Old Aug 29, 2006, 06:00 PM
rcgroupie is offline
Find More Posts by rcgroupie
pushing the envelope
rcgroupie's Avatar
USA, CA, Los Angeles
Joined Jun 2005
CNC cutter and special alloy Hot Wire - works straight from a 12V battery.
I've been in the process of designing / building a custom cnc foam cutter, it became necessary to build a hot wire bow.
I've been reading all the posts by people who have had trouble cutting foam - especially EPP - with a hot wire.
As a metallurgist, I developed a special alloy wire that has the perfect characteristics for cutting foam.
All you need is a 12V car battery, and about 4' of special wire.
So far I have the wire, the stepper motors, controller, lead screws, and misc bearings, and it is starting to go together.
I also have some big blocks of 1.9 EPP 4' X 3' by 4" or so.
rcgroupie is offline Find More Posts by rcgroupie
Old Aug 29, 2006, 07:55 PM
OzDragonFlyer is offline
Find More Posts by OzDragonFlyer
Model Bender
OzDragonFlyer's Avatar
Australia, NSW, Newcastle
Joined Jun 2004
More info please! resistance per foot, tensile strength, wire gauge/dia etc?
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old Aug 29, 2006, 10:20 PM
rcgroupie's Avatar
Joined Jun 2005
Since the development cost me quite a bit, the details are proprietary. If someone really wants some, please reply or PM and I'll consider selling some for a couple bucks/foot.
1. Attach leads to wire
2. Attach 12V car battery
3. Cut foam.
Small variations in length are possible for your specific foam - just move the leads.
Old Sep 01, 2006, 09:19 AM
saucerguy is offline
Find More Posts by saucerguy
saucerguy's Avatar
United States, WA, Yacolt
Joined Dec 2005
hmm...
How quickly does it move through the foam?
saucerguy is offline Find More Posts by saucerguy
Old Sep 01, 2006, 09:39 AM
jamessimon is offline
Find More Posts by jamessimon
Joined Oct 2005
Attaching to a car battery like that is dangerous. Too many amps possible. Bad results.
jamessimon is offline Find More Posts by jamessimon
Old Sep 01, 2006, 10:57 PM
rcgroupie's Avatar
Joined Jun 2005
James:
Apparently you are not familiar with elementary physics.
Saucer:
Slowly. Too hot and the foam 'melts away' from the wire, causing a loss of precision.
Old Sep 03, 2006, 12:51 AM
moreil is offline
Find More Posts by moreil
Sydney, Australia
Joined Jun 2005
And what are the 'perfect characteristics' for cutting foam?
Have you managed to build a wire with a negative temp coefficent of resistance?
moreil is offline Find More Posts by moreil
Old Sep 03, 2006, 03:20 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
All you need is a dimmer switch and a 120/24V transformer. Then you can use stainless steel wire (braided or solid). http://www.rcgroups.com/forums/showt...72#post6002347
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Sep 03, 2006, 03:58 PM
dusty IV is offline
Find More Posts by dusty IV
dusty IV's Avatar
Joined May 2004
I made my swing arm foam cutter eons ago. I cut maybe 6-8 cores a year. Unless your in a production environment I see no reason to go CNC.
The power source for the wire seems to be all over the place. I tried some of the suggested methods and had nothing but trouble with breaking wires and running either to hot or to cold.
So I made up a regulated current power supply. Nothing fancy I just use a series pass voltage regulator set up to regulate the current. A very old design. It runs off off 14V. For the wire I just use piano wire from my hobby dealer. Costs about .50 as I remember. Never had a wire break and the temp holds spot on.
KISS is the key.
dusty IV is offline Find More Posts by dusty IV
Old Sep 03, 2006, 04:25 PM
Joined Dec 2003
Dusty: Do you have a schematic for that?
Brad
Old Sep 03, 2006, 07:52 PM
Model Bender
Joined Jun 2004
Now there's a thought! I could use it with my cold fusion powered DC generator I keep hidden under the bed.
Old Sep 03, 2006, 09:51 PM
moreil is offline
Sydney, Australia
Joined Jun 2005
Yes, I was also curious to know if it was zero diameter wire...
Old Sep 03, 2006, 11:20 PM
RC_Junkie2006 is offline
Find More Posts by RC_Junkie2006
Fortune favors the brave.
RC_Junkie2006's Avatar
Vancouver, Canada
Joined Jul 2006
3. Cut foam.
I tried to use this contraption and look what happened to me!
RC_Junkie2006 is offline Find More Posts by RC_Junkie2006
Old Sep 05, 2006, 09:16 AM
Joined Oct 2005
James:Apparently you are not familiar with elementary physics.
Which elementary physics is that? The part about melted wire burning flesh or the part about shorted batteries spraying acid?
Maybe you meant elementary electric design, the part about fuses.
I don't need that stuff. You see, I can predict the future and I see a trip to the E-room in yours.
Old Sep 05, 2006, 12:14 PM
rcgroupie's Avatar
Joined Jun 2005
You apparently can't even predict the past.
I've cut and flown foam with it. EPP. So the bumblebee can't fly. Better revise your theories to fit the facts.
Oh, and maybe someday your mommy will let you fly glow. Props + fingers = too dangerous. Shouldn't you be in school?
This wire maintains a stable temperature from a standard battery.
Mini Hot Wire Cutter BFLYER1151 Foamies (Kits) 8 Sep 11, 2002 01:53 AM
Power Supply Transformer, for hot wire cutter, or flight pack charging Salin Electric Plane Talk 1 Aug 25, 2002 04:38 PM
Hot Wire cutter ornitech Foamies (Kits) 2 Jun 26, 2002 02:23 AM
hot-wire foam cutter with Astro 110d charger? esox Foamies (Kits) 5 Apr 25, 2002 04:28 PM
Hot wire cutter genovia Parkflyers 0 Mar 15, 2002 11:48 AM
