R/C? RickC2009 Batteries and Chargers 13 May 14, 2004 04:51 PM
