Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Aug 29, 2006, 11:16 PM   #1
blah...
THUREN's Avatar
**EdgeRC Devastator DTV** DS record holder for "chevron foam" 154MPH!!
Edit, 9-23-06...
Went to Parker Mtn. today with the intent to see how fast I could get this wing DS'n on the backside. I had no expectations to come home with a record but I did!!! BY A HAIR!!! 154MPH bumped from Vic's(-double-V-) record of 153mph with his own 42' Manta purpose built DSer... So stoked!!! It was fun battling it out with Vic on the slope, and we were talking about his new stuff coming out... Gonna' try to hold the record but Vic's surely on a mission to nab it back. Got it for now, and we'll see how long I can keep it...
More details starting on page 6....
__________________________________________________ _
Edit, 9-17-06
Justin added this full kit to his website, and every detail I added he has put in the kit, and some. Moulded pushrod covers, all carbon main spars, carbon drag spars, true aileron shaped elevons(no flat balsa), BOMB PROOF center fin, etc..
Available here ~Edge-RC Devastator DTV sloper~
This is my second Devastator and the only reason I parted with the first, was so that I could persuede my buddy into getting beyond the Weasel Pro. After seeing my Devastator fly, he litterally whipped out cash right on the slope.. It "was" my best flying plane..
~~Thread for my first Devastator~~
~~Link to a video of my first Devastator~~
After talking with Justin(owner Edge-RC) and ordering up some more Devastators, he decided he would make a true sloper from the E-planform and change up a few things. It now has a center fin, and IMO a MUCH improved spar system.
A few notes..
~ This is a wing in the prototype stages and availibility could be a moderate wait. Justin is a busy man and don't expect it in a week if you order one.. Few weeks minimum probably. It's worth the wait...
~ I will be adding a few things which are not in the "kit" and will try to note them as I progress with the build. Justin may chime in also and add some info, hopefully..
Can't wait to get this thing done and bust some more "grass skimming ACRO DS"... Such a great handling plane. Can't say it enough..
I am using Goop in this build as my target weight is 27-30oz, and I want STRENGTH. Nothing compares to Goop in all out EPP strength but if you want a slightly more delicate stucture, and about a 3 ounce lighter AUW, I'd go with PU glue... PU is great but becomes brittle, and from my experience, won't take a "shock load" like Goop.. Building with Goop takes time but it's worth it IMO..
-Don
Day one...
  • Name: dtv1.jpg
Description: Clean the core's with a scrap piece of EPP.. Clean the core's with a scrap piece of EPP.. 64.4 KB · Views: 866
  • Name: dtv2.jpg
Description: Sand spar slots so the spars will fall into the slots. If they are tight it will distort the foil.. Sand spar slots so the spars will fall into the slots. If they are tight it will distort the foil.. 73.0 KB · Views: 619
  • Name: dtv3.jpg
Description: Sand the main spar the same way, and check fit. Main spar must also drop deep as the two bottom spars sit on top. Make sure they clear.. Sand the main spar the same way, and check fit. Main spar must also drop deep as the two bottom spars sit on top. Make sure they clear.. 68.2 KB · Views: 683
  • Name: dtv4.jpg
Description: Goop panels together and tape.. Goop panels together and tape.. 83.8 KB · Views: 714
THUREN is offline Find More Posts by THUREN   Reply With Quote
Old Aug 29, 2006, 11:22 PM   #2
blah...
THUREN's Avatar
Still day one..
I don't use the wing beds as they aren't usually 100% true. A good flat surface works great with this plane as there is zero washout etc. Just make sure to weight it evenly..
-Don
  • Name: dtv5.jpg
Description: Goop in the main spar and be sure to push it deep enough so that the smaller panel spar can sit flush on top of it. Goop in the main spar and be sure to push it deep enough so that the smaller panel spar can sit flush on top of it. 80.1 KB · Views: 708
  • Name: dtv6.jpg
Description: make sure everything is straight and let sit overnite. I babysat the spar for about an hour to make sure it didn't push out.. make sure everything is straight and let sit overnite. I babysat the spar for about an hour to make sure it didn't push out.. 58.9 KB · Views: 676
Old Aug 29, 2006, 11:32 PM   #3
blah...
THUREN's Avatar
Day two...
This new kit has the 4 added spars which do not come in the E-version. I added ribbon spars to my first Devastator but they became soft after a few poundings. These a true heavy wall round spars and they do an awesome job of making a reliably stiff/strong wing...
  • Name: dtv9.jpg
Description: Top and bottom spars touch in the center but are not joined in the kit. I cut a nail, bent it to shape, and wrapped it to the spars with CF tow, CA, and kicker. I would have used Kevlar if I could have found it.. Top and bottom spars touch in the center but are not joined in the kit. I cut a nail, bent it to shape, and wrapped it to the spars with CF tow, CA, and kicker. I would have used Kevlar if I could have found it.. 80.1 KB · Views: 708
  • Name: dtv10.jpg
Description: clearance EPP for nail addition.. clearance EPP for nail addition.. 67.9 KB · Views: 716
  • Name: dtv11.jpg
Description: Fill slots with goop, smooth down.. Fill slots with goop, smooth down.. 70.6 KB · Views: 648
  • Name: dtv13.jpg
Description: lay some masking tape down.. Remove after about 1 hour for final dry... lay some masking tape down.. Remove after about 1 hour for final dry... 68.6 KB · Views: 660
  • Name: dtv12.jpg
Description: Set bottom spar in the same manner, and leave flat overnite.. Set bottom spar in the same manner, and leave flat overnite.. 75.7 KB · Views: 666
Old Aug 29, 2006, 11:42 PM   #4
blah...
THUREN's Avatar
Day 3....
The center fin mount plate design is 100% Justins, but I am flipping it over and adding a center carbon rod in the slotted plate. The fin mounting is hard to describe but you'll see as I go...
It will be BOMB PROOF as the two plates will be locked, and then Gooped to the main spar on top of that. The entire assembly would basically have to be ripped out with the main spar!!!
  • Name: dtv8.jpg
Description: Top centerfin plate with pre-cut location.. Top centerfin plate with pre-cut location.. 69.0 KB · Views: 679
  • Name: dtv16.jpg
  • Name: dtv14.jpg
Description: goop in bottom plate and check that slot in parallel to flight direction.. goop in bottom plate and check that slot in parallel to flight direction.. 49.2 KB · Views: 612
  • Name: dtv15.jpg
Description: Scrape out Goop spoooooge. Do this every 30 min as it keeps spooooging for a bit.. Notice where the main spar is. Super strong center fin design ehhhh? Scrape out Goop spoooooge. Do this every 30 min as it keeps spooooging for a bit.. Notice where the main spar is. Super strong center fin design ehhhh? 54.1 KB · Views: 672
  • Name: dtv17.jpg
Old Aug 29, 2006, 11:50 PM   #5
blah...
THUREN's Avatar
Day 4.....
Note..... On everything I goop I use the masking tape to leave a smooth surface, but it slows dry time substantially... I remove the tape after the goop gets "rigid" but not fully dry....
  • Name: dtv19.jpg
Description: You get the idea... The solid CF rod will be gooped in place.. You get the idea... The solid CF rod will be gooped in place.. 74.8 KB · Views: 693
  • Name: dtv20.jpg
Description: I'm adding 2.5oz to the nose from the get-go.. Dug a slightly small hole for the lead chunk, heated the lead, grabbed with pliers and burned a perfectly shapped hole, and lined hole with some Goop.. I'm adding 2.5oz to the nose from the get-go.. Dug a slightly small hole for the lead chunk, heated the lead, grabbed with pliers and burned a perfectly shapped hole, and lined hole with some Goop.. 77.8 KB · Views: 624
  • Name: dtv21.jpg
Description: Set on EPP cover, taped down.... Set on EPP cover, taped down.... 53.7 KB · Views: 609
  • Name: dtv22.jpg
Description: pressed for the nite.. pressed for the nite.. 81.9 KB · Views: 596
Old Aug 29, 2006, 11:52 PM   #6
blah...
THUREN's Avatar
Day 5.....
  • Name: dtv23.jpg
Description: CF trailing spars drying in goop....  Not in kit.. CF trailing spars drying in goop.... Not in kit.. 75.0 KB · Views: 607
Old Aug 30, 2006, 12:00 AM   #7
on a vacation
willhaney's Avatar
Man this is looking sweet! Did you use flats on the trailing edge or tubes?
willhaney is offline Find More Posts by willhaney   Reply With Quote
Old Aug 30, 2006, 02:06 AM   #8
-DoubleV-'s Avatar
im shocked!...... i was waiting to read something about 'calling me out' don, lol.
V V
-DoubleV- is offline Find More Posts by -DoubleV-   Reply With Quote
Old Aug 30, 2006, 03:00 AM   #9
Don,
I'm liking that black and green look. Very Xbox
Lance
hydrogin is offline Find More Posts by hydrogin   Reply With Quote
Old Aug 30, 2006, 09:15 AM   #10
fast chevron foam
WingmanDan's Avatar
Great job so far Don!! As you know, I recently built one of these DTV devastators myself. They are super fast for a chevron, like a halfpipe. AKA combatwing killers. But in a recent unfortunate "turn" of events (pun intended), it landed upside down on the fin I am going to redo the fin mount like yours (I have been waiting for this thread).
I want to see how you end up at 30oz, mine is only 20! At 30 it probably cuts the air waaaaaay faster.
Dan
WingmanDan is offline Find More Posts by WingmanDan   Reply With Quote
Old Aug 30, 2006, 10:26 AM   #11
blah...
THUREN's Avatar
willhaney,
Flats for the sub TE. I like tubes also but I wanted this wing to be a combat basher also, and thin-wall tubes tend to split.
Vic,
LOL!!! I'll race ya' on the frontside but you can keep the DS record YO! Allthough these Devastators DS great(first plane I "pulled" an inverted lap with), they are more of an aerobatic close in DS'er and not the ba!!'s out wide lap screamer. Probably could be a wide lapper with some more weight but ehhhhh...
Lance,
Xbox? Is that some sort of video game gizmo?
Dan,
My first Dev came out at 24oz and I was trying to be a "little" conservative with weight. I used PU glue and CA a lot on that one but Goop is so much heavier, I'll be glad if this one says under 30oz. At 24oz my last one could float in light air and SCREAM at the same time. I want this one to be a serious speed demon in medium lift and a few more ounces shouldn't hurt the light air performance. At 20oz your's must fly on NOTHING!!
-Don
Old Aug 31, 2006, 10:20 PM   #12
blah...
THUREN's Avatar
saaaaaa mmmmorrrrrrrree
progress..
16oz now... Hmmmmm. lets take a guess......
Receiver........................... 1oz
elevons........................... 1oz
moderate/heavy tape job.... 3oz
center fin assembly............ 2oz
ultracoat......................... 1oz
Thinned Goop.................... 2oz
linkages, hinge tape, etc..... 1oz
27oz....... We'll see!!!!
  • Name: dtv24.jpg
Description: Split a 2300mah NiMh brick pack and sunk it in, touch o' goop.. Dremel'd out a receiver bay.. Split a 2300mah NiMh brick pack and sunk it in, touch o' goop.. Dremel'd out a receiver bay.. 54.5 KB · Views: 624
  • Name: dtv25.jpg
Description: Dremel out bay's for HS85MG's. I am SICK of digging out servos/wires, so I am gluing in an extension right at the servo for future ease of repair.. Dremel out bay's for HS85MG's. I am SICK of digging out servos/wires, so I am gluing in an extension right at the servo for future ease of repair.. 83.1 KB · Views: 614
  • Name: dtv26.jpg
Description: Servo is fed from the bottom so the long control horn doesn't protrude too high from the top. Servo is fed from the bottom so the long control horn doesn't protrude too high from the top. 68.6 KB · Views: 559
  • Name: dtv28.jpg
Description: Servo flush with the bottom.. Servo flush with the bottom.. 57.0 KB · Views: 537
  • Name: dtv27.jpg
Old Sep 01, 2006, 09:07 AM   #13
fast chevron foam
WingmanDan's Avatar
Don, sweet techniques! I especially like how you split the battery, I had trouble fitting mine around the spars but didn't think of splitting it like that.
I am anxious to know your final CG and throws. As I mentioned before, I have trouble with mine tip stalling in the turns... I even tried taping on winglets instead of the center fin but it did the same. Maybe mine is too light, I weighed it yesterday and it's only 17oz!!
Old Sep 01, 2006, 10:02 AM   #14
blah...
THUREN's Avatar
17oz..
Gnarly!!! Did you ballast with helium?? Should fly great really as long as you can keep it moving...
Did you try moving the CG forward yet? Or get a chance to go inverted in some OK lift? That will tell a lot, if it hasn't yet Dan.. With the CG too far back it will want to fall out of the sky in the blink of an eye, in a tight slow turn, like most "fastish" planks/wings. Most "fast" planes, even conventional planform will do that actually with the CG too far back.
Few more pics..
  • Name: dtv29.jpg
Description: covered the battery bays with some of that clear thin strong plastic "everything" comes in.. Also installed the antenna while I was thinking about it. I allways forget till the tape/covering is on.. covered the battery bays with some of that clear thin strong plastic "everything" comes in.. Also installed the antenna while I was thinking about it. I allways forget till the tape/covering is on.. 76.7 KB · Views: 622
  • Name: dtv30.jpg
Description: better picture of the covers.. Dab-o-goop to hold em' on.. better picture of the covers.. Dab-o-goop to hold em' on.. 61.7 KB · Views: 583
Old Sep 01, 2006, 11:44 AM   #15
PWP!
ajroahkni's Avatar
don-got-skillz-dot-com
This is such an awesome, clean install.
Enjoying your work!
John
ajroahkni is offline Find More Posts by ajroahkni   Reply With Quote
Discussion Devastator DTV... Little aerobatic DS vid.. THUREN Slope 8 Oct 30, 2006 09:21 PM
Discussion what the DS record for a Zagi 5C? longdollar Dynamic Soaring 5 Jun 16, 2006 01:00 AM
New DS record holder (same DS record) bjaffee Dynamic Soaring 5 Nov 25, 2003 08:01 PM
"New DS Record set for Arkansas!!!!" Nick Trubov RCSE 0 Aug 08, 2003 03:03 AM
"New DS Record set for Arkansas!!!!" GordySoar@aol.com RCSE 1 Aug 08, 2003 03:03 AM
11
