Espritmodel.com Heli Air
View Poll Results: Which Standard Bird suits me?!?
Skybench - Olympic II 35 46.05%
MM Glider Tech - Marauder 19 25.00%
Northeast Sailplanes - Kestrel 100" 11 14.47%
OTHER - Please post plane below. 11 14.47%
Voters: 76. You may not vote on this poll
Old Aug 30, 2006, 03:37 AM
Russian Federation, Sakha, Yakutsk
Joined May 2006
Skybench OLY II, NES Kestrel 100" or MM Tech Marauder???
Hey all, a younger woodcrafter here. I'm getting ready to purchase / build a standard class plane and am left wondering which I should go with.
I ordered a Kestrel 100" from NESail, however after calling them today to see if my kit shipped I found out that it won't ship until 6-8 weeks from now.
Therefore...
I'm left looking at the Skybench OLY II and the MM Glider Tech Marauder. Both are lovely looking planes, with the Marauder looking a bit "more modern."
So...
I ask the OLY II, Kestrel 100 and Marauder drivers, which out of the three:
1. Builds well? (How is the quality of the Skybench, NES and MMTech kits?)
2. Is suited for my area? (Large flat coastal plain. Thermaling in open fields with occasional gusty winds
3. Can withstand hard launches?
BTW...I'm dead set on wooden sailplanes. However if there are any other 99" - 118" class wood ships I should know about, please fill me in!
FrogChief is offline Find More Posts by FrogChief
Reply With Quote  (Disabled)
Old Aug 30, 2006, 03:55 AM
Joined May 2006
I voted "other" to get my vote out of the way.
Old Aug 30, 2006, 06:03 AM
Manassas, VA
Joined Dec 2005
Paragon
balsaaddict is offline Find More Posts by balsaaddict
Old Aug 30, 2006, 06:10 AM
Punta Gorda, FL
Joined Apr 2002
I advise you to get a Mirage short kit. You get the sheet balsa and sticks from the hobby shop. The short kit gives you laser cut parts and Vacuum Formed Canopy.
http://www.isthmusmodels.com/product...roducts_id=111
I suggest you get the plans from RCM.
http://www.rcmmagazine.com/store/sto...xdVPskvg89j4w3
I think that the Mirage design is the best for wood sailplanes. The Mirage aerodynamic and structure is best functional design but not for artistic looks.
See what Dr. Drela says:
"I mostly agree with Mark Miller's comments. The Mirage is great combination of simplicity and performance, and making modifications which involve a lot of work just isn't worth the payoff.
"Nevertheless, Blaine Rawdon has mentioned to me that he would make a few fairly easy mods to the Mirage if he were to build another one today:
1) Elevator on both sides, for more precise elevator response.
The original one-sided elevator was mostly for mechanical simplicity and minimal weight, but having two elevators isn't that much more difficult. A short piece of spruce, basswood, or CF tube would make a suitable connector.
2) Get rid of the rudder balance tab, for more rudder power and mechanical simplicity.
3) Make the center-panel turbulator strips out of 1/8" square spruce or basswood rather than balsa. The balsa ones crack too easily. I myself would stick to balsa, but make them 1/8" x 3/16" set on edge. The 50% depth increase will more than double their strength.
4) Increase the torsional stiffness of the center panel by double-covering it with Monokote. This will suppress the catastrophic flutter which occurs on this plane at 50-60 mph. Using a heavier LE strip and making the TE strips as light as possible will further suppress this flutter.
"In addition to the above, I would
a) Add spruce doublers to the top-surface sparcaps, glued on to the rear of each cap, flush with the surface. The top center sparcap gets a 24" x 1/4" doubler, and the top tip sparcaps get 12" x 1/8" doublers.
b) Use thicker shear webs in the center to match the stronger sparcap. I'd use 1/4" for the three innermost bays, then 3/16" for the next three bays, then the stock 1/8" for the rest.
"These mods will nearly double the bending strength of the wing, with minimal weight and effort. The ends of the doublers can be tapered for better appearance."
Ollie is offline Find More Posts by Ollie
Old Aug 30, 2006, 06:37 AM
R.M. Gellart's Avatar
Joined Nov 2005
How about the 100" Bird from Skybench? Strong, clean, and very aerodynamic clean.
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Aug 30, 2006, 07:15 AM
AECS USN RET. P3 FE
allanp's Avatar
USA, FL, Winter Springs
Joined Mar 2004
Big Bird !
Allan
allanp is offline Find More Posts by allanp
Old Aug 30, 2006, 07:24 AM
Prescott Arizona
Joined Mar 2005
Oly for relaxed flying, Big Bird for performance. Both build very well and the fit and finish is unlike anything Ive ever assembled. Built the Oly in four days with wood glue as it has a smaller piece count than most planes. It is rugged. You will enjoy working with Ray also, he always has time to answer your questions and service from him is spot on.
Bob- owner of four skybench planes
bobby legue is offline Find More Posts by bobby legue
Old Aug 30, 2006, 10:14 AM
Chile, Región Metropolitana, Santiago
Joined May 2002
I don't have experience with the other planes, but I can't say enough of Ray Hayes great support to woodies, excellent service and great kits (easy to build, great wood selection, good plans, all hardware included, etc, etc).
I have built the Lil Bird 60" and the 2 meter version as well as the Legionair (almost finished). I also have one OlyII on the building board, another NIB and a ASK18 short kit to be built sometime.
Me? I stick with Skybench!
Alex
Alex J is offline Find More Posts by Alex J
Old Aug 30, 2006, 11:44 AM
Joined May 2006
Originally Posted by balsaaddict
Paragon
Who sells the Paragon??? I've done some searching and haven't seen it yet.
Update. I bought a new Sig Riser 2m at a mall hobby shop last night to get my building skills warmed back up so I don't hose the 100" ship I eventually choose.
Got it for $24.99 on clearance!!! Can't beat that.
Old Aug 30, 2006, 12:27 PM
Unrepentant Paragon addict
LVsoaring's Avatar
Triumphantly returned to OKC!
Joined Jan 2006
The Kestrel is a nice airplane, but the customer service from NSP is very poor, so I'd stay away from them. All your other choices are good ones, but if it were me, I'd go with the Maurader, just to try something new.
Rick
LVsoaring is offline Find More Posts by LVsoaring
Old Aug 30, 2006, 12:53 PM
Vintage Flyer
Indiana
Joined Jan 2005
Therefore...
So...
Hi!
I would back up OVSS BOSS 's post and get the 100 inch Bird from Skybench, or go with the the larger version ( 132 inch version) Skybird.
OVSS BOSS and I both know Ray Hayes personally who owns Skybench, and I we fly with him often, as I live about 15 miles from Ray.
The 100 inch span Bird kit he has is of exceptional quality, will fly in calm or gusty conditions, and is a great flyer!
I mtyself plan on getting one as soon as I finish up 3 other sailplanes I have going now.
The OLY II is a good airplane, but being a flat bottom Clark "Y" airfoil, it isn't much a of a penetrator into a strong wind without a lot of ballast.
On the other hand the 100 inch "Bird" Ray kits is a great penetrator, will take a strong winch launch, and is an all around great sailplane!
And it's easy to build.
Well that's my 2 cents worth.
Good luck to you and welcome aboard!
Woodies are great!
Well time to go back to work on my Tom Martin Hall Cherokee scale sailplane which is an all-woodie!!!
Best of luck to you!
Ed
Ercoupe Ed is offline Find More Posts by Ercoupe Ed
Old Aug 30, 2006, 12:59 PM
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
not totally wood but the JK Thermic 100" or RES Thermic @ http://www.arthobby.com/shop.html
They are all very good flyers.
Batmanwpg is offline Find More Posts by Batmanwpg
Old Aug 30, 2006, 01:36 PM
Joined May 2006
Well, I'm 0 for 3.
NESnail* can't send me a Kestrel 100" until Oct...
Skybench has been away from the phones for 2 days...(*Edit - Ray is on vacation)
and MM Glider tech doesn't even have an answering machine...(*Edit - Merrill's machine was full, I got ahold of him today 8/31/06)
See I've been burned in the past faxing in orders and never hearing anything until my product arrives like a month later. So of course I'd like to speak with someone and know if the kit is in stock, how long until shipping, etc.
Oh well...I'm sure Mr. Hayes will get ahold of me sooner or later.
*intentional
Old Aug 30, 2006, 02:06 PM
Pearland, Texas
Joined Aug 2005
Paragon.
www.skybench.com/slnost.html#paragon
SkipinHouston
skipinhouston is offline Find More Posts by skipinhouston
Old Aug 30, 2006, 02:14 PM
chlee's Avatar
Atlanta, GA
Joined May 2000
Also see the offerings at www.laserarts.com
The Scepter is like the Oly II, but with a more modern airfoil.
- Chung
chlee is offline Find More Posts by chlee
Discussion Oly 650 or Oly II? icmartin Sailplane Talk 10 Apr 01, 2007 08:09 PM
For Sale NIB MM Glider Tech Marauder & Grand Illusion Kits scansyn Aircraft - Sailplanes (FS/W) 2 Feb 09, 2007 10:14 AM
Discussion Skybench OLY II burgermike Sailplane Talk 33 Nov 13, 2006 02:35 PM
Found Oly II Copy or Photo of Wing Plan Wanted old_dude Aircraft - Sailplanes (FS/W) 0 Oct 30, 2006 01:48 PM
Anyone convert an Oly II or similar 100" to electric?Could you post your power setup? Jimmy James Electric Sailplanes 13 Nov 13, 2005 07:18 PM
