Old May 17, 2001, 08:40 PM
Cash Traylor is offline
Find More Posts by Cash Traylor
Senior Member
Dallas, Texas, USA
Joined Feb 2000
Help - Prism 7x and V-Tail Mixing with aileron differential (channel 1 and 6)
OK, I've looked through the book and I can't find the answer. I am trying to get this plane ready to go for a friend, so my wife can take it to him when she leaves tomorrow (flying north). Help!
Here is the problem: I have a V-tail plane that is setup with 4 servos. 2 for the rudder/elevator-vtail and 1 for each aileron. I can enable V-Tail mixing to get the elevator/rudder working, but I can't figure out how to enable the ailerons (only the aileron on channel 1 is responding). I need to setup the aileron mixing from channels 1 to 6 like in differential, but that mixing option is on the same setup menu (as far as I can tell). How do I setup both V-Tail and the two ailerons, is this even possible. I plan to try and call Hitec tomorrow if "we" can't figure it out - but this is perplexing.
Here is the "desired" setup:
Channel 1 - Aileron number 1
Channel 2 - V tail elevator
Channel 3 - Throttle
Channel 4 - V tail rudder
Channel 5 - empty
Channel 6 - Aileron number 2 (mixed)
Any guesses? (I'm going to copy this to the Ask Mike at Hitec Forum in case no one here knows...)
Or do I just have to Y- connect the Aileron channel 1... (would prefer a computer mix if possible)
Can it be done fellow Prism owners?!?
Thanks!
Cash
Cash Traylor is offline Find More Posts by Cash Traylor
Old May 17, 2001, 09:21 PM
RickTatem is offline
Find More Posts by RickTatem
All Hail Brak!
RickTatem's Avatar
United States, NC, Fuquay-Varina
Joined Mar 1999
Well, the Prism 7 (no X) only does one type of mixing at at time. If you want V-Tail (VTL), you can't have aileron differential (DIF)... and vice-versa.
I'm pretty sure the mixing menu is the same for the 7/7X... the differences between the 7 and 7X are (all additional functions to the 7) buddy-box, freq shift changeable(hitec/airtronics), and aileron-rudder coupling. (maybe more, but that's what's obvious)
Rick
RickTatem is offline Find More Posts by RickTatem
Old May 17, 2001, 09:42 PM
Senior Member
Dallas, Texas, USA
Joined Feb 2000
That's what I was afraid of. But that is ok, aileron mixing was not a "requirement," just would have been nice.
Thanks for the info.
Does anyone know of a radio that does perform multiple mixes such as this?
-Cash
Old May 18, 2001, 08:08 AM
BobK is offline
Find More Posts by BobK
Rhode Island
Joined Oct 2000
Futaba 6XA
BobK is offline Find More Posts by BobK
Old May 18, 2001, 01:38 PM
techroscope is offline
Find More Posts by techroscope
techroscope's Avatar
Huntington Beach, CA
Joined Feb 2001
Hitec Eclipse 7...
techroscope is offline Find More Posts by techroscope
Old May 18, 2001, 05:00 PM
Senior Member
Dallas, Texas, USA
Joined Feb 2000
Ordering an Eclipse....
Cash
Thank you everyone!
Old May 18, 2001, 05:25 PM
crux is offline
Find More Posts by crux
Narr, RI ,USA
Joined Dec 2000
See if channel 5 will do the other aileron
6 might be the LG channel.
Just a guess??
crux is offline Find More Posts by crux
Old May 18, 2001, 05:32 PM
Svengali is offline
Find More Posts by Svengali
Crash test dummy
Svengali's Avatar
Atascadero, CA
Joined Dec 2000
The Flash 5 can also do this.
Svengali is offline Find More Posts by Svengali
Old May 20, 2001, 12:34 AM
Senior Member
Dallas, Texas, USA
Joined Feb 2000
If the Flash5 can also do it, that makes me have to wonder if it is a software limitation. If so, you might wonder if Hitec would ever offer a software upgrade.
Hmm,
Cash
Old May 20, 2001, 10:31 PM
Senior Member
Dallas, Texas, USA
Joined Feb 2000
Never mind... I had no idea that Electronic Vtail (receiver add-ons) mixers were so cheap. I've never needed one. I just did a search and found several that weigh practically nothing for around $20. Heck, if I need both types of mixing in the future, I'll just add one of those to the Aileron Differential Mixing from the radio. Funny how things seem a big deal at first, then when everyone here starts making suggestions (in the Hitec thread) the problems go away.
Cash
V-tail mixing help mohillbilly Beginner Training Area (Aircraft-Electric) 4 Aug 28, 2005 09:45 AM
Question Need quick help setting up Flash 4 for V-tail mixing! ScienceGuy Parkflyers 6 Dec 28, 2003 11:26 PM
Help w/ V-Tail Mixing on Futaba 6A & GWS R-4P Aspen Parkflyers 3 Dec 30, 2001 05:01 PM
Need help with V-tail mixing Hank Electric Plane Talk 5 Nov 28, 2001 07:38 PM
Flash5 and V tail mixing BleakleyS Electric Plane Talk 6 Jun 15, 2001 05:18 PM
